hey people just wanna get some advise from u guys..
getting my 2A and contemplating between spec 1 and 2.
I want good fuel efficiency. so is spec 1 a better choice than spec 2? whats are the cons of spec 2 besides the vtec open earlier? I read through the thread some bros the spec 2 1litre can go up to 23km whereas spec 1 1 litre about 19km.. What price range should i be looking at?
Thanks bros.
More power comes with more petrol consumption
Consumption depends on your riding style/ engine n ect.. LOTS of factor to consider
Mine spec 3 till last drop manage to get 420km/tank..(if I throttle conscious )
I have pretty bad fc.
Btw what sprocket setup r u all using? Tyre pressure also.
Full tank last me around 220-230
Keep everything as stock as possible
Depends on weight, but must be within factory spec
Afew tips to look out :
Possible reason for bad fuel consumption :
-Airfilter (Dirty/ Clogged up)
-Spocket (Worn out/ Not standard size)
-Chain (Not lube/ Chain too slack/ tightened)
-Tyre (Worn out/ Incorrect Pressure) ( Wrong size)
-Tyre Valve (Leaking air)
-Wheel bearing (Not in good condition)
-Engine Oil (Wrong grade/ Due for change)
-Carburetor (Air/ Fuel not balanced) (Jetting not stock)
-Fuel (Contaminated/ Low grade)
-Fuel line/ filter (Clogged)
-Meter (Inaccurate/ offset)
-Rider (MotoGP mood/ Fuel-conscious type)
-Clutch (Clutch plate/ spring worn out)
-Header Gasket (Worn out)
-Weight (Heavy luggage/ pillion/ rider)
-Idling (Too High/ low)
-Engine braking (Too much)
-Abrupt braking
-Hard acceleration
-Engine condition (TOO much to explain)
-Brake Caliper/ Brake pad (Brake Caliper piston jammed?/ not free)
-Improper suspension set-up (Too hard/ Too soft)
-Servicing (Do on time, dnt overdue)
-Idle too long (Waste petrol/ Engine hotter/ coolant affected unnecessary/ WaterPump work harder to maintain temperature)
Tats all I can think off, for now.
so what do u recommend? spec 1 or 2 ?
Hey people, just purchase a 1st hand revo few months back. My fuel consumption is really terrible like 18km/litre under normal riding without dragging. Isit normal that revo drink petrol like water? Cause some threads I read mention it could go for 24 to 25km/litre. Kindly advise.
Sent from my GT-I9505 using Tapatalk
Revo idling/ timing abit high conpared to carb model
Run in May consume slightly more petrol
My petrol I try full tank before reserve max ard 260-280km only.. Any spec1 bros here facing e same issue?
me too. but roughly how much can you last on a full tank if everything stock except air filter?
You guys having any issue on the fuel indicator? my indicator seem to be giving my question if it actually malfunction.
e,g it 5 bar after a few sec it drop 4 bar than a few sec it return back to 5 bar
any advice?
any advice?
I think the gauge change when u r on slope
Sent from my SM-N9005 using Tapatalk
Pls don't tailgate or stalk moi.:thumb:
any advice?
Digital gauge is not as accurate as those analog "needle-type"
anyone here know whr can i get carbon fibre tank and side cover?
06/08/07 --passed Class 2B (3rd attempt)
15/04/09 --passed Class 2A (1st attempt)
01/09/11 --passed Class 2 (2nd attempt)
I've been reading about bad mileage from so many users and that scares me. Super 4 is one of the contenders for my next bike.
Assuming a new well maintain super 4, whats the FC that I should be expecting ?
my spec 3 is only getting 18-19km/l no matter how conservative I ride which is kinda high imo.
is there anything I should send for checking? tyre pressure is 235 front and 265 rear, no pillion 90% all time
For me :
For sg road, ard 300km BEFORE reserve
For Nshw, ard 300km INCLUDING Reserve
Varies on condition
Edited by HaiR1
See post #2530
Try riding on Nshw at a constant speed, see if u get constant FC
  • 3 months later...
I actually saw this new model in a jap mag before i got my specIIIhttp://zz.avedcomputer.com/7.jpghttp://zz.avedcomputer.com/9.jpghttp://zz.avedcomputer.com/8.jpghttp://zz.avedcomputer.com/10.jpg
-Engine Oil (Wrong grade/ Due for change/ Too much)
-Abrupt braking
-Hard acceleration
Tats all I can think off, for now. :cheers:
I think that's all that can be contributed.. Lol.
My Spec 1 FC is also very bad, considering that my bike is fully stocked and I'm only 43 kg -.-
16km/l. Piang
The only constant is change... So keep changing.
:bounce:
2011~2013 - Yamaha Sparks LC135
2013~Current - CB400 Vtec1
Class 2 in training - CAN'T LIFT THE BIKE :angry:
