yup possible to remove but how? so after removing the lock means the bike will be lockless, mux pray nth happen to it... ya go bike shop chg another piece of new lock, fastest but most wallet pain job...
There appears to be an 'optimal' carb setting for the TA200. Compared to my earlier settings, the engine runs almost silently under power.
If you got a chance, get a 38 rear sprocket (order it if you have to) because the longer gears are much nicer to ride with. I don't like running out of gears accelerating to highway speeds then stuck in 6th all the way. Lower revs = much cooler engine (can run leaner if you like), reduced fuel consumption and fun stuff like being able to ride in your optimal low-mid range torque all the time.
This bike is torquey enough to still launch in second gear with the new sprocket size.
With the higher top speed, you can cruise and/or overtake on lane 1 happily. Good windscreen = no windblast and less drag at high speed.
I wish I could tell if they're Honda originals but apparently after much discussion on the bike shop's phone I can only get 2 sizes for the Phantom - 41 or 38. Waited 3 hours for the thing to arrive from somewhere across the island and as far as I could tell it's a Honda Original judging by the packaging. Absolutely beautiful, full chrome and all.
As for the front one - we took out the f/sprocket cover and saw the clearance in there was already very tight with the stock 13 teeth thing. Putting a 16 on the front would yield even higher cruise speeds but we didn't want to risk the sprocket and chain grinding onto anything.
It's not like a 125Z where you can run size 17 in front, it's quite cramped down there on the Phantom.
As for performance wise, I do not think I'd want an even lower RPM setup because it's only a 200cc and there's only so much torque you could squeeze out of the thing without losing reliability or blowing a gasket. (that's why I didn't use water injection for a very long time now - the boost does strain the engine! as it did on fighter planes in the 40s: emergency use 10 mins only)
Damage wise - $156 inclusive of the awesome X-Ring heavy duty chain, special order rear sprocket, standard front sprocket, air filter, carb optimisation thrown in as well.
hmm but I normally dun travel to kaki bukit to service my bike. I go unique motors. yea I will like to call them to stiffen up my forks, you said add more oil right? is a bottle enough?
bro this one i would recommend u go to Planet instead. Same reasons why i told u last time. :)
http://i87.photobucket.com/albums/k129/ckoonyin/ThenandNowver2a.jpg
Yeah I went UM they quote me 80 bucks for the cone. I didnt change in the end. For me right now my back suspension is more important that my forks, afterall Im not a scambler that goes off road. And we have two suspension one on right and left unlike 1 like spark, SP, KRR or other sportsbike. So while cornering I need stiffer suspension so I wouldnt wobble, which after taking out my box I solved that. (:
wheres the list once again! remmber to always up the list..
Monoshocks are more advanced than our box-suspension units; they are stiffer and lighter almost all the time, giving even larger street bikes like Hyosung Comet a tremendously high safe cornering speed compared to ours. Super 2 needs to ride in racing line to keep up, while Comet just glides through 99 Bends like a crazy Japanese drifter.
ref: "Sheryl Nome Night Attack" video from last weekend.
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Solution: Nothing.
Edited by thechosenx
Solution: Nothing.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off.
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Kalyan)
Hi guys,
need some help here. a shop qouted me a total of $665 for a full overhaul of my phantom 200.
i remember, he qouted me, engine sprocket for $150.
re bore block for $25
concord around $100 plus.
Shop did give exactly what he change and price. Many items never change also, being reused.
so i need help, with that engine sprocket price, is it a fair price or the shop trying to chop me?
what is FULL overhaul price normally? i think shop qoute me $665 is no 'full' overhaul.
pls help. thx.
kind souls, please pm me please.
http://i24.photobucket.com/albums/c10/red0x/7-1.jpg
Never Shy To Use Your Horn
use alu sheets.. used for BBQ de.... but ugly...
guys!! help! big issue.. the tuning screw at my carb is missing! so i guess its super duper lean now... rode back slowly wif my throttle on all the way to my mscp... jux wanna ask if i can find a screw around my home that can fit the thread, will it work? or isit sum special screw wif sum special shape for its purpose?
yhis is a precision machined...and it comes in diferent sizes...u have to get it from the agent..oem also available..
either u buy from agent or get it from spare parts shop...
best is go to workshop and get it...there may be other issues ..
may be carb is the problem..loose screws..get it check thoroughly..
cant help you...for workshop in the west..
