http://a8.sphotos.ak.fbcdn.net/hphotos-ak-snc7/302981_10150287858197106_160394947105_8052862_512160238_n.jpg
Brembo Upgrade Kit:
Brembo 19RCS $550.00
Brembo 16RCS $550.00
Brembo M4 Monoblock $1600.00
Brembo T-Drive Floating Disc $1200.00
Brembo Folding Clutch Lever $295.00
Brembo M4 Monoblock Calipers Kit $1600.00
http://i600.photobucket.com/albums/tt84/uniquemotor4/Brembo_220A39710.jpg
Until now MONOBLOC calipers had been realized for a Super Racing use: the manufacture with particular material and in limited batches implied such a price which deterred the usage of this technology for calipers to be fitted on normal supersport bikes.
Brembo, through a relevant engineering work, succeeded in producing a monobloc caliper at an interesting price but keeping very high technology.
The structural design, of course radial, is MONOBLOC type as already said. Of course a real monobloc, like those used in MotoGP and SBK from the majority of the riders, that is to say without the lateral caps which hold the pistons. Brembo, unequalled in the world, developed this technology so as to assure unique stiffness and working precision.
TECHNICAL INFO: Fixing hole distance 108 mm and Off-set = 22,5 (perfectly interchangeable with the radial calipers of Japanese supersports, for some model spacers are required), 4 pistons Ø 34mm, 2 high performance brake pads,pads anti-vibrating springs,double piston seals, red Brembo logo, hand painted, identifying a Racing products
This kit fits the following with*OE sized brake rotors:
Honda CBR1000RR 2006-2011 (320mm)
Honda CBR1000RR 2009-2011 ABS (320mm)
Kawasaki ZX6R 2005-2011 (300mm)
Kawasaki ZX10R 2004-2007 (300mm)
Suzuki GSXR600 2004-2005 (300mm)
Suzuki GSXR750 2004-2005 (300mm)
Suzuki GSXR1000 2003-2001 (300mm)
This kit fits the following models with*Oversized brake rotors:
Honda CBR600RR 2005-2001 (320mm), OE size is 310mm
Honda CBR600RR 2011 ABS (320mm), OE size is 310mm
Honda CBR1000RR 2004-2005 (320mm), OE size is 310mm
Honda CB1000R 2008-2011 (320mm), OE size is 310mm
Kawasaki ZX6R / 636 / RR 2003-2004 (300mm), OE size is 280mm
Brembo HPK "T Drive" Floating Disc Kit $1200.00
http://i600.photobucket.com/albums/tt84/uniquemotor4/Brembo_TDRIVE.jpg
A product of experience acquired in SBK and MotoGP, the brand new T-Drive is the next generation of product reflecting the natural evolution of Brembo brake discs engineered for competition use.
The key feature of the new T-drive system is an innovative method of transferring brake torque from disc to wheel, in which the conventional system of cylindrical bobbins are replaced by a set of eight “T” pins on the disc and eight corresponding segments formed in the disc carrier.
The special shape of the pins was developed following a targeted study of machining tolerances and ensures braking torque can be transmitted more efficiently, by offering increased resistance to thermal and mechanical stresses, especially under extreme operations such as those encountered in competition.
The connection between disc and carrier is assured by a special guillotine type interface (patent applied for), which allows both radial and axial float, as well as reducing the overall weight of the disc. This brings considerable advantages in terms of enhanced rideability, when compared with the conventional disc-carrier interface using round bobbins.
Brembo 19 RCS Radial Brake Master Cylinder - High Performance Brake Systems $550.00
http://i450.photobucket.com/albums/qq228/uniquemotor/brembo5.jpg
Brembo showcased the new 19 RCS, an update of the legendary product with a number of significant engineering features, all derived from MotoGP. The most unique feature of the Brembo 19 RCS (Ratio Click System) radial brake master cylinder is a patented device that allows the rider to choose between two settings, 18 or 20 mm, to improve either modulation or response during braking. Previously unavailable, this feature now provides a very simple adjustment that will give the optimum feel between rider, riding style, bike and circuit.
Brembo 16 RCS Clutch Master Cylinder - High Performance Brake Systems $550.00
http://i562.photobucket.com/albums/ss69/uniquemotor2/brembo9.jpg
The 16RCS clutch master cylinder makes up a set with the 19RCS. The 16RCS is equipped similarly with the Ratio Click System, allowing adjustment of the feel on clutch control. Like the 19RCS brake master cylinder, this component has a forged-aluminum alloy body with hard-anodized surface finish.
Brembo 15 RCS Radial Brake Master Cylinder - High Performance Brake Systems $550.00
Intended specifically for Naked and SuperMotard machines, the 15RCS master cylinder has all the technological features of the 19RCS - the M/C most popular with enthusiast - namely the Ratio Click System, the same component specifications as for MotoGP system, hard-anodized cylinder body, and folding lever. With the 15RCS, the user can change the lever pivot distance from 18mm to 20mm simply by turning the adjuster inside the cylinder. This brake M/C can be matched with the 16RCS clutch master cylinder, giving a set-up that will deliver MotoGP performance, as well as being a real attention-grabber.
Brembo 16mm Master Pump + Clutch Assembly Package: $388.00
Brembo 16mm Master Cylinder Assembly: $288.00
Clutch Assembly Package: $128.00
http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs517.ash1/30469_405181132105_160394947105_4555925_4772397_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs557.snc3/30469_405181137105_160394947105_4555926_3878478_n.jpg
$699 Brembo & ASV Package (UP $790)
- Brembo RCS 19 Brake Master Cylinder
- ASV F3 Unbreakable Clutch Lever (3 years warranty)
- Evotech RT-01 Brake Fluid Reservoir
- Dot 4 brake fluid
- Installation
$599 Brembo & ASV Package (UP $718)
- Brembo 16mm Brake Master Cylinder
- ASV F3 Unbreakable Brake Lever (3 years warranty)
- Clutch Lever holder
- Dot 4 brake fluid
- Installation
$399 Brembo & ASV Package (UP $483)
- Mini Brake Fluid Reservoir
- Dot 4 brake fluid
- Installation
http://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/308421_10150286896292106_160394947105_8048462_404677590_n.jpg
Suzuki DRZ400SM Brembo Upgrade Kit
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/311157_10150287938762106_160394947105_8053212_1802614911_n.jpg
Brembo Upgrade Kit
Brembo 19RCS : $550.00
Brembo 4 Piston Calipers + Caliper Brackets Kit $888.00 (Front Calipers)
*Please check 1st post of this thread for latest updated pricing. Thank you.
Edited by Unique_Motorsports
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
  • Replies 272
Best Regards
Kelvin 87178999
WL: Zul 84818999
Bro, just asking only can this fix on Spec 3????
Yamaha RXZ a.k.a Nadia> FBB3608T - 14 March 2007 to 11 July 2008
Honda CB400 Spec 3 a.k.a Lisa> FBC7988P - 11 July 2008 to 24 June 2009
Yamaha RXZ a.k.a Qistina> FBD6886B - 25 June 2009 to 29 April 2010
Suzuki Hayabusa a.k.a Rachel> 29 April 2010 to 23 April 2011
Suzuki GSXR 1000 a.k.a Suzy> FR**H - 23 April 2011(CURRENT RIDE)
Yes, can be installed on spec 3.
Best Regards
Kelvin 87178999
WL: Zul 84818999
$550 BREMBO RCS19 PACKAGE:
- Brembo 19 RCS Radial Brake Master Cylinder
- Dot 4.0 Brake Fluid
- Brake Reservoir
- Installation of Brembo 19 RCS Brake Master Cylinder and Brake Reservoir
$550 BREMBO RCS16 PACKAGE:
- Brembo 16 RCS Radial Brake Master Cylinder
- Brake Reservoir
- Installation of Brembo 16 RCS Brake Master Cylinder and Brake Reservoir
$550 BREMBO RCS15 PACKAGE:
- Brembo 15 RCS Radial Brake Master Cylinder
- Brake Reservoir
- Installation of Brembo 15 RCS Brake Master Cylinder and Brake Reservoir
Please refer to 1st post for updated pricing. Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Please refer to 1st post for latest updates. Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Brembo Cast 4 Pad Radial Mount Caliper for Suzuki DRZ400SM
http://i450.photobucket.com/albums/qq228/uniquemotor/motostrano_2039_37151686.jpg
$650 PACKAGE:
- Brembo Cast 4 Pad Radial Mount Caliper
- Brembo Brake Pads
- Caliper Relocator
- Motul 5.1 Brake Fluid
- Installation of Brembo Cast 4 Pad Radial Mount Caliper
Bro Kelvin good day, do u hv a package if i take both the brembo caliper n master cyclinder... Do u hv stock in store and how long does the installation take? Btw the caliper comes in only one colour, the sliver with red brembo wordings? Dis package don't include rotors? U can pm me or juz sms me at 98243635 for the pricing and my questions..... Can i go either branch?
http://i95.photobucket.com/albums/l144/velyntusa/DSC_1045-1-1.jpghttp://i95.photobucket.com/albums/l144/velyntusa/DSC_1010-1-1.jpg
1995-2009 KTM620, Suzuki 750, Suzuki TL1000R, Suzuki K2, Africa Twin 750, Honda GoldWing, Honda BlackBird, Mitsubishi Colt 1.6, Honda XR250, KTM 250, BMW 320i, Kawasaki Ninja 900, Honda CBR954RR, Subaru WRX/Sti, Gilera, Suzuki DRZ K8.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
does it feel much stiffer than the stock one when depressed the lever?
shouldn't it be the more stiff the braking level, the lesser force we have to pull in order for max. braking on the rotors?
It's a 4pot brake and upgraded to 320mm rotor instead of OEM 2pot and 310mm rotor.
braking is definately less effort.
Hmmm i like, good stuff..... Will talk to Kelvin soon...
brembo brakes are the best.. i cant live w/o it.. i feel it's a must for all bikes to have..
why?
eg: from 120km - 0km/h (fully stop)
on ur stock brake setting it might take a distance of 180m to stop? (just an example ah..)
after u switch to brembo master pump ALONE(just the pump only.. haven upgrade caliper)
your stopping distance can reduce to about 150m or 120m..
tats y i love it.. it saves life and it gives good stopping distance
Lousy Noob Rider
i've tried it before.. totally different feeling..
it really bites!!
Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
BRAKING BRAKE DISC + BREMBO CALIPER
http://i450.photobucket.com/albums/qq228/uniquemotor/DSC00036.jpg
DRIVEN BLACK SPROCKET + EK RED COLOUR X RING CHAIN
http://i450.photobucket.com/albums/qq228/uniquemotor/DSC00037.jpg
http://i450.photobucket.com/albums/qq228/uniquemotor/DSC00038.jpg
Best Regards
Kelvin 87178999
WL: Zul 84818999
just bought the 19rcs from him on tuesday. good offer. kelvin ,keep up the excellent service. cheers !!!
2000-2001 :Aprilia rs 125 (FT3988D)
2001-current : Rvf Rossi NC 35 (F*46*)
Thank you for your support and feedback.
Best Regards
Kelvin 87178999
WL: Zul 84818999
$550 PACKAGE:
- Brake Reservoir
Best Regards
Kelvin 87178999
WL: Zul 84818999
suitable for S4?
Yup. Brembo 19 RCS can be fixed on S4.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Can the Brembo 19 RCS, disc, caliper, sprocket and chain be installed on FZ6S2?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
What bikes can fix and use this, besides s4, any cl 2 bikes?
PM me pls. thanks.
It is suitable for most bikes.
Best Regards
Kelvin 87178999
WL: Zul 84818999
