Can anybody pls tell me how much would it cost for me to change the battery on my Yamaha FZ1, i went to 2 bike shops yesterday and they both qouted me $190....its like the same cost as a car battery.....:cry:
2003-2006 Honda NSR SP 150
2006-2008 Suzuki GSX-R 600 K5
2008-2010 Yamaha FZ1-N
2010-20?? Yamaha YBR 125
2011-20?? Suzuki GSX-R 1000 K7
  • Replies 25
Ya, tats roughly the market price , or u can get compatible batt from regina , less than $100.
In any case , fully charge ur batt b4 using .
GIVI Touring windscreen for FZ1 2006 onwards for sale - $90
http://www.koolart-japan.com/images/small/P1246.jpghttp://www.koolart-japan.com/images/small/P1721.jpg
Yusa for FZ1 Gen 2, $140-$150 @ Regina.
Saw a fellow FZ1 who bought his there ytd.
LEAF departure is B`cos of WIND pursit or TREE didn't ask her to stay?
U YEARN for wat u FANTASIZE den 2 realise who U should TREASURE...
å¶çš„离去是因为风的追足还是树没有挽留
你期望你所è¦å¾—, 但崿²¡æœ‰å‘çŽ°åˆ°ä½ æ‰€çœŸæ­£çæƒœçš„
http://www.comp.nus.edu.sg/~limtianc/achew_sig.gif
Try Lab......
http://img256.imageshack.us/img256/8610/photo440f.jpg
http://img139.imageshack.us/img139/1641/photo459.jpg
WTB: Wave 125 NF125MD coverset/ speedometer sensor . Let me know the details, Thanks
Wat type of batt is sold ? The wet or dry cell type ?
i got a dry cell batt, maintainance free, but i shouldn't have change it coz i read the manual saying that the batt can be charged when it loses current...HiaZ....
Bro try republic motor. i got mine changed last week for less than $100. He even told me that if it gives probs in the next 3 mths, he'll change it.
Hi there,
just be happy tat it costs tat much. I was quoted, S$295 in Hong Leong(Yamaha agent) n S$250-S$265 in most bike shops. I would change it if I was u. Btw, mine is an '05 carb model. So do not contemplate and JUST CHANGE IT IF IT DEEMS RIGHT!!! :cheers:
HL is even more expensive than others...when do we need to ruffly change the battery after first purchase of bike?...gauging by a yr of usage wud be good?
Dec 2002- March 2004 Phantom 200 '02
March 2004- March 2006 Super 4 Vtec | '04
March 2006- Oct 2007 Fazer 6 '05
Oct 2007- Feb 2009 Super 4 Vtec ||| '06
Feb 2009- now FZ1S '09
It Came. I Am Fazer-ed !!
:cheers::cheers:
Healthier Lifestyle, Healthier You.
just changed mine last mth... cost me $60....hehehe... i use S4 battery...
gd luck to u bro, mi last time also using tat, end up the damage the alternator, total cost for damage $320- alternator and another original batt $180
cos our alternator will be charging more than the S4 batt, S4 batt only 9-12v, our FZ1 is 14v
http://209.85.117.195/10250/106/0/e5401/e5401.gif http://209.85.117.195/10250/106/0/e5401/e5401.gif http://209.85.117.195/10250/106/0/e5401/e5401.gif
http://i257.photobucket.com/albums/hh238/The_One_Biker/SBF-siggy.jpg?t=1228649487
OEM batt's price cost about there...but if u decided to get another option..maybe u can try LAB they got 2 kind ($85 and $150) the $150 is those kind that you pour powder into chemical..and $80 one is pouring liquid into chemical,i am using the $80 one...average usage is 1 - 1.3 years..
-Best to charge it 1 hour before fixing onto your bike.
hmm.. i thought its standard 12V..
Alamak, a lot of misunderstanding in this thread. I think what Katana meant was that S4 battery is of lower 'power capacity' probably about 9-10 amps, while the FZ1 battery is of higher 'power capacity', 11.2 amps to be exact. While both are 12v, the FZ1 engine charging may be too high for the S4 battery.....funny things may happen. The battery, lying sideways, may get too hot from overcharging and the lead plates in the battery may 'weaken' and touch each other. If the positive plate and the negative plate touch each other, all hell break loose. There will be a short circuit and the rectifier and alternator may be affected/short circuited and so kaput!
Lab's $85 battery (10.8 amps?) is the normal sulphuric acid maintenance-free battery. You have to pour the acid into the 6 holes, plug in the cover and then use it. So far Racingter has been using this battery without any problem. The FZ1 original Yuasa YTZ 14S battery, some say gel, some say suphuric acid type, is prepared in the factory and sealed up there. It is completely sealed up, with no holes to pour acid into. It is a very high cranking 230? CCA battery. Hence it is expensive.
Although the FZ1 battery is meant to be expensive since it is such a 'good and powerful' battery, some of the shops here are over charging........... So now for the good news. If you fellas intend to buy this battery, one good source is to buy one from the Yuasa office (pls check phone directory for address) in Jurong. Someone has bought it there and the price is so much cheaper (20 to 30%) than Hong Leong, Regina or any bike shop.
So, let's hope my simple kaypo explanation clarifies everything. :angel:
http://i289.photobucket.com/albums/ll201/bikeyroo/Signature%20dog/cute-moving-puppy.gif
http://www.valkyrieforum.com/forum/smileImages/animated/a18.gif my exact sentiment. While the intention to share tech info is gd, BUT the fact have to be correct first; this is basic :angel:
thanks for the post.. definitely learnt something from it.
PS: i THINK super4 stock battery is 7 amp.
actually super 4 uses ytx9-bs which is 8Ah
My Rides
Dec 2006 -Aug 2008 : kawasaki krr150
Aug 2008: Honda CB400 Super 4 Spec 1
27-29 JUNE 2009 - Hatyai (Thailand)
14-17 NOV 2009 - KL/Fraser Hill/Malacca
ya...well said.
Check ard for options, especially when the battery is not placed vertical in the compartment.
Main issue would also be to ensure that lead acid batteries are left to activate after adding in the acid, then charged up before using.
Check Yuasa website for battery activation instructions or guides...
wrong
all model of spec got some variant of the battery
spec 3 uses 10
http://images.quizesilver.multiply.com/image/8/photos/19/500x500/1/Picture3.jpg?et=pp72A3vHiyWV%2B1gmEDuh4g&nmid=137248738
