Hi Bro and Sis, if driving a car pass by the stationary speed cam can we excess by 10km/h? Let say the stationary speed cam is 60km/h. But speed is about at 68 to 70km/h?
  • Replies 31
wait for 2 weeks and you will know...
in the meantime just playplay...that the camera is a dummy.
The legends going around is that that the speed camera will capture your moment of glory only if it is speed limit + 10km or so. :D
And factoring your speedo inbuilt overreading (I presume), you are probably safe.
Every now and then, we all tend to scare ourselves with these incidents. ;D
Hardcore
Think have allowance of +10km/h. Last when i ride sp pass by there 70km/h everyday. I'm sure got many driver or rider don follow the speed limit. But now because from bike change to van so don know is it same as bike.. curious...
speed cam has approx +10km/h allowance, tp does give some allowance also, but depend on situation.
analogue speedo has some tendency to show higher speed, while digital speedo is more accurate.
usually if u trip the cam, u'll see a flash from ur mirror.
some cam housing r dummy as the equipment r expensive, they swap the place from time to time. hot spot areas confirm have cam inside.
some ppl like to play the limit. i always stick to below the road limit so that i have allowance in case i forget the cam is there.
btw, van has a speed limit, 60 or 70, if u're on the expressway, limit is 90, but u're forced to go 60 or 70. the speed trap there might not catch u, but tp will. witness lots of time, tp always like to stop van, lorry or bigger vehicles.
Yup Tp will caught when the van or lorry is hogging the road. But mostly van or lorry wilk go at 80km/h. But everytime i saw is tp chasing lorry or van to the most left lane...
i think only the kpe cam is working
KPE cams are using laser speed camera working 24/7. No need to change films, unlike the old type cams.
I tink most of us probably knows about this when KPE first opened to the public, the first few days or something, many were caught speeding. Probably the legend of 70+10km does not apply here? haha...those laser cameras are accurate.
Hardcore
accurate or not, i believe they do give some allowance, although the 10km/h is a myth, it might be lesser.
kpe cams r working but they do have e +10kmh allowance. tested n proven, i travel at 80kmh there daily, no summons so far. u can travel at e limit safely but dun overshoot tt, anything pass 85kmh, they flash
the one and only...
-=#BLUE^CHILLED^COLA#=-
ur 80km/h is based on ur speedo? how accurate is it?
thanx for the info..
Good infro feelick.... but think it can go max to 80km/h... if 81km/h then will kena liao...
my friend on drz told me 89km/h will not kena.
i test on my pgm3 also just below 90km/h.. (my pgm3 meter has been tested as quite accurate to the tp.)
u sure ur friend never bs u?
For kpe my friend have drove pass e cam at 82km/h in the end kena summon. Think 80 should be all right...
Firstly, all vehicle speedos are about 10% optimistic ie, speedo reads 90kph, actual speed is about 81kph. Of course the difference varies from different makers.
Secondly, it is true that all speed cameras have certain tolerance above the prevailing road speed limit however that discretion is in the hands of the TP reviewing the records. No one will get a speeding ticket for going 2kph above the speed limit.
Road speed cameras usually uses doppler technology while handheld speed detectors uses laser.
yup incase u didnt read, i tried too, just below the 90km/h on my meter.
Maybe u can follow me if u want to try.
i doubt u're really on 90km/h when ur meter show u 90km/h. a lot of other bros cofirm getting caught at 8xkm/h.
i'm not getting risk getting caught in kpe, n i seldom go there. if u really want to know ur actual speed, i got a gps, pm if u're around the area. :)
good idea..
but how can we know whether ur gps speed is same as TP & Lta speed cams/laser/sensors?
What GPS do you have that give speed reading in a tunnel ?
