hi guys..if i start the engine..and got the eeeee sound..but then it wun start...is it becos of sparks plug? becos i dun think is starter cos if starter got problem..it wun even gif out the sound...and dun think is batt weak cos the sound very strong..and i can feel that the batt is still going strong? any more idea beside sparks plug?
NSR Sp 2004/5
RVF 2005/6
Honda Civic 2006
Kia Koup 2010
Honda Odyssey 2015
BMW 520i 2017
  • Replies 6
Originally posted by limbat@January 25, 2007 09:55 pm
If " got the eeeee sound " ............... then most likely the starter motor cannot engaged the car flywheel to start the engine................ :smile: :smile:
wah..chim..flywheel i wat? then is what thing spoil?
NSR Sp 2004/5
RVF 2005/6
Honda Civic 2006
Kia Koup 2010
Honda Odyssey 2015
BMW 520i 2017
The flywheel is someting like a small gear connected to the engine, after that the flywheel rotates the crank shaft to give the momentum.. den wat happens after that, guess u should noe since ur also a seasoned biker... so as pointed out earlier, the engine will not start if the starter fails to engage the flywheel.. guess it might be wear & tear prob as civic esi is quite an old car already.. pls correct me if my concept is wrong... :smile:
<u>Past Ride</u>
Jan 2005 - Dec 2006 FT2#5#Y Honda NSR 150 SP
<u>Current Drive</u>
Apr 2005 - ????? SFU2@#2A Hyundai Getz 1.3A
<u>Ideal Plan</u>
Bike - RVF NC35
Car - EVO/STI
http://i252.photobucket.com/albums/hh35/Benben81/Photo_0003.jpg
Better to get yr car check by auto electrician .................. lor ............... most likely your starter motor needs servicing .....................
HP: 93891138 :angel:
Well said ................ mate :thumb:
