Originally posted by S4Sixty@Nov 16 2004, 02:29 AM
3.2L should be for Vtech.
Obviously they mistook ur for a VTEC cuz of the colour or the ripping u off by saying it's actually better for ur bike, which is not.
If u dun believe me, check the forum for exact specs for Ver S.
Cheers !
so that mean for vtec2 need 3.2L engine oil izzit... but i all the way using 3L
  • Replies 833
I am currently using duckhams 10W40 semi-syn oil and i find that after 2 to 2.5 mths, my gear shifting is very hard and rough. Engine also feels rough. I know its time to change and i wanna DIY. Any gd engine oil to recommend. Heard of royal purple, castrol R4, repsol,motul and fuchs etc are gd. First timer to DIY so need some advice on it too. Thanx a lot bro
THE ROAD BURNS AFTER ME
Dude.... You don't go by MONTHS but KM when it comes to changing EO.
Take a look at the Components Price List...
There are more than 10 types to choose from.
Heard Motul 300V is the best.
I am using Royal Purple 20w50.
Good for mi. Nice and slick gear shifting.
But mileage very low as I always in other country so I change oil 9 months but filter change 6 months.
does engine oil hav any life span once its poured into the engine ?? wat if he seldom ride, like 5000 km in 6 mths... then he change oil every 6 mths ??
I think go by mileage is a good as my mileage is about 4000km per year oil u dont change but oil filter u must change every 6 months as filter is made from
material that doesnt last and if I am not wrong is made from some kind of paper so after putting it in oil for long time it will corrude off. That y u see those super long milage can last for 12000km but recommanded filter change every 5000km or 6 months which ever come first.
Originally posted by enHANZed@Nov 24 2004, 09:27 AM
u DIY than ur used engine oil how ?
i will collect it in a plastic container and dispose it in the used bottle after oil change. then when going out i will drop by yishun industrial bike shops and discard there. Better be safe than sorry and to get caught n fined.
where did u get these royal purple oil. Are they semi syn?
yes the royal purple is fully synthetic oil, cos i have been using it for past one year. as it cost only $10.50 per bottle cos i jus recently brought. you can get it tanjung pagar block 2...
http://img.photobucket.com/albums/v703/kazuhikyo/combination1.jpg
The more I ride my SV, the less I care about going to the annual bike show and looking at new,
or expensive, or exotic machinery. I'm continuing to mod my bike into exactly what I want it,
and enjoying every mile I put on it.
Originally posted by redname@Nov 24 2004, 09:31 PM
dnt get R4, the quailty of R4 is inferior to those i've meant & cost quite ex too, $16 if i'm not wrg, rockoil is only $2 more. i wld recomend u get the motul 300V, $20 per bottle, gd stuff
ok thanx bro
bro how do i get to tanjong pagar blk 2. i live in yishun
in doubt ... how do you actually chane filter without changing the EO ???
meaning the filter itself contain some oil then you pour in more oil after changing huh ???
or you just change and do nothing ??? :confused:
<_________DO OR DIE DON'T ASK WHY________>
Normally oil filter is change together with engine oil, if you just want to change the oil filter, you need to drain out the engine oil first if not all the engine oil will leak out once you remove the oil filter.
And its not advisable to pour back the used engine oil into the engine again, as the container you used to hold use engine oil might be dirty.
My Z750 DIY Page
04 Z750 Specification
No need to drain out as all the oil is in oil sump but oil filter is located above it
But oil filter do contain some oil inside and u need to top up the different is about 200ml. i changed this week before I leave singapore. The oil flowed out still purple in colour so my oil still very new even I changed it this june.
I bought a new bottle to top up the difference. To mi is cheaper and not so messy.
mi now using total EO
heard it not advisable to use that rite ???
other then that brand other cheap and good brand to recommend ???
and where and how much you actually pay for the oil filter ??:confused:
u wan good product, b prepare to pay for it......if u can afford go for motul 300v, try n u noe the diff.......
No Time To Think Of One
