urgent urgent.
My drain hose keeps on leaking petrol .. may I know what's the cause ? I have seen other phantoms, and their drain hose is not connected at the other end as well, but it doesnt leak any petrol . . may I know what went wrong ? I'm so lost yet again T_T
Adventure.
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Kalyan)
Solution: Gear box dying.
Solution: Engine is overheated. (Running too lean/ Not enough engine oil.)
hi guys, recently my bike is hit by dunno "hu" or "what" in the car park, and it fall. Today i was riding on AYE, keep feeling my bike seems to be like jerking from tym to tym, i duno is road uneven or bumpy. Any possibe reason to keep feeling that?
your bike doesn't seem like it is even safe to be ridden... you should get a trusted mechanic to have a look and test ride it...
Seconded, please do not risk yourself on a suspect machine. Nothing against the bike - it can survive the occasional drop quite well, but certain components bent out of alignment will adversely affect performance and safety. The mechanic can diagnose the problem better than most of us, and save you the liability of being responsible for DIY repairs.
If it falls to the right, the petrol from the carb/tank might leak out then the carb might be fill with air thus have the jerking feeling from time to time. But it will be ok after a short while.. This happened to me before. but it was ok after like 20mins of riding
*I don't entertain bullsh*t
lol I've seen some interesting reasons and solutions though some are quite DUH but still usable because people will still ask anyway without thinking :lol:
@razali1980 - the front brake light actuates by way of the "button" type switch. When you press the brake lever the inside part of it hits the button.
Not so easy to DIY but I suspect the "button" switch problem. Or it's wiring. Since the lever is a mechanical object and will actuate the button 100% of the time, I'm suspecting a little electrical connection issue. Or that the button has gotten stuck somehow.
Hmm... But I see that the botton actually ejected when i press the lever and it is not stuck but it just dun want to active the brake light... NVM I will ask Dr Chong and see if he can help... Thanks for the reply...
My front brake does not light up my brake light when press... Anyone know how to fix it??? Or I need to change the front brake lever???
wiring or switch prob only ;D hahaha...
guys... been hving this issues for d past 2 mths.. i hv trouble getting 1st gear wen im in Neutral.. last tym, maybe only 10% of d tym i cant get 1st gear on the first tap (as in 1 time i tap down d gear lever). nw, its like only 10% of d tym i can get the gear on d first tap. most of d tym, i hv to tap, clutch in n out at least 5-6 times then can engage..sucks wen there is bloody big lorry behind me.. played ard wif d clutch freeplay still no success..
chged engine oil still the same.. hw guys? it seems that the gear jux doesn't "snap" strongly anymore.. must keep pressing n pressing... urgh! isit a mechanical issue?
Or the switch spoil. My bike, the light activated when the button is depressed.
Try release clutch, then clutch in again and kick down when in neutral. I had this problem before after i fell, the gear lever was a little bent so its hard to hit gear 1. For all gears from 6 to neutral, kick a little will engage, but to hit gear 1, the lever has to move a longer distance. Just use a spanner bend the lever up a little can work. Did u fall on the left or hit something with the gear lever recently?
It happen to me also... All you need to do is... Push your bike slightly forward clutching in then kick again... And try not to reverse when in neutral espacially when you stop at traffic light... best dun even engage neutral when you stop at traffic light... just stay on gear 1 so you will be ready to go...
if the above suggestions doesn't help, try to kick from neutral down to first gear using half clutch... since I think you have "clutched in too much" :smile:
Hmm I realise after i off my engine i roll my bike forward there's a yiiiiiiii sound. Then I realise is my front tire is making that sound, anyone know what needs to be change?
sounds like your front brakes are screeching... check your front brake pad first
