ya..need 3.2..no change filter 3...[v]tec is right,if u wan to check wait for the engine to cool down first..mostly u change onli the engine oil,it will almost reach the top line..
  • Replies 833
Originally posted by s_hyper@Mar 1 2004, 06:29 PM
for my spec two is 3litres if never change oil filter. if got change oil filter then 3litres+...
From manual: if change oil without oil filter --> 3 litre exactly. If with oil filter --> 3.2 litre.
hei guys hus wanna know how u guys change yur engine oil yurself planning on doin it this weekend, usin the carefou engine oil total...got some ok reviews abt it here and most of all its cheap...how much do i use 3L or 2.7?i not goin to change my oil filter cos changed it last on october....thnks for the help guys....
Originally posted by vik@Mar 4 2004, 07:35 PM
sorry mine version s....ooh yah wat number spanner do i need?using the total engine oil frm carrefou good or not?
My VTEC2 is 17 (Should be common for most bikes, i guess), Oil filter is 65mm.
anyone uses fuchs engine oil here?? like comp 4t, pro 4? even other brand...
wat yr opinion..
personally been trying out various engine oil...like total..castrol ...fuchs..
now using cheap cheap fuchs engine oil comp 4t....i personally feel it somehow it is better...
wat yr opinion guys?? maybe if best..we can start a MO to buy engine oil and diy ourselves...
--==anything more than a handful is waste==--
http://photos.friendster.com/photos/89/36/3386398/2918831032400l.jpg
hw much is e fuchs engine oil comp 4t? wats the visocity?
Philosophy A: Ignore what everyone else thinks. Riding is a better way to get around. Ride paranoid and keep your skills sharp
Philosophy B: Ride with somebody who's better than you. You will pick up a handy trick or new skill just about every time you are out
Philosophy C: You don't need a big bike to prove ur passion for riding
Guest TheSquid
i'll only recommend 3 oils. Motul, OWS, sikolene.
:thumb: :thumb: :thumb:
Motul, the name says it. dun have to emphasis more.
OWS, smth i am using now. not bad i must say. ESTER BASE! wooo hooo
sikolene, new 'formula'? lol... good feed-back from my mates.
cheers
any comment on delphi from sanfu???
Signal First Before You Brake
SuperFour Biker
Posts ALL Rights reserved�.
THE WINGS TO RIDE FREELY
try b4..not much diff from other oil...
Thank you.... :smile:
SuperFour Biker
eehhh....it is up to personal perference...geez..
why not u try and give feedback too...
going to do that..... with the package so ask around first :cheeky:
SuperFour Biker
AS for me, i've been using Mobil 1 for quite some time.... so far no complain...:cheer:
http://www.motorbox.com/static/upl/y/yamahamt0s-7144-016-f.jpg
tried b4 any other engine oil?? how is it compare to others???
Guest LandLord
Originally posted by stanboy@Mar 24 2004, 07:11 PM
using MOTUL...veri smooth... :smile:
same leh
:lovestruck:
Well i did try motul b4... to my opinion motul is better than mobil 1 bcoz i can feel the smoothness of the engine :thumb: but on the other hand, i did notice that mobil 1 last longer than motul oil eventhough 5000km after use..... jus my 2 cents..:bouncefire:
Guest Sir_Romeo
motul and rockoil:thumb: :thumb: the n plus zx1 smooth~~~
Originally posted by Legan@Mar 25 2004, 09:06 PM
Trying $5 shell mineral oil. Very smooth..... Surprising
Where did you buy from?
good point taken out there..geez...
