guys i need help... if engine got something like ball bearing lose sound is it spoil... checked is coming from engine i think... around rpm5 to 6 the sound will be noticeable... like the metal ball hitting sound tek tek tek tek tek.... when i engine brake then the sound will come... any idea? engine bearing? or the piston bearing? or the clutch? btw my spark plug also 5 month never change... how about my valve? is it that.... 1.5yrs never change for the clutch... btw the bike is able to reach 11.5 rpm.... but when rpm5 to 6 there like jerking... wonding is the bearing spoil? but if bearing spoil how to reach high rpm... sure jam right??? btw i riding a KR150....
Edited by Xenox
http://img230.imageshack.us/img230/7937/bleachswimsuitci9ga7.png
Kawasaki KRR150
  • Replies 11
bro, i tot we mentioned to you that it might be your kick start as it happens to one of the KR riders as well.. If it's not.. Most likely is engine bearings.. if engine bearings have to overhaul... it means that you MIGHT not be riding your bike good enough or wack too much... Else, meet up on sat and we will check for you lor... :)
eh.. why my pipe got kring2 sound ah?? can help check also? and sumtimes sound go bom bom bom...
just asking around only... but i feel is like the valve cleanreaen thing leh...
Kawasaki KRR150
lolx.. bring down to the outing... We will clean your valve and you will see if it's better?... :angel:
This is really new to me.
KR150RR got valves and valve clearance issues?
Exhaust reed valve I believe... but that one when sticky due to carbon buildup causes only poor performance at high rpms.
Knocking sounds from a 2 stroke engine can only mean worn con rod bearings.
Kr use reed valve??? i see is like gear teeth like that de... i'm not sure wat that call...
Kawasaki KRR150
  • 2 years later...
