Just apply the force u use wen u brake hard. cux scared too much u might end up break d seal in ur master cylinder or caliper pistons and leaks.
hmm. i used a daiso reflective arm strap to tie down the thing to since the whole point is just to open the valve! after quite a bit of non stop pumpumping today the free play is sort of reduced already but not so satisfactory yet =X
Dont think so leh. It should still have some clearance but maybe tight clearance. You need to use really alot of brakes to trip down the excess. Mine also sometimes the pad touches the disc. Ask mech to check, he spins the wheel, wheel moves fast and freely. So dont know whats going on also XD
mine doesnt spin much, need mild effort to roll it with the disc rubbing on the pad. the caliper is hot and disc is hot after riding!
perhaps its still new and i have to go back one week later anyway for the next round of checking..
just be careful for the next few days as the new pad starts to get seasoned to the disc. to get it to optimum i tink will need a few weeks at least, esp if ur disc has grooves and not even. for now just brake more gently and gradually. :)
hope that at least by 2mr ur brake lever gets abit more solid.
i certainly hope so! i guess the rain next few days will affect braking anyway so gotta be more careful then!
top overhauled my bike 6 months ago. ytd while riding at expressway, suddenly bike loses power but still able to move. next morning on engine got knocking sound. bring to shop and they say piston must change. twice within 6 months? is it possible. engine oil change regularly every 2000km. any advice?
Ask around for advice. Once i also same as you. On highway engine loses power and eventually dies if i low trottle. Its either my earth cable spoilt thats causing the prob(which also prevented my from starting the bike) or a rusty tank choking the fuel filter. Both happened at the same time. Engine knocking sounds abit like fuel air mixture problem. If piston spoilt it should sound loud. Might be your ignition timing off? Timing off can cause knocking also.
2A - On going...
I went 2 different shops both say the same thing. But bike feels normaly when travelling 80km/h. Only at low speed then noisy and when throttle the bike vibrte damn jialat.
Cause change piston they earn $$ mah haha. Try looking at your EO level. Generally spoilt piston have an impact on your EO. But i got a feeling is your bearings man. But i cant determine much. Seems serious. Like mine i got bearing issues, not engine, either wheels or some others. Sometimes got serious vibration sometimes no. When clutch in can hear some bearing is crunching but no idea where.
2A - On going...
Great! :) dont go do endo ah! Haha!
ill endo only when i want to =DDDD not by mistake!
sounds like fuel/air issue to me too. i suggest going to a reputable mechanic for 3rd opinion at least cos 2 overhauls in half a year is madness unless u have screwed the engine during the break in period.. when u open throttle it vibrate how prolonged is the vibration and how smooth or sudden u open the throttle?
unless the installation workmanship was bad? but in this case, since the bike can still run, go to a reputable mech like planet. like the other guys mentioned, could also be ur fuel delivery problem. maybe carb problem or rusty stuff getting into your engine. always start with the cheapest possible fixes. :) bikeshops on the other hand do the opposite: start with most expensive fix. by the time they fix the actual problem, they would have sucked ur pocket dry.
Went to planet and ah koon at lengkuk bahru. Both say the same thing. Going planets now to get it done.
dats sucks to here bro. well i guess u just have to sort it out lor. no choice. where did u do the previous overhaul? im curious abt the workmanship.
Pm-ed you already.
Hey guys, just got my phantom recently and realised that the gear changing is still noticeably rougher compared to my SP. I have just changed my EO to pennzoil fully-synthetic and it didn't seem to make much of a difference. Could my gearbox be worn out? :faint:
Class 3 02/06/2011
Class 2B 13/06/2012
NSR150SP FBD2**G June 2012 - October 2012
Phantom TA200 FW6**6A October 2012 -
sorry to hear bro =X meanwhile after the overhaul ah chong would probably show u every part he take out from the engine that is replaced for you to see. from there you will probably better assess the damage.
just my 5 cents.. ta200 i think the shifting is always that rough one.. as compared to the cb125e i was using at bbdc.. after some time after all the coordination play with the throttle closing and clutching in at the same timei found the shifting more smooth so its more of a timing issue.. maybe try varying your shifting pattern and kiv?
Just sharing I use semi 20W/50 EO easy to kick to natural gear but when use Fully Syn is depend on luck have to kick few time.
And my bike must top up 1.1L if not the engine very hot.
Remember Phantom is air cool not water cool EO you use play a important part and hopefully not ur gearbox fail.
http://tripdrive.blogspot.sg
Thanks for the tips guys, will try the Belray Thumper semi-syn next time to see if got any improvements.
Class 3 02/06/2011
Class 2B 13/06/2012
Solution: Its normal.
Turning the screw clockwise to enrich the mixture. (once again, tune in 1/4 or 1/2 turns of the air correction screw, located on the LEFT side of the carb)
Bike tends to rev rapidly but have poor acceleration if lean, and if too rich, will have "spongy" / slow throttle response at high speeds.
If in need of advise / demonstration sms pandora's kitten at 93270801 (advice/demo given is FOC)
Reason: Air leakages.
Reason: Air filter clogged.
Solution : Get your air filter changed. You are advised to inspect the air filter every 4000 or so kms and change it at 10k (Honda warranty service manual)
Solution 2: Buy a can of fix a flat from Carrefour or petrol stations, put it in your box.
Reason: Fuse may be blown.
Reason: Bike is in gear, kill switch is on, no petrol, petcock off.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution: If you have very poor acceleration when throttle is opened, you are running lean. Enrich mixture by 1/2 to 1 turn of the air correction screw.
Solution: If you are using spray on chain lube, dirt and grease may be thrown off the chain during normal operation. When a lot of grease accumulates on the chain tensioner (rubber cylinder) and swingarm protector (rubber bar) the chain will emit a loud sound as though running through sand. Scrape and wipe away the excess grease and enjoy the quietness.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution: Fuel/air mixture too lean giving poor acceleration and a hot engine
Reason: Your brake is dragging
Solution: Check wheel spin, check the brake pads if its time to replace, check if brake caliper mounted properly, check disc rotor warped or not
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Solution: Fuel-air mixture likely too rich. Backfires when throttle is closed, due to residual fuel afterburning in the exhaust header. This is bad for the valves and the catalytic converter.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Pandora's Kitten :3)
Solution: Gear box dying.
Solution: Engine is overheated. (Running too lean/ Not enough engine oil. An overheating engine may cause excessive oil consumption, especially when using less tolerant mineral oil)
Solution: If cannot find neutral when engine is hot but fine when engine is cold, that means engine oil has degraded and cannot maintain its viscosity at high temperatures. Changing engine oil should solve the issue.
Problem 27: Handlebar position is not centered (while riding). Handlebars are "straight" but wheel points to one side.
Solution: Lock the wheel, grab the handlebars firmly and twist the bars until straightened. The risers are flexible to some degree, due to the vibration damping rubber washers. (Demonstrated by Planet Motors)
Solution: If your steering lock is spoilt, put the wheel against a pillar or a wall.
Problem 28: Bike hard to U-turn. Riding position not comfortable as handlebars too high up.
Solution: Adjust the angle of the handlebars. Loosen the bottom two screws of the risers, pull back the bars so they "rise" towards your face. This will give you a more relaxed riding posture and you are able to enjoy a greater turning angle at low speeds. If your handlebars are set to rise straight upwards forcing you to stretch forward and upwards to steer, your elbows will prevent you from turning easily at low speeds
Problem 29: Engine oil disappears at a fast rate
Reason: Piston ring busted.
Solution: See mechanic. Top overhaul probably needed.
Problem 30: Side stand broke off with mounting lug.
Solution: Get a mechanic to weld the mounting back.
prepost and update if needed! =D
My bike couldn't start after I parked it there for a few minutes. The electrical system was entirely dead even though it was performing perfectly normal earlier on. My battery is still running strong. Anyone knows what's wrong? :\
Class 3 02/06/2011
Class 2B 13/06/2012
Check the fuse. I encountered b4. Very irritating problem!
5 Oct 2005 - Jun 2007(SP) FS6059X
18 Jun 2007 - 26 Nov 2007 -> CBR400, L model problematic FJ532*S
26 Nov 2007 - 12 Nov 2011 -> TA200, FV2X2G
12 Nov 2011 - 12 Nov 2012 -> SYM GTS200, FZ99*0D
29 Nov 2012 - 13 July 2015 -> KIA Rio HB 1.4M, SFY*
13 Jul 2015 - 28 Apr 2018 -> Kia Cerato V2 SKT*
28 Apr 2018 till current -> Hyundai Elentra S_trim SLZ*
Sounds similar to Spark_135's problem? That time his grounding got problem screw up his electricals.
