Put limit on who can start a new thread lor... sa like post counts >50 or maybe >100... at least it gives them 50 or 100 posts to learn before starting their own threads, and their participation being limited to the many many many threads of wide varieties should not be a problem. In fact even if you lao jiao in PK forum also no need to start new thread sia... everything all have liao. zzz
would be good, try posting this in Feedback thread to Admin :thumb:
that's not upto PK's moderator's power i guess.
anyway, it's great forum and friendly people... just we bull$h!t alot :p
you said it :lol:
hmmm i suggest u all change the title la.. like' see here for ur phantom problem' don't put possible la.. very blur for new rider.. but this is a good post la.. help alot of new rider.. so thumbs up for u guys.. :D
well I tried to make it not too singlish and comprehensible to everybody already. Any suggestions? I used 'possible' because it might not be 100% accurate :thumb:
Solution: Its normal.
Problem 2: Engine stalls in heavy rain and unable to start.
Reason: Air fuel mixture may be too rich.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Solution: Retune the carb.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 20: Sound emitting from front/rear wheel when braking
Reason: Brake pads worn out
Solution: Change
upz for good info.
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Solution: Change
12 Jun 2008 - Class 2B
28 Jun 2008 - Honda Phantom TA 200 (COE 11/3/17)
17 Jan 2009 - Class 3
27 Oct 2009 - Class 2A
28 May 2016 - Yamaha Fino 115 (COE 04/8/24)
9 June 2017 - Honda CB400 Spec 2 (COE 02/1/23)
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Solution: Change
Problem 20: Pop pop sound whenever you close your throttle(harley like sound)
Reason: Valve/Air vacuum faulty.
Solution: Get it replaced (honda original. Planet motors $65)
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Class2B - 11 Dec 08
Past - Honda Wave 125S
Current - Kawasaki KRR 150
Class3 - 26/09/09
Current - Lancer GLX 1.6
One Life, Treasure It
http://i180.photobucket.com/albums/x70/nengwei/R6-1.jpg
Future - YZF R6
hey guys, i used to have problem kicking the gear to neutral from either gear 1/2...but after oil change normally the problem is resolve...but now...it is the oppsite....have problem kicking to gear 1 to neutral ,now tap a bit only can go neutral...cannot go to gear 1...normally when gear 1 cannot kick down anymore...but now can continue to kick and kick but still cannot gear 1...then when move off sometime auto netural...from the "gear 1"...any bros here know wat is wrong with it?.....thanks in advance for any replies...
Bro i used to have tis issue, if ur bike keep on skip gear by itself i think mayb its the clutch prob, wat i would suggest is go planet n look for Mr Chong to quote for u just to b safe.
http://www.singaporebikes.com/forums/attachment.php?attachmentid=77956&d=1224144141
try kick down in half clutch. thats what cdc instructor taught me when i took 2A. the problem happened with their bike, and after that my phantom. but then again, best to check with bike shop
its either eo or clutch plate.
take note, it could also be biting point ;)
yup, best to let bike shop (recommended is planet) to have a look w/out worries of any aftermath.
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Problem 21: Weak Battery.
B]Reason: [/b] There is a knob for adjustment, it might be loose
Reduce it to 2 turns. You mixture may be too lean.
There's no fixed setting, every vehicle has a different setting suit/catered to different users.. Try adjusting slowly over time to cater to yourself or let the mechanics do the job. FOC.
Hi SNapEl, managed to rectify my backfire problem. My mech say its a exhaust gasket issue. After change exhaust gasket, the backfire seems to have lessen alot but not completely gone (once in a while have a pop sound). My mech said TA200 standard carb settin is 2.5 turn. Just wanna to confirm this with u guys. Anyway, i have yet to try reducing to 2 turns. Is there any other way to check if our setting is rich or lean apart from spark plug appearance? Now my bike feels throttle response is better a bit, but once reach 90`100 feels a bit heavier to pull away..
Solution: Obvious.
i kena this one this morning... pushed all the way 2nd floor to 1st floor of MSCP also cannot start... took out spark plug to check spark, wondering how come no spark... try with spare plug also no spark... then i saw the kill switch.................... :faint:
last night itchy hands la go use kill switch to stop engine... :nono:
Solution: Obvious.
hahahah i also kenna this a few times liao.. if not then is start liao then kick gear 1 engine die off.... forget to kick up side stand... lol
haha lol chuanz you all the way sia... take out spark plug summore..
Once i just crank starter motor, crank crank crank dun start, siao liao... den notice kill switch. Heng ar...
piang eh forum cmi double post
Hi I had problem 18 and had the cam chain tensioner changed. That was only about 500km ago. Now the sound is back. Should I change the tensioner again or are there any other possible reasons?
