hi all nsr sp rider, i jus got my bike (sp) not long ago... and it giving me many problem, anyone noe wat could be d cause of engine stalling??? it always stall when bike coming to a stop, neurtal light light v.dim... at 1st i thought it lies wif d battery, but after replacing d battery, problem still there...
pls advice......pls
  • Replies 11
pls advice......pls
2 strokes bike doesnt really depend on batttery that much.
but if long term riding with a faulty battery might cause more harm to bike recifier.
1 good way to detect bad condition battery is when during idling time, head light is very dim, but when throttle, the head light turn very bright/normal.
Therefore chances of repeat stalling of engine due to faulty battery is pretty slim. Think your bike choke is jam or choke cable snapped alr.
when you start you engine in the morning or after long period of time stopping, did you notice if there any increasing of rpm to more then 2k and drop after abt 5 mins. If that the case, think you got a jam choke or snap choke cable.
finally, better send to your trust mech to check your bike.
safety 1st.. :thumb:
A second of precaution is an hour of safety. It never hurts to ask.
䏿‡‚å°±è¦é—®ï¼Œé—®æ˜¯ä¸ç”¨é’±çš„!
"Life is Neither Fair or Just"
check fuse too.
Dec 2005 - Sep 2007 Honda NSR 150 SP FS3*45M
Sep 2007 - Apr 2010 Honda CBR 400 RRL
Apr 2010 - Sep 2010 Yamaha X-1
May 2013 - Apr 2014 Kymco Grand Dink 150
Apr 2014 - ~~~ Kymco Downtown 300i
One life, Live it, Don't waste it!
My old SP
http://s223.photobucket.com/albums/dd94/SGGH/th_bike1.jpg
its best u change ur batt wif a new piece of rectifier, coz rectifier plays a major role in recharging ur batt besides the coil. shudnt be ur fuse as u said earlier ur lite are on.
Hi, can I have more details on this? My bike does that. It dimmed abit when idled and get back to normal when i open throttle. I tot that was normal?
pls advice......pls
2T bike stalling has got nothing to do with your battery.
Check your ignition coil, stator coil, exhaust valve ( the thing that rotates at the exhaust manifold).
Problem couild be your carb's pilot jet that is clogged.
If you have carb problems, this could also indicate your petroltank has got corrossion. In this case, install a fule filter before the petrol enters the carb.
Best is sent in to Honda's agent for service and please not to any FXXK-UP mototiams.
Hope this helps.
pls advice......pls
I encountered this problem before, not on SP, but other bike.
For my case was, when came to almost stop, I dropped gear from 2nd to 1st, the engine stalled. Or when there was a sudden brake and slowed down, from normal speed to stop, the engine stalled.
Increased the engine idling abit more, the problem solved.
mctan
new licenseee..whats ur idling rpm? for sp at least 1 and 2 strokes like that (meter at 1 and 2 strokes beside it lol) if urs below try tune it up? if other probs i not sure liao
i encounter this prob on the very first day when i took out my bike.. for mi it's the choke prob.. check out the bike shop bah :)
http://i150.photobucket.com/albums/s109/edalpha/StealthLOGO.jpg
for me my bike always stall when i at traffic light when i first got my bike, for me its my idling, just tune it abit to 1.4 liddat then ok liao
Passed 2B on 21st Dec 2006
Jan 2007 - KRR150 Kips
pls advice......pls
my 1/2 cent:
I'm riding a TA150, which I believe has the same engine as ur NSR 150. Faced the same problem previously, symtoms:
1) Hard to start, pull choke also don't work; has to turn accelerator up to start.
2) Normal idling become low...need to turn up
3) Stall when stopping.....hard to start after stall
4) Acceleration........slower due to percieve `lost' of power.
Action taken:
1) change battery - no difference
2) change sparkplug - no difference
3) Sent to 3 different shops......all point to either CDI or plug coil.
After more digging, got this info; Plug coil is a simple product, rarely spoilt. CDI lifespan approx. after 5yrs will start to die.
Finally, decided to change CDI.......all is fine today...:cheer:
