setup: TV outlet to SCV cable modem, then to WRT54G Linksys wireless router
problem faced now; 1 desktop w/ USB Linksys Wireless WR54V4 network adapter and 1 notebook with PCMCIA Dlink WI Fi card
surfing with notebook no problem, but surfing with desktop is a big problem
i have excellent signal strength, but "limited connectivity" ,
downloading speed is 1kb n below, distance less than 5metres
tried reinstalling driver also no use, suspected is browser problem, installed Mozilla Firefox also same case
disabled norton internet security, helps abit but SBF alone still takes 5mins to load
help mi !
http://i145.photobucket.com/albums/r239/utopian355/ABCD0006-smallcopy.jpg
  • Replies 4
for a start, try connecting the desktop to the router via network cable. should the surfing speed be deemed normal, then u can safely isolate the problem to the wireless connectivity issue.
if its the wireless issue, u might need to provide more configuration details.
erm is better to use cable den wireless .. as cable lan u got more bandwidth which is 100mbps and wireless u onli hav 54mbps .. so dun xpect fast speed from wireless
May I know more about the connections.
SCV Point -> Cable Modem -> Use LAN Cable not USB -> Linksys Router.
Restart the cable modem. Should be able to work. You should get everything up and running. I hope. Do tell the outcome.
* Suzuki GSR750
