Thanks for the info guys but is there any way i can do it myself? Like use water to clean or do i have to take out the whole brake?
not recommended at this point of time... just in case it is something more than that... besides, you probably don't have a compressed air gun right? :thirsty:
if u hv access to compressed air, its possible to try it out urself, cux iirc, its jux 2 bolts that holds d calipers.. but warning.. dun squeeze the brake lever when the calipers are off the disc.. :)
yep... need quite some effort to return the brake pistons to the closed position! :sweat:
guys... update on my problem regarding difficulty on engaging 1st gear!
-Open up ur front sprocket cover and u can see the rod that joins ur gear lever to the gearbox.. there a clamp with a bolt on it. mine was loose, and thats why when i depress the lever, the shaft that goes into the gearbox barely moves.. so just tightened it up, and voila! problem solved instantly! hahaha.. wat a small fix that helps my riding so much.. :) jux wanted to share wif the rest who might face this intermittent problem.. give it a try!
great to hear that you have found the solution! :clap:
now adays my bike goes into neutral gear too ezily wen frm 2nd to 1st or the other way... pretty dangerous sometimes, any way to fix?
i think lesser freeplay of clutch might helps. i remember the mechanic at unique saying if too lil freeplay very hard to go into neutral gear when i wanted to reduce the freeplay.
Nice tip - I'll try to get some pics when I poke at that area next :3
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Kalyan)
Solution: Gear box dying.
Solution: Engine is overheated. (Running too lean/ Not enough engine oil.)
guys.. recently, wen idling, my bike randomly "rattles".. lyk sumting is "loose" inside the engine lar.. quite obvious wen i cut the throttle suddenlyabit worried if sumting inside wanna come off like dat.. any one faced this prob b4? or is it the famed cam chain tensioner?
-edited-
i hv attached a recording of the noise.. turn up the volumes as well.. thanks for anyone who sees it... :)
http://www.youtube.com/watch?v=Ekx4HwWuQRE
Edited by naim
-edited-
several times, i have the same issue as you after i used a lousy engine oil. it goes away after riding for 5 minutes. do you have the same issue?
seems like engine knock... What you can do is to use better grade petrol and engine Oil or overhaul engine soon...
haha.. petrols play a small part. but EO plays a huge part ;D
Hi everyone, need your opinion on two matters for Phantom 150:
1) Difficulty changing gear when bike is stationary, with engine on.
For eg. At traffic stop, I am at first gear. Tried to change to neutral while bike stationary, but cannot. Or when bike is at second gear when stationary. Tried to change to 1st gear, oso cannot.
Subsequently, I tried to adjust the clutch free-play. Seems to be ok for a while after that.
But then the problem comes back again every 2 weeks after each adjustment.
2) Metzler back tyre leaking air
I am not sure if I pump too much air (36 units/250 kPa).
For the first 7 months when I changed the tyre, in March, everything was ok. So I pump air every 2 weeks initially, then once per month.
But recently, the air pressure seems to drop dramatically. For eg. I pump last Friday to 36 units. Then yesterday (Friday), it dropped to 8 units. Then today (Saturday), after having pumped to 36 units yesterday, it dropped back to 12 units.
The same thing happened when I used Pirelli last year…
Anyone can help?
difficult to engage as in ur gear lever like stuck, or u the gear itself doesnt get engage? i hope u get wat i mean..
if its difficult, try this:
-Open up ur front sprocket cover and u can see the rod that joins ur gear lever to the gearbox.. there a clamp with a bolt on it. mine was loose, and thats why when i depress the lever, the shaft that goes into the gearbox barely moves.. so just tighten the size 10 bolt and u shud be good to go.. u can first try pressing the gear lever, n see the shaft if it turns accordingly.. mine moved only a little, therefore the gearbox did nt engage it..
and guys btw, got my cam chain tensioner fixed... changed the cam chain and all the gaskets as well.. :) noise is gone.. nw i can ride happily n worry-free again!
guys... been hving this issues for d past 2 mths.. i hv trouble getting 1st gear wen im in Neutral.. last tym, maybe only 10% of d tym i cant get 1st gear on the first tap (as in 1 time i tap down d gear lever). nw, its like only 10% of d tym i can get the gear on d first tap. most of d tym, i hv to tap, clutch in n out at least 5-6 times then can engage..sucks wen there is bloody big lorry behind me.. played ard wif d clutch freeplay still no success..
chged engine oil still the same.. hw guys? it seems that the gear jux doesn't "snap" strongly anymore.. must keep pressing n pressing... urgh! isit a mechanical issue?
i am having the exact same issue ever since i started riding my dad's phantom after passing my license. seriously its annoying when u are in a hurry or at a traffic junction... i changed engine oil and the problem was solved for some time...but again the problem came back..and it was like the same again. i normally would ref my engine and the problem would be over...but its just for a min or so...i seriously have no idea whats the problem...bike had no falls... also at times it is difficult to engage gears properly...say from neutral to gear 1 or sometimes gear 1 to gear 2... i tried adjusting the clutch play, and saw some improvments...but seriously....neutral to 1st or 1st to neutral is a tough fight every single day...is there any recommended workshop that you guys know which i can go to and get my ride checked up once and for all? thanks...hope someone attends to my worries :(
have u tried the fix i did in the previous post?
another thing once u r fondling that area, u can actually remove the clamp, and rotate it so that ur gear lever can be made higher.. nt sure if u can picture wat i mean, but once ur gear lever is higher, it makes stepping down to 1st gear a whole lot easier..
ok bro...thanks..i will get it checked with what u have said... for me its more of the gear lever kinda stuck and at times....cannot engage to gear one properly...not at one click...i have to clutch in again to solve that problem... if u got pictures...it could be helpful for some of us here... :)
