1... check your tension tighten if necessary...if exceed max position..time to have chain replaced.
check for wear: at the sprockets pull/push chain links up and down if u can feel chain is moving then chain/sprocket needs to be changed.
2. oil all joints...return spring may need to be change. at the same time check for brake fluid level may be insufficient fluid.
Thanks for the info, bro.
Anyway, a quick update.
1) I went down to the bike shop yesterday. The mechanic tightened to the max, but the chain was still loose. So he proposed changing a new chain. At first, he quoted me $45, but subsequently realised he does not have stock for that chain. In the end, i hv to pay $100 for what he said a "better" chain. U guys think that is a reasonable price?
2) For problem 2, it turns out that the spring connecting the brake is rusty. He oiled it for me, and now, i think it's working somewhat better.
wahhh $100... even an x-ring chain shouldn't cost this much...
i think is the high end brands bahs... From italy or something.. saw someone posting a $100 chain somewhere before..
UPZ FOR GREAT INFO.
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Solution: Retune the carb.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
yar lor, put a big hole in my pocket. But no choice, i hv to agree, cos the mechanic oredi took out the old chain. Then he said dun hv the $45 chain. haiz.
i hope so too. But the mechanic said it's only from Japan. Dunno what DID brand. Oso never hear before.
Very siong siah. I bought the bike four mths back for only $800. Now just one chain oredi cost another $100.
Hello.. i riding TA200 , and u guys know when kick to neutral, that will be green light rite? but mine , every single gear also got green light . what happen actually ? =/
2. when i wanna take my bike, the floor got EO stain. what could actually happen ?
Determination is the wake up call to the human will..
2006 - SP150
2007 - Phantom TA200
2013 - Yamaha R15
[/img]
Thats why its only $800 ;)
Neutral connection at every gear? Hmm connection spoilt? :cheeky:
Something leaking? Gasket blown?:angel:
ohh.. icic.. thanks .. haha..
2006 - SP150
2013 - Yamaha R15
[/img]
i got a Qus... What are the signs to take note if my rear suspension is damage or not?
cause when i pillion , cross over a hump = bike produce music
some help here people.
try doing this without a pillion.
fly over a hump... your rear shocks would be compressed...
scenario 1: you return to normal riding height in a single motion - rear shocks ok :box:
scenario 2: you bounce up and down... up and down... boing boing boing... fail... your rear shocks need servicing... :giddy:
ok.. mine is scenario 1 for sure.. Think need to visit ah chong again liao... 3 visits in less then a week ;-)
the sound can only be heard sometimes when i pillion only.. is chain too tight a problem? maybe the mech tune till too tight?
well... a 3rd possibility is that the joint between the chassis and the swing arm is rusty / dry... maybe some lube would solve that...
either way, do ask ah chong about it... :smile:
gimme a call my no is in FNO thread...i might know the reason
J. P. Morgan
alright.. will trying doing as you said before consulting Doctor chong :D
Thanks thankz
your suspension hit the bottom limit..
try adjusting the suspension to a tighter level.
sound may come from your bike chain..as your suspension bottom, the swing arm actually goes up relative to the swing arm pivot, by going over the pivot the chain tension is actually increased....loosen your tension ( ie..u had the tension adjusted without using the pivot as a refernce.).if thats the case.
in your case..confirm which is happening.
oh.. so just tighten the suspension will do?? like what the ta200 manual says?? postion 3? tighter as in postion 1 or 5?
Edited by jtzx
wah..now u r talking like a potential xpert...:bounce:
hmm.. meaning?? postion 1 to 5... tighter = postion 5?
no idea.
hhahah
but i would increase the spring tension by 1 level and test..it should give u a stiffer ride. then test going over or carry pillion and confirm if it is working
no idea.
hhahah
confirm can liao.. i also dunno why my postion 3(tight) can jump till position 4(light)...
just went to check... need to open up my phantom tools and figure out which way to turn later ;-)
thats simple...turn into direction that reduces the spring loaded lenght...u just have to turn left or right....in most situation turning clockwise most of the time is tightening or increase the streess...coul be that way...
it stated in the manual.. postion 4 and 5 is to make your ride real hard.. but good for heavy loaded. But im already at position 4 and there's still sound when i pillion...
pin spanner i also dunno how to use.. Jia lat liao...
anyone?
Edited by jtzx
