looks like d issue cud be from ur fuel system.. probably water in ur petrol.. i'd say jux keep an eye on d EO level over d next few weeks jux to cfm.. i hv not attended the clinic but if im nt wrong, its organized by ezzyoiler.. can PM him.. :)
i personally love to mess around wif my bike and DIY myself.. more fun way to learn abt my bike.. dun be scared to do so! u will learn alot and can easily rectify most issues in d future urself..
Hey guys,
After a few days of riding my EO level dropped quite a fair bit (from max level down to half level on dip stick) and white smoke still present (very smelly too, lol). Also met up with ezzyoiler yesterday (got to install his raved oiler, very nice..) and had a chat, got a lot of tips from him.. He also advised to replace the rings.. Thus, went over to Ah Koon (since nearby to office) and booked for an overhaul, which he can only do late this week or early next week (he very busy).
In the meantime, is it safe to bring out the bike? I mean so long I keep topping up the EO to make sure it doesn't 'dry up'.. On average I'll be riding 40km++ per day..
Hey guys,
How many years COE left in your bike? Do consider whether its worth overhauling.
Actually slightly less than a year.. still thinking whether to top up the coe, coz i dont think i'll be upgrading to a bigger bike, and dont think I'm getting a newer bike either (dont want loan, plus next upgrade is car lorr).. Dont mind keeping this for later to play around and customise.. I mean, boys must have their toys..
look at your spark plug.
if the tip of the spark plug is white/clean, it's probably too lean.
if the tip is black with soot, its too rich.
perfect balance is the colour of teh tarik.
most likely you are running rich with the backfire popping.
roger that, thanks!
Hi guys, have some problem with my iu recently. IU always don't power up even with cash card in. Went 2 times to vicom n got my IU replaced. But after riding back hm, IU problem persist. I am suspecting that the connecting point on my bike may be faulty. Will be heading to bike shop to see if it's bike prob or IU. Been frustrating n hope that you experienced riders out there can assist. I'll keep you guys update if prob is fixed. Thanks!!
YAMAHA M1
just trace the IU cable to where it is tapped from.. mine is to the wiring harness on when u open the LHS chrome cover... just check the connection lar.. at least try rectify urself if its IU problem or purely poor workmanship wif d electricals..
last time i had this problem on my phantom. soon after, i had difficulty starting my bike. cause my starter motor was spoilt. went to planet motor to get my starter motor repaired for $60. then e iu problem went away also. what i observed is that the bike is grounded from the starter motor and iu connection was from the ground of the bike. so got issue when e starter motor was spoilt. :)
does phantom work better at a cooler temperature(such as at night) versus day time ? mine feels better and more responsive at night than in the day where there's a hot sun...@@
since our engine is air-cooled, its very dependant on ambient air temperature.. so, USUALLY a cooler engine runs better lar... in the cold morning mist even more shiok! normally cylinder heat temperature of my bike runs ard 180 degrees.. at nite, maybe abt 160-170... rain, below 100!
Hi, Recently started having a weird problem, few days ago, my low beam went out, so switched to high beam. All was fine. Next day, when I started the engine, the low beam worked fine. Then a few minutes later, it went out. Seems that the low beam works from cold start only. This is a new bulb.... any ideas?
when my fren had his problem, he went to planet. guess what ah chong did? he took a can of WD40, and SPAMMED it in the switch area. like really spam!!! haha! then ok liao. power right.
Solution: Its normal.
Turning the screw clockwise to enrich the mixture. (once again, tune in 1/4 or 1/2 turns of the air correction screw, located on the LEFT side of the carb)
Bike tends to rev rapidly but have poor acceleration if lean, and if too rich, will have "spongy" / slow throttle response at high speeds.
If in need of advise / demonstration sms pandora's kitten at 93270801 (advice/demo given is FOC)
Reason: Air leakages.
Reason: Air filter clogged.
Solution : Get your air filter changed. You are advised to inspect the air filter every 4000 or so kms and change it at 10k (Honda warranty service manual)
Solution 2: Buy a can of fix a flat from Carrefour or petrol stations, put it in your box.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution: If you have very poor acceleration when throttle is opened, you are running lean. Enrich mixture by 1/2 to 1 turn of the air correction screw.
Solution: If you are using spray on chain lube, dirt and grease may be thrown off the chain during normal operation. When a lot of grease accumulates on the chain tensioner (rubber cylinder) and swingarm protector (rubber bar) the chain will emit a loud sound as though running through sand. Scrape and wipe away the excess grease and enjoy the quietness.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution: Fuel/air mixture too lean giving poor acceleration and a hot engine
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Solution: Fuel-air mixture likely too rich. Backfires when throttle is closed, due to residual fuel afterburning in the exhaust header. This is bad for the valves and the catalytic converter.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Pandora's Kitten :3)
Solution: Gear box dying.
Solution: Engine is overheated. (Running too lean/ Not enough engine oil. An overheating engine may cause excessive oil consumption, especially when using less tolerant mineral oil)
Problem 27: Handlebar position is not centered (while riding). Handlebars are "straight" but wheel points to one side.
Solution: Lock the wheel, grab the handlebars firmly and twist the bars until straightened. The risers are flexible to some degree, due to the vibration damping rubber washers. (Demonstrated by Planet Motors)
Solution: If your steering lock is spoilt, put the wheel against a pillar or a wall.
Problem 28: Bike hard to U-turn. Riding position not comfortable as handlebars too high up.
Solution: Adjust the angle of the handlebars. Loosen the bottom two screws of the risers, pull back the bars so they "rise" towards your face. This will give you a more relaxed riding posture and you are able to enjoy a greater turning angle at low speeds. If your handlebars are set to rise straight upwards forcing you to stretch forward and upwards to steer, your elbows will prevent you from turning easily at low speeds.
Bro, WD40 is helping in the closing of electrical circuit. Meaning, it can conduct electricity, therefore it works, as long the WD 40 still be around. When it dries then... Er... probably back to square 1?
I guess d WD40 nt so much of a conductor.. it actly cleans d contact surfaces in d switches instead.. sumtyms dirt n rust might affect d contacts.. it saved several of my switches alr..
Sent from my HTC Desire S using Tapatalk
Dear people, awhile ago, i can still start the bike normally, but recently it can only be started by clutch in with start button. Anybody know what happen ? Spark plug is new btw.
wen u put it into neutral, is the neutral light on?
