Selling off Dynojet PC5. used for onli 3mths. selling cos switch to YEC kit. $320
Dynojet Yamaha YZF-R6 Power Commander V
The New Power Commander V is loaded with tons of new features. It is compatible with 2008 and newer bike models. Below you will find some Power Commander V features.
Reduced size from PCIIIusb (less than half of the size of PCIII).
USB powered from computer (9 volt adapter is no longer needed for programming).
2 position map switching function built in (map switch not included).
Gear input (allows for map adjustment based on gear and speed).
Analog input (allows user to install any 0-5 volt sensor and build an adjustment table based on its input such as boost or temperature).
With gear position input connected the PCV is capable of allowing each cylinder to be mapped individually and for each gear (for example: on a 4 cylinder bike with a six speed transmission there could be up to 24 separate fuel tables).
Unit has a -100/+250% fuel change range (up from -100/+100%). This allows more adjustment range for 8 injector sportbikes.
10 throttle position columns (up from 9 on PCIIIusb).
Enhanced "accelerator pump" utility (increased adjustment and sensitivity ranges).
Selling off Termignoni Full titanium 'RACE' system with carbon end can. whole system weights less then 4kg. no scratch or damage.Top range exhaust system. Excellent exhaust tone and weight saving. Selling cos wanna try other exhaust. FREE SPARE ENDCAN UPON PURCHASE OF EXHAUST!!Custom made. Titanium sleeve. Lighter,sound n perform better then original Termi endcan.$1800.
[ATTACH=CONFIG]273851[/ATTACH][ATTACH=CONFIG]273852[/ATTACH][ATTACH=CONFIG]273853[/ATTACH]t4.jpgNew Image.jpg
Scorpion EXO-1000 RPM Gold Helmet size 'M'. No damage at all. no scratch or drop b4. Used less then 2mths n i hardly ride n its my spare helmet. Gd as new. $300.
Features:
AIRFIT CONCEPT: HelmetPump permits a rider to personalize helmet fit through air adjustable cheek pads with additional noise reduction. Only by SCORPION EXO!
Fiberglass/Kevlar Matrix Shell: Quiet, aero-tuned design for wind-tunnel tested comfort. EPS-lined chin bar for additional protection.
SpeedShift quick-change retractable shield system (patent pending): Easy, secure tool-less fog free Everclear faceshield changes in ten seconds or less. No adjustement needed: the shield retracts while closing.
KwikWick moisture-wicking helmet liner and cheek pads: Breathable, easily removable and washable.
Ventilation system:Adjustable, indexed front and rear vents with aero-tuned rear spoiler reduce lift, create vacuum and maximize airflow through helmet.
Breath-deflector: Enhanced fog-free performance.
Chin-cover: contributes to noise reduction. Everclear Shield: The most effective fog free shield on the market.
Certification: Snell/DOT Certified
Note: All Scorpion EXO-1000 Helmets come with clear outer shield and light smoke inner drop down shield.
EBC GPFA brake pads for both front calipers(2 sets). They r the top range pads from EBC. Selling for $150
Carbon fibre swing arm protector. To replace OEM plastic wit carbon. a little extra cosmetic look to ur bike. $70 SOLDphoto.jpg
Pls contact me @97554686 for more info. Low ballers pls stay away.
Edited by Blueblood
Aprilia RS 125
Honda NSR 150SP
Honda CBR 400RRR
Suzuki GSXR 1000K4
KIA Cerato Forte 1.6SX
Mitsubishi Lancer EX 2.0GT
Yamaha YZF-R6 12
  • Replies 59
Termig pipe isit with cert ?
No cert. for race use onli
Aprilia RS 125
Honda NSR 150SP
Honda CBR 400RRR
Suzuki GSXR 1000K4
Yamaha YZF-R6 12
