Suzuki DRZ400SM - Performance Parts, Accessories & Servicing Packages
http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs595.snc3/31342_392758292105_160394947105_4229354_5372555_n.jpg
Servicing Packages for Suzuki DRZ400SM
Link to Servicing Packages for Suzuki DRZ400SM
Tyres for Suzuki DRZ400SM
Link to Tyres for Suzuki DRZ400SM
Sprockets + Chain Kit
DID X Ring Chain + JT sprockets: $200
DID X Ring Chain + Original Sprockets: $260
DID X Ring Chain + DRIVEN sprockets: $280
DID X Ring Chain + ISA Sprockets: $280
DID X Ring Chain + AFAM Sprockets: $280
DID X Ring Chain + Supersprox Sprockets: $280
EK MVXZ Coloured X Ring Chain + DRIVEN/ISA/AFAM/Supersprox sprockets: $340
Air Filter
K&N: $105
BMC: $106
Pipercross $55
Street Legal Exhaust System
Scorpion Full System: $1080 (New Model)
Delta Full System: $1050
WRP slip on aluminium : $890
WRP slip on Titanium: $1090
WRP slip on Titanium / carbon tip: $1290
Leovince slip on: $694.80 (UP $772)
Leovince Headers: $481
Leovince Full System: $1127.70 (UP$1253)
Yoshimura Titanium Oval Full System: $1880
Brakes/ Control
STAR Performance Brake lines: $110 (UP $130)
HEL brake lines + installation: $140
Venhill brake lines + installation: $230
Brake pad (WP, Gold Fren, Fizz Power, EBC, BRAKING etc): $25 to $75
BRAKING Front SK Disc 320mm: $510
BRAKING Caliper bracket for 320mm brake disc for OEM caliper: $180
BRAKING Caliper bracket for 320mm brake disc for BRAKING caliper: $180
BRAKING Rear Disc: $240
BRAKING 16mm Master Pump with lever: $470
BRAKING 16mm Master Pump with lever + BRAKING Reservoir:$ 480
BREMBO RCS15 Master Cylinder: $550
BREMBO RCS19 Master Cylinder: $550
BREMBO 16mm Master Pump Assembly: $288
BREBMO 16mm Master Pump Assembly + Clutch Assembly: $388
DRIVEN Velocity handlebar $110
DRIVEN Meteor handlebar: $150
Renthal standard handlerbar (7/8): $130
Renthal FATBAR: $180
Renthal handlebar pad: $25
AFAM Xbar $130
AFAM Bigbar $180
ASV F-1 Unbreakable Brake Lever :$85
ASV F-1 Unbreakable Clutch Lever: $85
ASV F-1 Unbreakable Brake and Clutch Lever Pair Pack: $135 (UP $170)
ASV F-3 Unbreakable Brake Lever :$120
ASV F-3 Unbreakable Clutch Lever: $120
ASV F-3 Unbreakable Brake and Clutch Lever Pair Pack: $200 (UP $240)
ASV C-5 Unbreakable Brake Lever :$150
ASV C-5 Unbreakable Clutch Lever: $150
ASV C-5 Unbreakable Brake and Clutch Lever Pair Pack: $240 (UP $300)
Zeta Brake Lever: $95
Zeta Clutch Lever: $95
Zeta Amor Hand Guards: $180
Motovation Products
- Motovation fork and axle sliders: $110
- Motovation heavy balancer with barend sliders : $75
- Motovation IMS Footpegs Sliders: $65
Performance Upgrades
JD Jettings for DRZ400SM: $180
JD Jettings for DRZ400SM FCR 39mm carburetor: $180
Keintech Fuel screw: $35
3 x 3 modifications: $35
PAIR removal: $35
ThumperTalk Manual Cam Chain Tensioner: $95
Pivot Voltage Stabliser (made in Japan) $90
Pivot Voltage Stabliser with Super Earth Cables (made in Japan) $148
Revtec Impedance Stabiliser: $90
Broquet Fuel Charger B/2T: $59
Broquet Fuel Charger B/3T: $80
Ohlins fork springs + dust covers + oil seals + fork oil: $320
Ohlins fork springs + dust covers + oil seals + Ohlins fork oil: $400
Ohlins rear shocks with installation: $1364
Others:
Trial Tech Vapor Speedometer: $350
Trail Tech Striker: $350.00
Trial Tech Vector: $320.00
Trial Tech Endurance Speedometer: $220
LED signal lamps: $50 to $75
LED tail lamp Acerbis red: $75
LED tail lamp Acerbis white: $110
Safari Fuel Tank 17 litres: $890
Safari Fuel Tank 28 litres: $1190
Samco Sports Silicone Hoses: $161 (DIY)
Samco Sports Silicone Hoses + installation + Engine Ice: $211
MR Digital voltmeter $55
Dynamyx Digital Voltmeter: $55
Stebel Twin Tone Horns (2pcs) + relay + installation: $65
Stebel Nautilus Compact Horn (1pc): $85
Hella Disc-Type Horns (2pcs) + relay + installation: $65
Hella Twin Tone Horns (2pcs) + relay + installation: $65
BLU Horn + Relay $45
KTM 200 Headlight Assembly: $210
KTM 200 Front Fender: $90
Acerbis Supermoto handguard: $210
Acerbis Multiplo "E" handguard: $230
LED Vision headlight: $120
WRP Wide Foot Pegs: $190
Rough & Road 591 Rally Rack: $300
IMS "Super Stock" Foot Pegs: $95
IMS "Pro-Series" Foot Pegs: $145
DRC Tail Lamp (Fender Eliminator) $145
ThumperTalk Case Shields Ignition / Clutch Combo Pack $70 with installation
DRIVEN coloured sprocket nuts $45
Brembo Upgrade Kit
Brembo RCS 15 $550.00
Brembo Cast 4 Pad Radial Mount Caliper + QTM bracket: $650.00
Brembo 320mm Full Floating Rotor: $520.00
*Please check 1st post of this thread for latest updated pricelist. Thank you.
http://i450.photobucket.com/albums/qq228/uniquemotor/2008-suzuki-dr-z400sm_800x0w.jpg
Standard Servicing Packages (Engine Oil + Oil Filter)
$48 Package
- 2x Chessa Chex 9000 10W50 Engine Oil
- 1x Suzuki DRZ400 Oil filter
$54 Package
- 2x Belray Thumper 10W40/ 15W0 Engine Oil
$56 Package
- 2x Motul 5100 10W40/ 15W50 Engine Oil
$60 Package
- 2x Maxima Extra 15W50 Engine Oil
$60 Package
- 2x Silkolene Pro 4 10W50 Engine Oil
$68 Package
- 2x Motul H-Tech 100 15W50 Engine Oil
- 1x Suzuki DRZ400 oil filter
$69 Package
- 2x Belray EXS 10W50/ 5W60 Engine Oil
$74 Package
- 2x Motul 300V 10W40/ 15W50 Engine Oil
Standard Servicing Packages (Engine Oil + Oil Filter + Spark Plug)
$58 Package
- 1x Denso Regular Spark Plug
$64 Package
- 2x Belray Thumper 10W40/ 15W50 Engine Oil
$66 Package
$70 Package
$70 Package
$78 Package
- 2x Motul H-Tech 100 10W40 Engine Oil
$79 Package
$84 Package
- 2x Motul 300V 15W50 Engine Oil
Standard Servicing Packages (Engine Oil + Oil Filter + Spark Plug + Engine Ice)
$118 Package
- Engine Ice High Performance Coolant
$124 Package
$126 Package
$130 Package
$130 Package
$138 Package
$139 Package
$144 Package
Full Servicing Packages (Engine Oil + Oil Filter + Spark Plug + Engine Ice + Engine Flush + Engine Protector + Gas Treatment)
$186 Package
- OWS 210 Engine Flush
- OWS 220 Engine Protector
- OWS 360 Gas Treatment
$192 Package
$194 Package
$198 Package
$198 Package
$206 Package
$207 Package
$212 Package
James Dean (JD) Jetting - Your source for high performance jet kits
http://i562.photobucket.com/albums/ss69/uniquemotor2/jdjetting_wht.gif
http://i562.photobucket.com/albums/ss69/uniquemotor2/JDanim1.gif
JDS005 - Suzuki DRZ400S/SM(all), DRZ400E (Calif) (00-09) and Kawasaki KLX400SR (03-04) #53
$160 - Cash & carry
$180 - With installation
http://i562.photobucket.com/albums/ss69/uniquemotor2/Im000535_T.jpg
James Dean designed the JDJetting kits so that you don't have to be an expert to get professional high performance results!! Even better, technical support is provided.
The James Dean custom jetting kit is designed to improve throttle response throughout the range by using specially made multi-taper needles. These are based on the most popular settings used by new generation MX and off-road riders around the globe and the results are impressive.
Exceeds the performance of the popular EMN, DTM, and other standard factory needle options
Low and High altitude custom designed triple taper needles
Main Jets included
Spare Needle Clip
Dyno Tested
Developed and tested from sea level to 12000ft elevation
You can’t buy this from any OEM factory or aftermarket. It’s JD’s prescription for the headpipe blues.
This kit fits Suzuki DRZ400S/SM(all), DRZ400E (Calif) (00-09) and Kawasaki KLX400SR (03-04)
JDFM050 - Keintech Fuel Screw for Suzuki DRZ400S/SM #86
$35 with installation when purchased together with JD JETTING HIGH PERFORMANCE KIT
http://i562.photobucket.com/albums/ss69/uniquemotor2/jetscrew.jpg
This JD kit is no joke..
will eliminate your backfiring problems and giving your the power and same time controlling the FC..
Good investment for those that wanna get some power and save fuel at the same time..
the jets in this kit is machine is made to be plug and play for SGP's climate.. no need to play around with the sizes at all.. all you needa do after installing is to tune the air/fuel mixture screw to get a good setting..
with it, your DRZ will not run lean after you install aftermarket exhaust and no more backfiring..
My current FC is 25.3km/L.
yeap, the jettings help alot, my friend's drz can feel the diff, i test ride also can feel it:cheers:
oh, did u? i was contemplating to come at 10am but then got work to do in the office so i finish it n came at 11. i did eo chg too and accidentally put in the JD jettings. was thinking to do jettings at abboy, then wat the heck. i put bmc air filter alrdy n bike feels overchoke wif air. i oso realise that 3x3 was not done yet. so i just hv the scorpion fs not fully optimised.
well, didn't regret though. after setting, the bike feeeeeeeeellsss great. like flying alrdy n the ah pui mechanic was happy doing wheelies in front of the shops :faint:.
nxt project, chg decals.
Trail Tech - Innovative Offroad Solutions
Vapor ATV/motorcycle speedometer tachometer:
The Vapor motorcycle speedometer main feature is a large, well lit RPM tachometer graph. Vapor is useful as a motorcycle speedometer and side by side utility vehicle or ATV speedometer (or any machine with a wheel.) Vapor's large digital tachometer bar graph is easy to read. The digital gauge has many other useful features like time keeping, engine temperature, resettable distance, and odometer. Vapor's tachometer shift lights and temperature lights are great to warn about potential mechanical problems while there is still time to react. The built in stop watch and hour meter is perfect for race training. The adjustable distance setting can be used on those tough enduro courses.
Vapor is enough to replace an entire instrument cluster on your dashboard. Speed, time, distance and tach - Vapor has it covered. If indicator lights are required for dual-sport and supermoto road ready bikes, Vapor is available with a stylish indicator dashboard accessory. If rougher treatment is expected, the Vapor speedo has a full line of model-specific aluminum billet guards and protectors for motocross, enduro, rallies, and trials.
A combined effort from experts in software, electronics, and mechanical design – each feature of this 4th generation product is carefully crafted and constructed with the offroad enthusiast in mind.
http://i562.photobucket.com/albums/ss69/uniquemotor2/CIMG0887.jpg
- The latest concept in motorsport on-board computation. A combined effort from experts in software, electronics, and mechanical design - each feature of this 4th generation product is carefully crafted and constructed with the offroad enthusiast in mind.
- Speedometer
- Tachometer
- Temperature
- Distance
- Clock
- Power
- Model Specific Kits
- More Features
Pricing:
ThumperTalk Manual Cam Chain Tensioner (Suzuki DRZ400SM & Hayabusa 1300)
http://i600.photobucket.com/albums/tt84/uniquemotor4/ENG_TT_MCCT1-2.jpg
Save yourself thousands in costly repairs! ThumperTalk Manual Cam Chain Tensioners (MCCT) are designed to replace the automatic and hydraulic tensioners found on today's hi-performance 4-stroke engines.
Factory automatic adjusters can back out when the throttle is suddenly closed at higher rpms. This allows the cams to momentarily go out of time and can result in bent valves and/or serious engine damage! Hydraulic tensioners have a tendency to put too much tension on the chain guide under high rpm/high oil pressure conditions, resulting in premature cam chain wear.
Installation of a ThumperTalk Manual Cam Chain Tensioner will allow you to maintain the proper, constant cam chain tension necessary for reliable hi-performance riding and it will not backout.
This is a high quality product, proudly made in the USA. There are thousands of these units in service, so buy in confidence!
- Precision machined billet aluminum body
- O-ring seals, both on the body and threads
- Stainless steel adjuster bolt & locknut
- Clear anodized body for long lasting good looks
Pricing: $95 with installation
http://i600.photobucket.com/albums/tt84/uniquemotor4/DRZbremboupgrade.jpg
Brembo Upgrade Kit
STAR Brake lines: $110.00
All of above items: $1730 (UP $1830)
http://i450.photobucket.com/albums/qq228/uniquemotor/drz400yoshimuraupgrade.jpg
Cylinder Works 434cc Big Bore Kit
Suzuki DRZ400SM 2000-2011
Price $999.00
Yoshimura Engine Mount
Suzuki DRZ400SM Price: $160.00
CNC Machined from 6061 T6 alloy
Very strong. Lighter than OEM stamped version
Laser etched Yoshimura logo
Distinctive Yoshimura Magnasonian finish
Kit includes front and top engine mounts
Yoshimura Case Savers
Suzuki DRZ400SM $230.00
Crafted from 6061 T6 alloy
Distinctive Yoshimura logo
Protect the sensitive water pump and ignition cover in the event of a crash
Yoshimura Rear Brake Clevis
Suzuki DRZ400SM Price $100.00
Stronger and lighter than the stock unit
Smoother brake action
Better brake pedal feel
CNC machined from 6061 T6 alloy
Yoshimura Engine Timing Plug Kit
Suzuki DRZ400SM Price :$88.00
Include small TDC plug and crank shaft inspection plug
Facebook Pictures for Suzuki DRZ400SM http://www.facebook.com/pages/Unique-Motorsports-Pte-Ltd/160394947105#!/media/set/?set=a.10150330081427106.343810.160394947105&type=1
Please check 1st post of this thread for latest pricing. Thank you.
[FAQ] All you need to know abt Suzuki DRZ400SM = http://www.singaporebikes.com/forums/showthread.php/287029-FAQ-All-you-need-to-know-abt-Suzuki-DRZ400SM
Edited by Unique_Motorsports
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
  • Replies 318
Tyres
Pirelli Diablo: $290 (R150)
Pirelli Diablo: $290 (R160)
Dunlop Alpha 10: $310 (R150)
Dunlop Alpha 10: $320 (R160)
Michelin Pilot Power: $350 (R150)
Michelin Pilot Power: $370 (R160)
Brakes
EBC brake pad: $155
just asking, the tyres includes the front one for the price listed?
the EBC brake pad is $155 for front n rear?
Facebook HONDA CB400 REVO
Tyres stated are for front and rear.
EBC for Suzuki DRZ400SM: $55 each. Front and Rear: $110.
Best Regards
Kelvin 87178999
WL: Zul 84818999
thanks to unique.
brake hose n air filter done:cool:
still got a long list to go:giddy:
thanks to unique.
Thank you for your support and feedback.
Best Regards
Kelvin 87178999
WL: Zul 84818999
i have change to a full system pipe, how much it cost for TUNING??
& how much it cost for checking my alignment, braking, clutch cable etc.??
thanx..
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://www.uniquemotorsports.com.sg/pic/samcologo.gif
We are proud to introduce you the outstanding range of Samco Sport, direct replacement, high-performance silicone coolant hose kits for motorcycles. The Samco Sport hose kits are designed as a direct replacement for a wide range of motorcycles both in motorsport and fast road use. Superb integrity and superior performance reduces the risk of component failure and enables higher temperatures and pressures to be maintained with complete confidence when it matters, under pressure!
With superlative quality proven on the race and rally circuits worldwide, Samco Sport silicone hoses are the first choice of engineers demanding total reliability under competition and fast road conditions. They are available in 7 high gloss colours; Red, Blue, Black, Green, Yellow, Purple and Orange. They can either be matched to bike colour, add a custom look or ordered in black to keep an authentic appearance. All Samco products are manufactured in the UK and we are working closely with them to expand their product range. If there is a kit you feel need’s adding to the list sooner rather than later please contact us and we can look into it.
http://www.uniquemotorsports.com.sg/pic/bluehose.gif http://www.uniquemotorsports.com.sg/pic/redhose.gif
*Hoses fitted are shown on a Ducati 916
Colours available: Red, Blue, Black, Green, Yellow, Purple and Orange
Special Offer (While Stock Last!)
$348 PACKAGE (Usual Price $480) -
Samco Sports Silicone Hoses Package for Honda CB400 Vtec I/II/III/Revo:
- Samco Sport Silicone Hoses x 7
- Removal of old rubber hoses x 7
- Installation of Samco Sport hoses x 7
- Radiator flush
- Workmanship
Colours available (Ready stock): Red or Blue
Other colours (including Ver S/R): To order 4 to 8 weeks for delivery
$188 PACKAGE (Usual Price $280) -
Samco Sports Silicone Hoses Package for Suzuki DRZ400 SM:
- Samco Sport Silicone Hoses x 3
- Removal of old rubber hoses x 3
- Installation of Samco Sport hoses x 3
- Radiator flush
- Workmanship
Other colours: To order 4 to 8 weeks for delivery
Best Regards
Kelvin 87178999
WL: Zul 84818999
Brembo Cast 4 Pad Radial Mount Caliper for Suzuki DRZ400SM
http://i450.photobucket.com/albums/qq228/uniquemotor/motostrano_2039_37151686.jpg
$650 PACKAGE:
- Brembo Cast 4 Pad Radial Mount Caliper
- Brembo Brake Pads
- Caliper Relocator
- Motul 5.1 Brake Fluid
- Installation of Brembo Cast 4 Pad Radial Mount Caliper
Best Regards
Kelvin 87178999
WL: Zul 84818999
wow, so many goodies for DRZ, i go see liao more surprised, even more stuffs for DRZ, :thumb: for u
Best Regards
Kelvin 87178999
WL: Zul 84818999
ready stock for braking rear disc???:sian:
Yup. Ready stock available for DRZ.
Best Regards
Kelvin 87178999
WL: Zul 84818999
BRAKING BRAKE DISC + BREMBO CALIPER
http://i450.photobucket.com/albums/qq228/uniquemotor/DSC00036.jpg
DRIVEN BLACK SPROCKET + EK RED COLOUR X RING CHAIN
http://i450.photobucket.com/albums/qq228/uniquemotor/DSC00037.jpg
http://i450.photobucket.com/albums/qq228/uniquemotor/DSC00038.jpg
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi Boss,
Right now my bike is still in running in period..this will be my first oil change...
so since i need to use only mineral oil during running in ...which package do u recommend?...just wanna change mineral oil n oil filter btw...
thanx...if can i wanna come by later aft work..
Hi Boss,
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Very prompt reply...ok den...i will come down to ur defu lane branch later this evening...:thumb:
THANX!
Sure. Cya.
Best Regards
Kelvin 87178999
WL: Zul 84818999
went yesterday evening to Defu Lane Branch to change mineral oil & oil filter..
quite happy with the service given...
Thanx Alex...:thumb:
Best Regards
Kelvin 87178999
WL: Zul 84818999
Promotion ended.
Best Regards
Kelvin 87178999
WL: Zul 84818999
got no yoshi for drz??
Yes, there are.
Best Regards
Kelvin 87178999
WL: Zul 84818999
any package for drz wit iridium spark plug??
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
