Sounds similar to Spark_135's problem? That time his grounding got problem screw up his electricals.
Identical symptoms just that mine is grounding issues his is fuse.
2A - On going...
:PPhantom TA200/TA150 List of Problems and Solution
Solution: Its normal.
Turning the screw clockwise to enrich the mixture. (once again, tune in 1/4 or 1/2 turns of the air correction screw, located on the LEFT side of the carb)
Bike tends to rev rapidly but have poor acceleration if lean, and if too rich, will have "spongy" / slow throttle response at high speeds.
If in need of advise / demonstration sms pandora's kitten at 93270801 (advice/demo given is FOC)
Reason: Air leakages.
Reason: Air filter clogged.
Solution : Get your air filter changed. You are advised to inspect the air filter every 4000 or so kms and change it at 10k (Honda warranty service manual)
Solution 2: Buy a can of fix a flat from Carrefour or petrol stations, put it in your box.
Reason: Fuse may be blown.
Reason: Bike is in gear, kill switch is on, no petrol, petcock off.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution: If you have very poor acceleration when throttle is opened, you are running lean. Enrich mixture by 1/2 to 1 turn of the air correction screw.
Solution: If you are using spray on chain lube, dirt and grease may be thrown off the chain during normal operation. When a lot of grease accumulates on the chain tensioner (rubber cylinder) and swingarm protector (rubber bar) the chain will emit a loud sound as though running through sand. Scrape and wipe away the excess grease and enjoy the quietness.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution: Fuel/air mixture too lean giving poor acceleration and a hot engine
Reason: Your brake is dragging
Solution: Check wheel spin, check the brake pads if its time to replace, check if brake caliper mounted properly, check disc rotor warped or not
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Solution: Fuel-air mixture likely too rich. Backfires when throttle is closed, due to residual fuel afterburning in the exhaust header. This is bad for the valves and the catalytic converter.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Pandora's Kitten :3)
Solution: Gear box dying.
Solution: Engine is overheated. (Running too lean/ Not enough engine oil. An overheating engine may cause excessive oil consumption, especially when using less tolerant mineral oil)
Solution: If cannot find neutral when engine is hot but fine when engine is cold, that means engine oil has degraded and cannot maintain its viscosity at high temperatures. Changing engine oil should solve the issue.
Problem 27: Handlebar position is not centered (while riding). Handlebars are "straight" but wheel points to one side.
Solution: Lock the wheel, grab the handlebars firmly and twist the bars until straightened. The risers are flexible to some degree, due to the vibration damping rubber washers. (Demonstrated by Planet Motors)
Solution: If your steering lock is spoilt, put the wheel against a pillar or a wall.
Problem 28: Bike hard to U-turn. Riding position not comfortable as handlebars too high up.
Solution: Adjust the angle of the handlebars. Loosen the bottom two screws of the risers, pull back the bars so they "rise" towards your face. This will give you a more relaxed riding posture and you are able to enjoy a greater turning angle at low speeds. If your handlebars are set to rise straight upwards forcing you to stretch forward and upwards to steer, your elbows will prevent you from turning easily at low speeds
Problem 29: Engine oil disappears at a fast rate
Reason: Piston ring busted.
Solution: See mechanic. Top overhaul probably needed.
Problem 30: Side stand broke off with mounting lug.
Solution: Get a mechanic to weld the mounting back.
Solution: Obvious.
Others:
=Battery : super bright when neutral light.
=fuel : full tank
=gear : not in gear, in neutral start bike
=headlight : always off when starting bike, but i recently changed to new headlight so its kinda like using Super4 lightbulb..12V still.
i think im having this problem..
morning cold start always no problem, until recently my bike couldnt start by electrical means, but manage to start when push start..
the problem seemed to be "degrading"...as in the problem starting up at first was weak, den gradually weaker and weaker until cannot electrical start.
after riding, i park at destination and try to start bike, can start by electrical means eh...
*edit*
FUSE problem?
earth cable problem?
Edited by ahch0ng
adding possible problem
=fuel : full tank
*edit*
FUSE problem?
Nice seeing you ahch0ng at planet today :cheeky:
Class 3 02/06/2011
Class 2B 13/06/2012
NSR150SP FBD2**G June 2012 - October 2012
Phantom TA200 FW6**6A October 2012 -
haha hello there!
end up i change battery and my headlight(it was using H4 light bulb which literally blew off my headlight)...
back to original...and no more problem~
Just changed my air filter, ah boy one $10, but the other shops $20 sia, got diff anot ah?
My bike shop charge $25 for Genuine Honda Made in Thailand with install is the other shop selling genuine from Honda?
Ah Boy selling $10 not genuine but useable anyway.
http://tripdrive.blogspot.sg
Hi, for the past few days I been seeing this small black oil pool after leaving my bike park for the night. I checked my engine oil level and its didn't change, still maintain the xxx level. Does anyone know what is happening to my bike?
Thanks
As the photo show 2 spots, actually is just one spot, cause I managed to park at the same place, so that would be 2 different spot for 2 days.
http://i.imgur.com/BiUjN.jpg
http://i.imgur.com/UfILP.jpg
http://i.imgur.com/ipF32.jpg
Look under your engine like you would want to see a girls upskirt. :p Check your gasket if it is torn (try looking at those gap, see if oil is leaking thru). Or your drain nut if its leaking or not. Mine was a torn gasket due to ageing that resulted in a massive oil leak.
Edited by Spark_135
2A - On going...
You oiled to much is it? :angel:
If pump too many times or oil everyday will over oil and the excess oil will drip off the front sprocket. :)
I have an ezzyoiler install, and it was okay for the first few weeks, didnt see this pool of small oil patch maybe its from that? but the spoil is usually like under the joint of the stand
Hi guys,
A noob in Phantom here. Anyways, I'm having problems e starting my bike, especially when I leave it overnight. Seems that when the headlights are "on", nothing happens when I press the starter button (no cranking, no clicking). It will only start if I either 1) switch off the headlights or; 2) if I leave the lights on, I'd have to clutch in to start the bike. What seems to be the problem? Been having this problem since I bought the bike in July. Changed the batteries last Thursday when it went kaput (couldn't even push start the bike) but still having this problem. Any advice is much appreciated! :)
yup if possible remove the front sprocket cover and clean up that area too. that area can have alot of dirt build-up as well.
Hmm with due respect to you, to give you a benefit of doubt (not suspecting what u suggested), he said for the past few days he been seeing oil spots of that kind. Either his front sprocket cover is really filled with so much oil due to over oiling, or it could be another reason like a torn gasket as i mentioned. I dont mean to sound "act pro" but im worried for him because i had the problem of torn gasket and my EO is gone in 3 days (so fast because my piston ring also gone). That is dangerous as riding without oil can potentially damage the engine or even seize it during riding. And the prob of torn seal took me 2 weeks to discover it because the oil dripped from the drain plug direction, as the oil from the torn gasket slowed flowed down into the drain plug and dripped there. Hmm what i suggest is he open the cover as u guys suggested, see if the inner side is oil stained or contains some levels of oil. If there isnt, with the back of his head almost touching the floor, try look along the gasket area where the main engine oil sump is bolted to the side piece if its oily.
2A - On going...
