I'm riding an X1. I seldom wack the back as i believe 110cc will always be 110cc. So 80 to 90km/h is enough for me. Recently i tried to wack the bike to see if its able to hit above 100km/h. And the result is positive. But after i park the bike, there's a leaking underneath the engine area. Black liquid which i believe is engine oil. Yeah so i trace it back to where it came from. It leaks from underneath the engine part. I dunnoe how to say it in exact. Engine casing or the engine part where the yamaha logo is. On the left near the gear area and at the bottom part. Yeah it leaks abit . Wipe it with cloth and problem solve after that. It happens only after i wack the bike. Anyone know why ? what should i do to resolve it ?
  • Replies 11
you are pushing your bike pass the limitt...doesnt mean the speedo has a 160km limit or whatever linit...it is not advisable to reach that..or to go above a that limit..
small bike 110cc...90kmh is my limit..
more than that..sooner rather then later ...something will give way...
your bike just shown you...sonething has broken in your bike..lucky if it is only a busted gasket...worse one will be busted crank case...piston cylinder...etc..
get it check before serious damage occurs..
expensive lesson...if you dont respect manufacturers reccommendations...whatever it may be. imho
It is definitely not oil from the chain, as the replies stated the gasket is broken. Black liquid is the mix of petrol and engine oil. If you don't change it, the water pump will be next and changing the pump kit and flushing of the petrol tank and later on change of engine oil will cost about 200 plus. If you are on the road, then tow will be included.
Hit me before mine was white liquid like milk, even worse.
http://i231.photobucket.com/albums/ee289/SingaporeBikes/Siggy/GothRod_Siggy.jpg
Proud owner of GODSENDWORX's custom made Mesh
i"ve ruptured a gasket?Which gasket is that ? And what should i do to rectify it ? i've full service it on feb. Yeaah the normal speed i ride was 80 to 90km/h. Just that i wanna see how far it can go. For lubing of chain, i dont think it come from there.
Use spanner to tighten the engine oil cap and observe few days again.
