Hi,
Do you have the brembo 19 RCS Radial Brake master cylinder AND 16 RCS Clutch Master Cylinder for X1-R? May I have the pricing pls.
If I am to fix both as a package, pls quote me the best price :thumb:
Thanks
You have a PM.
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
  • Replies 272
the braking power really greatly increase since changing to the 16mm master cylinder for my honda sp150! thanks unique!!!
http://2.bp.blogspot.com/_KuAxfEWkyMo/SROeAbl3osI/AAAAAAAAAoY/r3J0m9qDzZA/s320/stoppieKiss.jpg
Thank you for your support and feedback!
Best Regards
Kelvin 87178999
WL: Zul 84818999
How much for 19RCS with lever? How much for the clutch to make it a pair? In Total.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  • 5 weeks later...
Any deal on 19RCS brake and 16RCS clutch masters only (no reservior nor fluids needed)? cash and carry. thx.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi Bro, you got carry KOSO Meter for SP? Please PM me, thanks!
You have a PM
Best Regards
Kelvin 87178999
WL: Zul 84818999
hi. Brembo 19 RCS Radial Brake Master Cylinder - High Performance Brake Systems,Brembo 16 RCS Radial Brake Master Cylinder - High Performance Brake Systems or Brembo 15 RCS Radial Brake Master Cylinder - High Performance Brake Systems, which is more suitable for super4 spec 1?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
What do you recommend for yamaha FZ1N? 19/ 16/ 15 RCS? What are the differences between these 3? Thanks.
It's not how fast you ride, but how well you ride.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi Kelvin, I would like to know the difference btw RCS 15 and 19? And will the 15' master pump alone fit my ktm smc 690 2010 since already comes with brembo brake set. And can kindly quote me the price. Thanks..
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://i450.photobucket.com/albums/qq228/uniquemotor/brembo5.jpg
Brembo showcased the new 19 RCS, an update of the legendary product with a number of significant engineering features, all derived from MotoGP. The most unique feature of the Brembo 19 RCS (Ratio Click System) radial brake master cylinder is a patented device that allows the rider to choose between two settings, 18 or 20 mm, to improve either modulation or response during braking. Previously unavailable, this feature now provides a very simple adjustment that will give the optimum feel between rider, riding style, bike and circuit.
$550 BREMBO RCS19 PACKAGE:
- Brembo 19 RCS Radial Brake Master Cylinder
- Dot 4.0 Brake Fluid
- Brake Reservoir
- Installation of Brembo 19 RCS Brake Master Cylinder and Brake Reservoir
Brembo 16 RCS Clutch Master Cylinder -
http://i562.photobucket.com/albums/ss69/uniquemotor2/brembo9.jpg
The 16RCS clutch master cylinder makes up a set with the 19RCS. The 16RCS is equipped similarly with the Ratio Click System, allowing adjustment of the feel on clutch control. Like the 19RCS brake master cylinder, this component has a forged-aluminum alloy body with hard-anodized surface finish.
$550 BREMBO RCS16 PACKAGE:
- Brembo 16 RCS Radial Brake Master Cylinder
- Brake Reservoir
- Installation of Brembo 16 RCS Brake Master Cylinder and Brake Reservoir
Intended specifically for Naked and SuperMotard machines, the 15RCS master cylinder has all the technological features of the 19RCS - the M/C most popular with enthusiast - namely the Ratio Click System, the same component specifications as for MotoGP system, hard-anodized cylinder body, and folding lever. With the 15RCS, the user can change the lever pivot distance from 18mm to 20mm simply by turning the adjuster inside the cylinder. This brake M/C can be matched with the 16RCS clutch master cylinder, giving a set-up that will deliver MotoGP performance, as well as being a real attention-grabber.
$550 BREMBO RCS15 PACKAGE:
- Brembo 15 RCS Radial Brake Master Cylinder
- Brake Reservoir
- Installation of Brembo 15 RCS Brake Master Cylinder and Brake Reservoir
Please refer to 1st post for updated pricing. Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
- Brake Reservoir
- Brake Reservoir
- Brake Reservoir
Best Regards
Kelvin 87178999
WL: Zul 84818999
bro do u hav the 19x20 forged? hw much and also do this include the brake switch?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
You have a PM.
can pm me about the price for both types too?
2006 - 2009 Super 4 spec II (FV **43 first ride)
2009 - 2010(jan) FZ1 08 (FBD3***)
2010 - 2013 Hayabusa 06 (FBA****)
2013 - ???? Tmax 2013 (FBH****)
http://i97.photobucket.com/albums/l212/shadowles85/sign1.jpg
Only Brembo RCS19 in stock. $550 with installation. Freebies for the month of Feb 2011. Please check with our staff at any of our workshops. Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
do u hav brake caliper for super 4 spec 3????
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
any offer deal for brembo rcs 19 ?
龙飞凤舞振家声 招牌一出天下å“
8th may 2008
thkz number 89!!!
Honda Sp 150508 - 060609
Honda NC 35 RVF 160509 - 111009
Honda CB 400 Super 4 Vtec 2 260909 - 230610
MRT BUS TAXI 230610 - 140610
Honda NC 35 RVF 140610 - ???
Boom Boom Boom!!
Yes! Do check with my staff at any of our workshops for bundle deal for Brembo RCS19. Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
