I don't understand how EO will be used up. Isn't it supposed to have a very high boiling point so that it will not evaporate? If not the EO itself will ignite in the heat of the engine which would be very dangerous.
hey..EO do not burn...even in the the firing chamber...
the most likely reason why engine eat EO is leakages...
EO will get eaten by leaking engine ..small drips of EO found on engine or floor..leak through cylinder and out through the exhaust..
sometimes u even find EO increase in your engine...hahahaha:cheeky:
couldn figure out?....suggest u do a bit of research..u will be surprise..
Reason: Wheel/Rim alignment might have problem.
Solution: Bike shop, change front tyre and flatten rim.
Reason: Suspension too soft. Makes tiak tiak sound when depressed.
Solution: Refill of suspension oil.
I've encounter this problem few months ago. managed to get it solved today by changing ALL above mentioned solutions. Damaged is $330. :cry: and 4 hrs of repair time.
You go where to do wor?? Change all the above?? All spoil together?????!!?!?
hmmm.. its a possibility but its very small....
Free to help update the list? :cheeky:
Not all spoil together, but all is inter-link. If I rmb correctly, they told me is when your rim alignment is out, it stress your steering cone causing it to wear faster. With a damaged steering cone, it puts on pressure to your suspension and the tyre will take the rest of the impact after the suspension.
When you changed your front tyre, you know it's time to change your rear.. :cry:
Almost forgot, went to H L Cycle to change them. :)
Solution: Its normal.
Reason: Air leakages.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Solution: Retune the carb.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Problem 24: Where to get visor / assesories after 6.30pm.
Solution: Lim Ah Boy (Kelantan Lane around Jalan besar Hawker centre).
Problem 25: Can Phantom change headlights?
Reason: No reason in particular / cosmetics.
Solution: Yes. Can change and it all depends on your DIY / mech's skill.
Solution: http://www.pinkphantom.com - (Source to get nice headlights)
Solution: LAB - (Source to get nice headlights)
Problem 26: Can TA150 / TA200 use 92?
Solution: Yes. And i think it all boils down to personal preference but strictly no diesel hor....
my tyre kena nail, removed and repaired by planet for $5.
with a worm? thats only a temp solution. You might want to consider a new one after some time of it wearing out a lil more.
Your balloon has a hole in it, you use scotch tape to cover the hole. It will satisfy you for now but it will still leak and leak. Picture that ;]
it will last a long time..thats my experience with car tyre....at the end of day cannot remember it was wormed..
Hey guys, hope to get a second opinion from the "old-bird" phantom riders.
I'm a new rider on a Phantom TA200.
Encountering a cluttering sound from the engine area.
The noise only start when going faster, i.e. past 50km/h
No noise when idling or low throttle.
Problem only appear on Monday after going to Pl***t MotorCycle to:
1) Change Air Filter
2) Change spark plug
3) change O-ring
4) Chain tighten
5) other minor stuff, e.g. clutch cable adjust, IV bracket, brakepad, etc....
Chong test ride my bike, say its because my rear suspension is "illegal" one, too high. So after his mechanic tighten the chain, chain become too tight when I sit on the bike and cause that noise.
He did some chain adjustments for me, it now sound better, but the sound still appear when going at higher speed.
He tell me must change the suspension to original one then can solve the problem.
Hope to get second opinion from you guys.
Is it really a problem with the suspension and chain ?
How come I never have this sound before even though using the same suspension ?
Could this actually be Engine Knocking (Spark Knock) or Pre-ignition ?
Maybe because using of the new spark plug ? ($5 spark plug, cheap stuff...)
Dear all,
Have anyone experienced repetitive sqeaking sound coming from somewhere behind or in the middle of your bike while riding?
It seems to happen to me when i have a pillion. When i ride alone, it only happens sometimes, especially when i try to negotiate a corner.
Any idea what could be the problem?
Is it wheel bearings or wheel shaft.
My bike already 5yr old.
Dec 2003 - July 2010
Honda Phantom TA 200
July 2010 - July 2012
Honda Super Four Revo
July 2012 - Current
Honda NC700S ABS
3) change O-ring
4) Chain tighten
since you are new, have you tried oiling/lubricating your chain? Try with your engine NOT running, press/sit down on your seat and stand. Repeat that to confirm if sound is from suspension.
Dear all,
Might be rear wheel bearing if noise from rear. Or your suspension? Try and follow what I mentioned above to the other dude. :thumb:
3) change O-ring
4) Chain tighten
I would trust ah chong =)
Yeah i would trust Ah Chong too... dun think it is the plug.... i used their plugs, those $5 ones... so far so good also... go back and ask him again lor...
btw, which mech do for you ??
Dun know the name - The crew cut guy, quite tanned, look like in his 40s one...
Yeah, i went back to ah chong again today.
Been there 3 times this week, Mon + Tues + Today... :sian:
One of his mechanic tell me, "hey, how come i everyday see you here ?" :giddy:
(i was thinking, "of course bike got problem lor. if not what, think i got a crush on Ah Chong ah ? everyday come here and stalk him....":dot: )
anyways, got Ah Chong to test again. Re-describe the problem to him, turns out he was hearing a different sound from me when he told me it was a chain issue...
I was talking about a cluck-cluck knocking sound from the engine/front area, while he was hearing a tick-tick sound from the chain.
told him have to wack the engine harder to hear the sound...
so Chong went out and wack my phantom till 100+.
Now he tell me its my front suspension casing knocking against the fork. (previous owner installed a steel plating/casing around the front suspension.)
I kind of believe him... Maybe because when i wack the engine hard, there is more vibration, so the sound come out.
any other bro got similar steel casing around the front fork ?
any such problem ?
Ah chong say can remove the casing for $20 fee... but i kinda reluctant to remove, cos it looks so nice and shiny....
Any other solution ?
See if you can dampen the knocking lor... Stuff paper in the gaps? lol
any such problem ?
Answer to your first question is Silent Hunter.... he has some sort of casing too.... can check with him...
Answer to your 2nd question, since not much of a technical problem or whatsoever, live with the noise.
Cheers!!
It is quite chilly in these two days. My TA200 suddently become hard to start.
Now I need to hold the throttle for 1~2 minute to warm it up. Or by tuning the idle speed high.
My choke does not work. It is strange. The engine cannot keep runing if I pull the choke out. Had to increase the idle speed.
After running for 10 minutes, I have to tune the idle down.
Anyone got the same problem? The problem comes from spark plug? Or carb?
The pickup speed is still ok, similar to before.
TA200 now.
Just wanna highlight my case to some new pk's here;
To check regularly the wear n tear on ur front tyre according to manual. Cos steering cone replaced yest due to "below-limit" front tyre and of cos not to forget a new front tyre. So total damaged is $70 front tyre + $65 steering cone = $135. image top up another 15 can change both front n rear. So dun save abit n pay more like me... also, safety is an issue with botak tyres..o_O
