i had problem engaging 1st gear some time back too, went to planet to change the foot gear lever thingy, cost $50... now its ok alrdy
footgear lever can get at unique@tohguan.
they having a clearance/promotion sale. can go their thread to see.
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Kalyan)
Solution: Gear box dying.
Solution: Engine is overheated. (Running too lean/ Not enough engine oil.)
Hi All,
i have a problem that has been plaguing me for months .. sent to bike shop, change quite a number of stuff but still giving me problem.
After travelling long distance, ~30km ... my bike engine can sometime die while when travelling slowly (gear 1). THis can also happen when stopping and moving again (at traffic light).
It is not easy to duplicate it (that mayb be why mechanic not able to fix it) as it happens once in a while but I feel this is very dangerous.
any ideas? thanks for your help
Hi All,
sounds familiar to situation I encounterd many many years back, have you changed your spark plug, battery, rectifier, main air filter, fuel tank air filter, service your carbuerator, electric coil?? if you have changed the mentioned items and problem still exists, you may have to consider overhaul your engine.
spark plug (changed), battery (no), rectifier, main air filter (changed), fuel tank air filter(no), service your carbuerator,(yes) electric coil(yes)
battery should be in good shape. Might try fuel tank air filter.
Do you think carburetor might be spoiled? I have not changed the carburetor yet.
It seems that you have done quite a few trouble shooting already. There can be many possibilities for such case, however, you need to trouble shoot further to determine the actual cause.
The carburetor is unlikely to be the problem but cannot phase out the possibility yet, it is not priority at teh moment unless you had modified it.
Focus on trouble shooting the electrical parts first, i.e., ignition coil for sparks and magneto coil. From your description above, did you renew or "repair" the magneto coil?
There can be chances that your clutch plates worn out also.
Edited by vvss
If most electrical changed, tuning since only at gear1 it happens? Which shop you went to? Perhaps ask mech tune for you opp of what you had, perhaps fast/slow pickup
Sent from my iPod touch using Tapatalk
Have u resolve this? I had the same problem n Ah Chong replaced my choke. He said it was stuck n problem gone after replacement. The original looks fine to me so don't think u can check it urself if it's the same issue
Hi All,
Liverpool revival has started....
guys... sry for the delay for my promise to upload pics on hw to solve a prob for those having difficulty engaging 1st gear...
so here they are:
Open your front sprocket cover (2 X 8mm bolts) and u will see this:
http://i16.photobucket.com/albums/b35/adiknaim/S7305059.jpg
the red circle is the where ur gear lever connects to ur gear shaft.. try n press down and up the lever a couple of times and see that whether ur shaft moves the same amount that ur lever does... if it doesn't, then urs is a minor fix and u may use my method...
tighten the 10mm bolt... dun overtighten it of cux! if it breaks, gd luck!
http://i16.photobucket.com/albums/b35/adiknaim/S7305057.jpg
all shud be ok.. play wif the lever, n if that is the fault, u shud hv no issues getting a solid "TAK" gear engage sound even wif ur hands...
if its already tight, and ur shaft moves together, yet the gear doesn't engage, then u might hv an issue wif the gearbox itself.. hope it helps some of u guys out there, without spending a bomb to the change the whole lever wen the fault is just a lose lever.. :) cheers!
Edited by naim
wow thanks a lot for that naim... really appreciate it
"Wolves and sheep will live together in peace, and leopards will lie down with young goats, calves and lion cubs will feed together, and little children will take care of them. Cows and bears will eat together, and their calves and cubs will lie down in peace." Isaiah 11:6-8
http://s-ak.buzzfed.com/static/imagebuzz/web02/2010/9/8/17/be-an-optimist-prime-4756-1283979887-3.jpg
Hi bros,
I'm having a severe sadness with my bike akin my wife suffering cancer. I recently sent my bike to a workshop at west coast to replace the cam chain tensioner and was told by the boss (sam) that i need to do a $200-$300 top overhaul as the timing chain is thinning already. It won't be long before the timing chain snaps and i'll have to pay more to do a $400-$600 full overhaul. He based it on my previous cam chain tensioner and his experience to suggest the overhaul.
He also suggested that i continue riding and don't think about it, when time is up, send the bike in and overhaul it. It will take 2 days for the completion of the overhaul.
I was wondering how can i verify if my bike requires overhaul and the accuracy of his judgment. I haven't sent my bike to other shops to get it checked, i was told that theres no way to check it as it still requires opening of the engine.
Please help! :(
Here's the cam chain tensioner,
http://img816.imageshack.us/img816/7274/photoin.jpg
Hi All,
recently got my phantom and would appreciate if someone would try to interpret some of the sounds i've been hearing.
1) a ticking/clacking sound when pushing the bike.
2) during engine braking, as i am slowly releasing the clutch, there is a whirring sound that seems like a front sprocket/chain problem. I've changed the chain and it seems better but still occurs from time to time.
3) a sort of hissing sound when gg at higher speeds. it goes away when i clutch in.
thanks in advance!
Hi bros,
Please help! :(
mine too cost ard $270.. which includes the tensioner n chain n all d necessary gaskets n seals.. cux my cam chain looks like it could use a chain.. so figured that since its already opened up, might as well change it..
naim bro, thanks for your reply.
how many days did your overhaul take?
the camchain in the picture is a new set. how does your cam chain look like that made you decide to do a change?
hey bros,
sometimes i got problem with starting the engine. I turn on ignition, got neutral light and headlight, but when i press on the starter button, nothing happens.
usually, when that happens, i just have to push the bike for a short distance and the starter would work normally once more.
can anyone advice me on the problem? thanks
My bike has problems engaging to lower gears some times when stopping. Ah Chong changed the clutch already. Any other suggestions?
you adjusted ur clutch cable freeplay already?
hey bros,
sounds like starter carbon finishing.. those were the symptoms i had.. eventually no matter wat i did, the starter did not work at all..
it didn't look that bad, but the mech advised me to just change it since its already opened up.. mine wasn't an overhaul.. so it was done within a day.. i sent in the morning, was done by night.. :) do take note.. a TOP OVERHAUL is replacement of other components such as ur piston ring, piston, engine block gasket.. ask ur mech properly on wat he means by that...
Yes of cos. Anyway, just to update, it turned out that the 3rd gear was spoilt... major repair almost $400 at Ah Chong's.
Hi all, was wondering what this meant.
is tt the idling speed knob on the right side of the carb? any pictures anyone? thanks!
Hi PKs,
I had my ta200 for almost 2 years already... some common issues which didn't bother me much, but i would like to share and see if u guys have encountered such issues.
1) Any idea why during pick up, there is this "tock! tock!" sound coming from my chain? (i do lube my chain every 500km)
2) not sure if it's me, but my engine (the part where u pour EO in) is hotter than usual after a ride
3) During change gear, 4 to 5, there seems to be some power loss, like the throttle is nt responsive, it takes like 1 - 2s before the engine goes VrOooM!
4) Fuel consumption has gone from 40km/l to 30km/l =( very sian...
5) My clutch slips when i rev too much during smaller gears
Please enlighten me broS~
ty~
Do what's right, not what you think is right. =)
