omg omg omg! YAY!
CHEERS FOR DANESIOUS~!~!~!~!~!!
so are we diy-ing or? :confused:
Moderator Note :
http://www.singaporebikes.com/forums/showthread.php?t=160110&page=6
This thread was spilt out from the a/m mass order. Members who had purchased this products kindly continue to discuss in this new thread.
Regards
Management
SingaporeBikes.com
http://i33.photobucket.com/albums/d54/amandaxp/topburanko.gifhttp://i33.photobucket.com/albums/d54/amandaxp/02982fc9.gif .
  • Replies 75
Alexandra village? Coz it's near ur workplace? :cheeky:
Collection only at Yishun tmr as i'm busy the next few days..Sat either Yishun or Serangoon..Msg me to confirm.
Yishun GOOD!! i stay nearby! wahahaha... u guys wanna DIY? I'm gonna go to SIM LIM 1st look for a suitable connector..
http://i101.photobucket.com/albums/m58/abm_shafiq/IMG_6747.jpg
#63
hmm.. bro ehem, when are u going to install yours.. i hope it's a day when i am not working.. so i can come down and ask for your help.... i am a klutz in DIY but with someone to guide, i think i can do it... hehehe
i collecting wif dan tonite..
maybe i will be installing it tml..
can i tap on the wire on the connector behind the meter??
i read from DG8 is "harness to the back of the clock"
:confused:
Okay sure, I wouldn't mind getting my hands dirty to DIY too,
Just wondering how are the instructions like, I believe it's a generic one and non-bike specific.
ehem, you're riding R1? If yes we probably might have the same electrical setup
I'm in to DIY
BTW Dan, please PM me your mobile, thanks
They have specific instructions for bikes tat are listed.. Not a generic one..
1999 - 2000 ~ Honda Hornet
2001 - 2002 ~ Honda Fireblade L-Model
2002 - ???? ~ Yamaha YZF R1 2002
2007 - 2008 ~ Yamaha X1
2008 - ???? ~ Yamaha Spark 135
Most Memorable Trip On My Bike - 1864 Corners
http://i197.photobucket.com/albums/aa285/danesious/DIGI0011-1.jpg
can someone PM me Dan's number pls.. might be getting the indicator from him today if it's not raining.
check yr pm..
I'm in to DIY
i'm riding an r6 actually, but normally, same manufacturers, same/similar color codes... trial and error using multimeter lor... normally voltage for tacho and speedo, similar.. 0-4v.. or higher, depending on manufacturer.. rev up engine, then can find tacho signal.. go into gear, then can see speedo signal..
mine, i'm gonna get my connector later.. then maybe get the stuff from danesious at 7pm... if too late, then most likely tomorrow nite.. my bike's at a tampines bikeshop currently..
#63
bro thx for the number...
so fast reply, not working issit?
doing my project..
relax for a while at the moment..
:cheeky:
Alright cool
Have you got your Starlane? I've gotten mine.
Btw, the connector, have you got it? How much did you pay?
Alright cool
i was 1st to collect mine lor.. hahah.. 6-pin connector at sim lim cost $2.30 only.(pins are included)
Now just need to get some wires and proper wire clamping tool..
btw, dont have to cut ur wiring harness.. try to squeeze the wires into the original wiring harness connector... then put the newly bought connector in between the gear indicator and ur bike connector..:thumb: if not, u have to cut lor..
#63
thanks dan for the MO..
i got my indicator and done it up juz now..
the item was great.. very accurate too..
thanks dan and ehem for the advice..
i squeeze the wire into the connector.. cos i not intended to do the plug type..
i have a problem.. the gear indicator works erraticly.. esp at gear 2 to 5.. eg: when at gear 3, the gear shows 3 den after awhile showed 4 without me changing gears.. sumtimes when dropping gears, the indicator maintain at 5.. did i do the set up wrongly?.
anyone care to help?..
u got half clutch when the thing happen??
:confused:
Hey Aalex82
Care to write a HowTo ?
when i free, i will write a detail write out on how i install..
:cheeky:
:confused:
i don't think so bro.. mebbe i will try again..
when u set up the indicator,what rpm did set ur shift light?
when u set ur gears, what rpm does the blinking numbers changed? do u shift gears accordingly?
i set up the gears before setting the shift light..
the device need little learning..
cos every gear i juz need to rev up to 5k then the device increase the number by one.. actually i was shock by the device learning that i tot can hav some time of allowance b4 switching my leg to change my gears.. i do it on a padlock stand..
my bike up to 8k rpm den number changed by one.. i did it on my mainstand though..
when u ride at slow speed, does the gear change accordingly?.. mine did not.. i am a bit lost here.. i think i did something wrong with the set-up but not really sure what.
if u need help, can call mi..
my number is on the previous post..
i need to rush to fetch gf off work..
:cheeky:
