I have a battery problem. It's runs flat for a couple of times this month. Had it for a year now. The battery before I used last me for years. Any ideas guys?
:bounce::bounce:
  • Replies 24
how often do you use your bike?
if you seldom ride, lithium iron phosphate (LiFePO 4) battery might be a good choice. it on the expensive side. alternative, you can hook it up with a battery charger.
if you ride your bike often yet it still go flat, get your charging system tested.
I ride everyday. Did asked a bike shop, they said, it's normal that battery only last for abt a year. Hmm... Not so convince leh
:bounce::bounce:
The standard manufacturer batt of your bike shld be the best, most likely Yuasa .. Do note of different types of Yuasa, u get what you pay for..
For aftermarket batt, there's a number in the market, motobatt is worth trying cheap n can last almost 2 yrs..
Hmmm.. Now kinda dilema when you have to choose between two.
LiFePO 4 or LITHIUM ION.
Anyone had use these could help me decided.
:bounce::bounce:
I used Shorai (its a lithium battery like "Ballistic") on my DR before.
The performance was better than any Yuasa battery I used. Never went back to using the default Yuasa lead batteries.
My apology to TS for side track.
Is the Ctek battery charger suitable to charge the LiFePO 4 and LITHIUM ION battery or the Ctek is suitable for those Yuasa ones?
Did some search..
Lithium Ion Batt - $220
Shorai Batt - $220
Lifepo 4 Batt - $360
Yuasa Lead Batt YTX9-BS - $150.
Which is good? hmm...
:bounce::bounce:
Looking at your batt size,
1) Why not change it to YTZ10S instead, a bit higher Ah
2) Do you do a lot of short distance riding everyday?
3) Multiple cranking per day?
If both is yes. Each time u crank, batt is being drained + short distance riding (insufficient charging due to lack of distance) = short battery lifespan.
Root of the problem is not the battery but your usage. So even if change to Lithium batt, you will still have d same problem.
2011-2012 Yamaha FZ1-N
2012-2013 KTM 990 SMT
2012-2013 Harley Softail Blackline
2013-2014 Kawasaki ZZR 1400
2013-2015 Yamaha Tmax530
2014-2015 Ducati Panigale 1199S
2016- Can Am Spyder RSS
2016- BMW S1000R
Ctek normal charger is not suitable for Lithium type battery. they sell a dedicated lithium battery charger.
Did some search..
Shorai Batt - $220
maybe you like to have a look at this and this.
Yuasa YTX9-BS is too expensive at $150. which shop quoted you this price?
Wrong pricing for Lithium ion too ai'ya.. $228.
Can't say which shop bro, but thank a lot for the info!!!
Wah cant just buy anyhow.
I travel 2 times a day day, morning n afternoon. Crank no. 2. Ride 28km out 29 in, 5 times a week.
:bounce::bounce:
the 2nd one(CMO) is good. I've been using it for more than 1 year and still starts my bike at first crank despite 2weeks of not riding.
Did some search..
Shorai Batt - $220
Which bikeshop is robbing u of your hard-earned money for the Yuasa?
YTX12-BS at $65 and YTX14-BS at $85 at Planet Motor.
Ok The 2nd CMO is good but I m not electrically train or well knowledge in this but my batt is run on 12V 8A the CMO is selling a 14 AMP, that s a 6amp diff. wont it effect or fry the wire?
:bounce::bounce:
measure with a voltmeter.
Great video but at the end of it phew.. thats a lot of work ea..
Still what its says only from the stator fault or wire grounding but nutin much abt the rectifire, I think. Correct me ...
:bounce::bounce:
The battery rating has nothing to do with frying wire or rectifier etc....
Read more on batteries.
Sure thing bro, thks for the advice. Something that I hate when going to bikeshop, they fry me n my pocket.
"ahh.. this one no gud this one gud, this chg that chg bla bla bla...
Thanks you guys for helping me out n YOUTUBE helps!!!! tks GOD....
:bounce::bounce:
No prob. The numbers, be it 12 or 14, refers to AH = ampere hour.
Your accessories wont fry. They will still draw the required amperage no matter what battery size you dump into your bike. Having a larger battery will only mean you can have more accessories installed.
Good luck!
