how much additional cost i have to pay to upgrade to iridium spark plug?
You have a PM.
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
  • Replies 318
ThumperTalk Manual Cam Chain Tensioner (Suzuki DRZ400SM & Hayabusa 1300)
http://i600.photobucket.com/albums/tt84/uniquemotor4/ENG_TT_MCCT1-2.jpg
Save yourself thousands in costly repairs! ThumperTalk Manual Cam Chain Tensioners (MCCT) are designed to replace the automatic and hydraulic tensioners found on today's hi-performance 4-stroke engines.
Factory automatic adjusters can back out when the throttle is suddenly closed at higher rpms. This allows the cams to momentarily go out of time and can result in bent valves and/or serious engine damage! Hydraulic tensioners have a tendency to put too much tension on the chain guide under high rpm/high oil pressure conditions, resulting in premature cam chain wear.
Installation of a ThumperTalk Manual Cam Chain Tensioner will allow you to maintain the proper, constant cam chain tension necessary for reliable hi-performance riding and it will not backout.
This is a high quality product, proudly made in the USA. There are thousands of these units in service, so buy in confidence!
- Precision machined billet aluminum body
- O-ring seals, both on the body and threads
- Stainless steel adjuster bolt & locknut
- Clear anodized body for long lasting good looks
Pricing: $95 with installation
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://i600.photobucket.com/albums/tt84/uniquemotor4/DSC00215-1.jpg
Samco Hoses for Suzuki DRZ400SM
- Blue
- Red
- Green
- Yellow
*while stock last.
Best Regards
Kelvin 87178999
WL: Zul 84818999
hi boss,
do you have stock for drz sprockets ??
im looking for 16/41 or 16/39.
pm me the price pls.
thanks
SH*T HAPPENS!
Pick It Up. Start It. Ride It.
picasaweb.google.com/nineh20
hi boss,
thanks
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
had my tyres, engine oil, oil filter n plugs changed at unique just now.WONDERFUL service.thanks alex!
june 06 - march 09 - wr2(motard)
march 09 - apr 14 - DRZ
july 11 - aug 12 - HD iron883
july 12 - mar 13 - KTM690smr
oct 13 - feb 15 - waveS
aug 14 - feb 15 - KTM990ADV
feb 15 - sept 15 - Vespa Primavera
sep 15 - current - NC750XA
Thank you for your support and feedback.
Best Regards
Kelvin 87178999
WL: Zul 84818999
how much is it if i were to do a jd jetting, change clutch cable, change belray thumper eo and oil filter? thanks.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
James Dean (JD) Jetting - Your source for high performance jet kits
http://i785.photobucket.com/albums/yy135/uniquemotor3/jdjetting_wht.gif
JDS005 - Suzuki DRZ400S/SM(all), DRZ400E (Calif) (00-09) and Kawasaki KLX400SR (03-04) #53
$160 - Cash & carry
$180 - With installation
http://i785.photobucket.com/albums/yy135/uniquemotor3/Im000535_T.jpg
James Dean designed the JDJetting kits so that you don't have to be an expert to get professional high performance results!! Even better, technical support is provided.
The James Dean custom jetting kit is designed to improve throttle response throughout the range by using specially made multi-taper needles. These are based on the most popular settings used by new generation MX and off-road riders around the globe and the results are impressive.
Exceeds the performance of the popular EMN, DTM, and other standard factory needle options
Low and High altitude custom designed triple taper needles
Main Jets included
Spare Needle Clip
Dyno Tested
Developed and tested from sea level to 12000ft elevation
You can’t buy this from any OEM factory or aftermarket. It’s JD’s prescription for the headpipe blues.
This kit fits Suzuki DRZ400S/SM(all), DRZ400E (Calif) (00-09) and Kawasaki KLX400SR (03-04)
JDFM050 - Keintech Fuel Screw for Suzuki DRZ400S/SM #86
$35 with installation when purchased together with JD JETTING HIGH PERFORMANCE KIT
http://i562.photobucket.com/albums/ss69/uniquemotor2/jetscrew.jpg
JD Jettings for other models:
$160 - Cash & carry
This JD kit is no joke..
will eliminate your backfiring problems and giving your the power and same time controlling the FC..
Good investment for those that wanna get some power and save fuel at the same time..
the jets in this kit is machine is made to be plug and play for SGP's climate.. no need to play around with the sizes at all.. all you needa do after installing is to tune the air/fuel mixture screw to get a good setting..
with it, your DRZ will not run lean after you install aftermarket exhaust and no more backfiring..
My current FC is 25.3km/L.
yeap, the jettings help alot, my friend's drz can feel the diff, i test ride also can feel it:cheers:
oh, did u? i was contemplating to come at 10am but then got work to do in the office so i finish it n came at 11. i did eo chg too and accidentally put in the JD jettings. was thinking to do jettings at abboy, then wat the heck. i put bmc air filter alrdy n bike feels overchoke wif air. i oso realise that 3x3 was not done yet. so i just hv the scorpion fs not fully optimised.
well, didn't regret though. after setting, the bike feeeeeeeeellsss great. like flying alrdy n the ah pui mechanic was happy doing wheelies in front of the shops :faint:.
nxt project, chg decals.
More reviews on JD jetting kits
Best Regards
Kelvin 87178999
WL: Zul 84818999
hi boss!
how much does it cost to tune the carb? i've been getting lots of backfire recently.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Products / Services available for Suzuki DRZ400SM:
- JD Jettings for DRZ400SM
- JD Jettings for DRZ400SM FCR 39mm carburetor
- Keintech Fuel screw
- ThumperTalk Manual Cam Chain Tensioner
- Motovation fork and axle sliders
- Motovation heavy balancer with barend sliders
- HEL brake lines
- Venhill brake lines
- Michelin Power One tyres [120/70-17(V) + 150/60-17(B)]
- Dunlop D253 supermotard tyres (120/70-17 + 150/60-17)
- Bridgestone BT090 tyres
- K&N air filter
- Pipercross air filter
- BMC air filter
- Ohlins fork springs
- Ohlins rear shocks
- 3x3 modifications
- LED tail lamps
- LED signal lamps
- PAIR removal
- BRAKING brake disc
- BRAKING brake pads
- EBC brake pads
Edited by Unique_Motorsports
Best Regards
Kelvin 87178999
WL: Zul 84818999
how much for led tail lights?isit drc?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Suzuki DRZ400SM - Performance Parts, Accessories & Servicing Packages
http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs595.snc3/31342_392758292105_160394947105_4229354_5372555_n.jpg
Servicing Packages for Suzuki DRZ400SM
Link to Servicing Packages for Suzuki DRZ400SM
Tyres for Suzuki DRZ400SM
Link to Tyres for Suzuki DRZ400SM
Sprockets + Chain
DID X Ring Chain + JT sprockets: $200
DID X Ring Chain + Original Sprockets: $260
DID X Ring Chain + DRIVEN sprockets: $280
DID X Ring Chain + ISA Sprockets: $280
DID X Ring Chain + AFAM Sprockets: $280
DID X Ring Chain + Supersprox Sprockets: $280
EK MVXZ Coloured X Ring Chain + DRIVEN/ISA/AFAM/Supersprox sprockets: $340
Air Filter
K&N: $105
BMC: $154
Street Legal Exhaust
Scorpion Full System: $1080 (New Model)
Delta Full System: $1050
WRP slip on aluminium : $890
WRP slip on Titanium: $1090
WRP slip on Titanium / carbon tip: $1290
Leovince slip on: $694.80 (UP $772)
Leovince Headers: $481
Leovince Full System: $1127.70 (UP$1253)
Yoshimura Titanium Oval Full System: $1880
Brakes/ Control
STAR Performance Brake lines: $110 (UP $130)
HEL brake lines + installation: $130
Venhill brake lines + installation: $230
Brake pad (WP, Gold Fren, Fizz Power, EBC, BRAKING etc): $25 to $75
BRAKING Front SK Disc 320mm: $510
BRAKING brake Caliper bracket for 320mm brake disc for OEM caliper: $110
BRAKING brake Caliper bracket for 320mm brake disc for BRAKING caliper: $110
BRAKING Rear Disc: $240
BRAKING 16mm Master Pump with lever: $470
BRAKING 16mm Master Pump with lever + BRAKING Reservoir:$ 480
BREMBO RCS15 Master Cylinder: $550
BREMBO RCS19 Master Cylinder: $550
BREMBO 16mm Master Pump Assembly: $288
BREBMO 16mm Master Pump Assembly + Clutch Assembly: $388
Motovation Products
- Motovation fork and axle sliders: $110
- Motovation heavy balancer with barend sliders : $75
- Motovation IMS Footpegs Sliders: $65
Others:
- JD Jettings for DRZ400SM: $180
- JD Jettings for DRZ400SM FCR 39mm carburetor: $180
- Keintech Fuel screw: $35
- 3 x 3 modifications: $35
- PAIR removal: $35
- ThumperTalk Manual Cam Chain Tensioner: $95
- Trial Tech Vapor Speedometer: $350
- Trial Tech Endurance Speedometer: $220
- LED signal lamps: $50 to $75
- LED tail lamp Acerbis red: $75
- LED tail lamp Acerbis white: $110
- Ohlins fork springs + dust covers + oil seals + Fuchs Silkolene fork oil + installation: $320
- Ohlins fork springs + dust covers + oil seals + Ohlins fork oil + installation: $400
- Ohlins rear shocks with installation: $1364
- DRIVEN Handlebar FATBAR: $150
- Renthal handlerbar (7/8): $130
- Renthal FATBAR: $180
- Renthal handlebar pad: $25
- Pivot Voltage Stabliser (made in Japan) $90
- Pivot Voltage Stabliser with Super Earth Cables (made in Japan) $148
- Revtec Impedance Stabiliser: $90
- Safari Fuel Tank 17 litres: $790
- Safari Fuel Tank 28 litres: $1090
- Broquet Fuel Charger B/2T: $59
- Broquet Fuel Charger B/3T: $80
- Samco Sports Silicone Hoses: $161 (DIY)
- Samco Sports Silicone Hoses + installation + Engine Ice: $211
- MR Digital voltmeter $55
- Dynamyx Digital Voltmeter: $55
- Stebel Twin Tone Horns (2pcs) + relay + installation: $65
- Stebel Nautilus Compact Horn (1pc): $85
- Hella Disc-Type Horns (2pcs) + relay + installation: $65
- Hella Twin Tone Horns (2pcs) + relay + installation: $65
- KTM 200 Headlight Assembly: $210
- KTM 200 Front Fender: $90
- Acerbis Supermoto handguard: $210
- Acerbis Multiplo "E" handguard: $230
- LED Vision headlight: $120
- WRP Wide Foot Pegs: $190
- Rough & Road 591 Rally Rack: $280
- IMS "Super Stock" Foot Pegs: $95
- IMS "Pro-Series" Foot Pegs: $120
-ASV F-1 Unbreakable Brake Lever :$85
-ASV F-1 Unbreakable Clutch Lever: $85
-ASV F-1 Unbreakable Brake and Clutch Lever Pair Pack: $135 (UP $170)
-ASV F-3 Unbreakable Brake Lever :$120
-ASV F-3 Unbreakable Clutch Lever: $120
-ASV F-3 Unbreakable Brake and Clutch Lever Pair Pack: $200 (UP $240)
-ASV C-5 Unbreakable Brake Lever :$150
-ASV C-5 Unbreakable Clutch Lever: $150
-ASV C-5 Unbreakable Brake and Clutch Lever Pair Pack: $240 (UP $300)
- Zeta Brake Lever: $95
- Zeta Clutch Lever: $95
- Zeta Amor Hand Guards: $180
- DRC Tail Lamp (Fender Eliminator) $145
- Trail Tech Striker: $350.00
- ThumperTalk Case Shields Ignition / Clutch Combo Pack $70 with installation
- DRIVEN coloured sprocket nuts $45
*Please check 1st post of this thread for latest updated pricelist. Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
JDS010 - Suzuki DRZ400S/SM with Keihin FCR MX 39MM Carburetor
$160 - Cash & carry
Main Jets included
Spare Needle Clip
Dyno Tested
$160 - Cash & carry
Best Regards
Kelvin 87178999
WL: Zul 84818999
Trail Tech - Innovative Offroad Solutions
Vapor ATV/motorcycle speedometer tachometer:
The Vapor motorcycle speedometer main feature is a large, well lit RPM tachometer graph. Vapor is useful as a motorcycle speedometer and side by side utility vehicle or ATV speedometer (or any machine with a wheel.) Vapor's large digital tachometer bar graph is easy to read. The digital gauge has many other useful features like time keeping, engine temperature, resettable distance, and odometer. Vapor's tachometer shift lights and temperature lights are great to warn about potential mechanical problems while there is still time to react. The built in stop watch and hour meter is perfect for race training. The adjustable distance setting can be used on those tough enduro courses.
Vapor is enough to replace an entire instrument cluster on your dashboard. Speed, time, distance and tach - Vapor has it covered. If indicator lights are required for dual-sport and supermoto road ready bikes, Vapor is available with a stylish indicator dashboard accessory. If rougher treatment is expected, the Vapor speedo has a full line of model-specific aluminum billet guards and protectors for motocross, enduro, rallies, and trials.
A combined effort from experts in software, electronics, and mechanical design – each feature of this 4th generation product is carefully crafted and constructed with the offroad enthusiast in mind.
http://i562.photobucket.com/albums/ss69/uniquemotor2/CIMG0887.jpg
- The latest concept in motorsport on-board computation. A combined effort from experts in software, electronics, and mechanical design - each feature of this 4th generation product is carefully crafted and constructed with the offroad enthusiast in mind.
- Speedometer
- Tachometer
- Temperature
- Distance
- Clock
- Power
- Model Specific Kits
- More Features
Pricing:
Vapor Kit - DRZ400SM: $350 with installation (Speedometer/ RPM etc)
Motorcycle Endurance Kit: $220 with installation (Speedometer only)
Best Regards
Kelvin 87178999
WL: Zul 84818999
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://photos-e.ak.fbcdn.net/hphotos-ak-snc3/hs007.snc3/11432_177040052105_160394947105_3043946_8345283_n.jpg
Best Regards
Kelvin 87178999
WL: Zul 84818999
wah sey, power lah, really awesome
Facebook HONDA CB400 REVO
Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Just changed to BRAKING Front SK Disc 320mm and bracket for 320mm disc for OEM caliper.
The braking power is unbelievable, just tap a bit can feel it.
Worth the money for a shorter braking distance and great looks:)
Worth the money for a shorter braking distance.
Best Regards
Kelvin 87178999
WL: Zul 84818999
