Bros i;m riding an SP and noticed tht my exhaust pipe end is a bit wet with black EO forming a "ring" around the opening of my pipe.. I went to change Oil seal rdy and wiped the pipe clean but after riding again still same thing.. Any idea wat it could be?
As for as how it affects my riding feeling like after u kick down from neutral to gear 1 at traffic light sometimes got tht slight choking feeling like cannot pull? Then after gear 2 onwards normal and call pull rdy.
http://img44.imageshack.us/img44/7706/32618315064695358757195.jpg
FOund and Happy. A special thanks to Derek and *Edwin(xxes123) who found my baby.
  • Replies 17
Your bike kenna rape by the thief?
DUnno how he ride and maybe got stationary drop. My left tai fairing there bit scartches and my left balancer scrapped a bit.
Most importantly is that you got your bike back. :)
I think ah, with my limited knowledge of 2 stroke bikes, could be something to do with your 2t pump perhaps spewing too much 2t into your engine. So not rich enough to burn your fuel, too much soot mixed with your 2t and forms a ring around your pipe. I dont think can be your 4t because it is seperate from the whole system. Then again, i'm not an expert in this. :)
My mech thought was too much 2t too.. He lowered the 2t valve(or watever its called) But still like got tht ring of black EO(Liquid) not soot.. SMoke output is okay.. Not alot of white smoke..
maybe the exhaust hav accumulate too much unburn 2t previously..
so no matter how much u lower the 2t intake, the oil will still present at the tip..
is like a full cup of water.. no matter wat amount u pour in, still overflow..
try clean the inside..
Hmmm.. thx for suggestion bro will try go get my pipe cleaned
Simple solution. Go with premix. Get the right mixture all the time. U just need a bit more effort.
But my 2T pump is still working O,o Whats the ratio anyway? I may try it out my Full tank abt 8L
victim of joyride theft.. by the way.. if i am not mistaken.. if u want to use premix must switch off the pump...
http://www.moviesonline.ca/movie-gallery/albums/Transformers2/transformers-20090430-megan-fox-on-bike-sexy-hot.jpg
My ride's a b*tch... thank god i have a bike....
i believe its e 2t. v common.
Wat u mean? O,o
Wat u mean? O,o
Your bike needs to be serviced(cleaned)
For the the black thing that leaks out is your 2t. Usually seen after you park.
Yup yup.. So a full servicing should do the trick?
thats my knowlegde for 2t bikes. However, for your nsr, i remembered that i read somewhere that its a common problem among them which they have yet to rectify the cause. this is talking about the pull thing.
i tot all 2t bikes will come across this problem?.. premix will be nice.. but incorrect ratio will make your pipe more wet?.. as in presence of 2t at the tip.. try full service.
Edited by zart
Do Not Speed
