hope ya all can help..
just get bike..
my biting point very near.. release just a lil bit bout 5mm bike can easily die off..
how to adjust uh..
loosen or tighten abit the cable near the lever?..
im confuse abit after do it on my bicycle.. hah.
another thing..
so happy2 ride...see red light.. stop.. engine will eventually die.
like a idiot .. will keep kickin.. before green light.. :sian:
i tried to clutch in early before stopping.. still will die..
read some posts here and there.. maybe spark plug?..
or because of clutch?..
Do Not Speed
  • Replies 7
lossen it by turning anti clockwise.. adjust untill the biting point u lyk lo.. engine die off is maybe the idling?o_O
http://i208.photobucket.com/albums/bb94/weiqiang240/photo.jpg
Live with the life you always taught us
try idiling
then adjust ur clutch cable -- to make it further, just turn the nob away from the lever(meaning, i sit on the bike, turn the nob so tt it moves abit to ur right), this is to make the biting pt further... trial and error to get what suits u
if persist
try servicing ur carb... maybe inside got water or dirty
Honda Wave 110s - FT7476M
Honda CG 125 ----- FK7947T
Suzuki Bandit 400 - FM 8039Y
Yamaha Fazer 6 --- FW7537E
Honda Steed ------- FN 5565R
Yamaha YP 250 - FS2578R
Suzuki DL650 ---- FX9497T
if u clutch in ur bike idling will drop alot, or u clutch in ur bike still can roll.. it's time to get a clutch plate changed and check inside ur clutch..
alternatively.. it's just mainly the idling, try turning 1/4 turn clockwise(if i not wrong) and try.. if not u try turning even more.. u look @ your RPM you can see it rise higher and higher if u turn more..
btw what bike r u riding?
Lousy Noob Rider
old bike..
sure lotsa problems..
rxk. but i just love make it look classic.
i adjust the knob already..
now much more better..at least got some clearance..
for the meantime.. when stop still engage 1st gear.. i will play throttle..
cos i dunno which knob to turn..
any rxk experience here?..
Do Not Speed
change cable,dude.
