James Dean (JD) Jetting - Your source for high performance jet kits
http://i562.photobucket.com/albums/ss69/uniquemotor2/jdjetting_wht.gif
http://i562.photobucket.com/albums/ss69/uniquemotor2/JDanim1.gif
JDS005 - Suzuki DRZ400S/SM(all), DRZ400E (Calif) (00-09) and Kawasaki KLX400SR (03-04) #53
$160 - Cash & carry
$180 - With installation
http://i562.photobucket.com/albums/ss69/uniquemotor2/Im000535_T.jpg
James Dean designed the JDJetting kits so that you don't have to be an expert to get professional high performance results!! Even better, technical support is provided.
The James Dean custom jetting kit is designed to improve throttle response throughout the range by using specially made multi-taper needles. These are based on the most popular settings used by new generation MX and off-road riders around the globe and the results are impressive.
Exceeds the performance of the popular EMN, DTM, and other standard factory needle options
Low and High altitude custom designed triple taper needles
Main Jets included
Spare Needle Clip
Dyno Tested
Developed and tested from sea level to 12000ft elevation
You can’t buy this from any OEM factory or aftermarket. It’s JD’s prescription for the headpipe blues.
This kit fits Suzuki DRZ400S/SM(all), DRZ400E (Calif) (00-09) and Kawasaki KLX400SR (03-04)
JDFM050 - Keintech Fuel Screw for Suzuki DRZ400S/SM #86
$35 with installation when purchased together with JD JETTING HIGH PERFORMANCE KIT
http://i562.photobucket.com/albums/ss69/uniquemotor2/jetscrew.jpg
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
  • Replies 318
u hv aftermarket tail light fr drz?
Yes we do.
Best Regards
Kelvin 87178999
WL: Zul 84818999
noted.. will b dropping by wed.. btw do u do 3x3 air box mod with JD jettings? as well as PAIR removal..
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
can u install MCCT(manual cam chain tensioner) for drz? I have the mcct in hand to replace acct.
Sure. Do drop by when free.
Best Regards
Kelvin 87178999
WL: Zul 84818999
My DRZ's total mileage is 8000km, what kind of servicing do you recommend? Price? thank you very much.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
This JD kit is no joke..
will eliminate your backfiring problems and giving your the power and same time controlling the FC..
Good investment for those that wanna get some power and save fuel at the same time..
the jets in this kit is machine is made to be plug and play for SGP's climate.. no need to play around with the sizes at all.. all you needa do after installing is to tune the air/fuel mixture screw to get a good setting..
with it, your DRZ will not run lean after you install aftermarket exhaust and no more backfiring..
My current FC is 25.3km/L.
Thank you for your feedback.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Trail Tech - Innovative Offroad Solutions
Vapor ATV/motorcycle speedometer tachometer:
The Vapor motorcycle speedometer main feature is a large, well lit RPM tachometer graph. Vapor is useful as a motorcycle speedometer and side by side utility vehicle or ATV speedometer (or any machine with a wheel.) Vapor's large digital tachometer bar graph is easy to read. The digital gauge has many other useful features like time keeping, engine temperature, resettable distance, and odometer. Vapor's tachometer shift lights and temperature lights are great to warn about potential mechanical problems while there is still time to react. The built in stop watch and hour meter is perfect for race training. The adjustable distance setting can be used on those tough enduro courses.
Vapor is enough to replace an entire instrument cluster on your dashboard. Speed, time, distance and tach - Vapor has it covered. If indicator lights are required for dual-sport and supermoto road ready bikes, Vapor is available with a stylish indicator dashboard accessory. If rougher treatment is expected, the Vapor speedo has a full line of model-specific aluminum billet guards and protectors for motocross, enduro, rallies, and trials.
A combined effort from experts in software, electronics, and mechanical design – each feature of this 4th generation product is carefully crafted and constructed with the offroad enthusiast in mind.
http://i562.photobucket.com/albums/ss69/uniquemotor2/CIMG0887.jpg
- The latest concept in motorsport on-board computation. A combined effort from experts in software, electronics, and mechanical design - each feature of this 4th generation product is carefully crafted and constructed with the offroad enthusiast in mind.
- Speedometer
- Tachometer
- Temperature
- Distance
- Clock
- Power
- Model Specific Kits
- More Features
Pricing:
Vapor Kit - DRZ400SM: $320 with installation (Speedometer/ RPM etc)
Motorcycle Endurance Kit: $210 with installation (Speedometer only)
Best Regards
Kelvin 87178999
WL: Zul 84818999
with it, your DRZ will not run lean after you install aftermarket exhaust and no more backfiring...
yeap, the jettings help alot, my friend's drz can feel the diff, i test ride also can feel it:cheers:
Facebook HONDA CB400 REVO
Best Regards
Kelvin 87178999
WL: Zul 84818999
im getting my drz sm k9 this coming fri.....thinking of changing to lv slip on , aftmarket tailight , hel brake line , sliders......do u have them in stock and the price if possible?? do u guys do pair removal??
thanks
Edited by nastyash7
Skinny man with skinny bike!!!!
thanks
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
if i install the JD jetting, i have to install the JD JETTING HIGH PERFORMANCE KIT as well?
or installing the JD jetting enough?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
today drop by ur defu branch to do the jd kits, well was nt a very good experience. tuning wise, so-so only.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi how much wud it b if jus to purchase the Keintech Fuel Screw for Suzuki DRZ400S/SM #86? tks...
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
hey there,do u sell radiator shield for drz?and if i wanna include samco radiator hoses,how much for everything?thx!!
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
