had probelms starting my bike today..kicked and kicked for half and hour..try everything also no use..finally called tow truck..ended up my cdi was spoilt..changed a 2nd hand one ..($100) and all's fine now..
glad that your bike is ok now :smile:
There is a problems with my TA200. Actually I'm intending to send my bike down to planet tomorrow morning but want to do some enquires to find out how much I have to actually spend.
Okay, this is the first time I am experiencing this problem. When the bike is idling, the engine sound not constant. For example, the sound goes like "ta-ta-tatata". After idling for some time, the engine start to stall. Or on the road, when I coming to a stop(close throtter), the engine stall/dies off.
Have any bros here experienced this problems care to share their insights? Very worried have to do overhaul :giddy:
I too have this problem last month... its very bad the problem.. when Rain come. engine will stall...:
I went to Planet.. Mech tested by SPRAYING water at the SPARK PLUg there... then after a while, engine auto stall again... I changed the SPARK PLUG "HEAD"(he told me). Charges is $60.. now ok liao..
Bring down and check.... if not, raining, sure very bad.....!!!!!
Regards
5 Oct 2005 - Jun 2007(SP) FS6059X
18 Jun 2007 - 26 Nov 2007 -> CBR400, L model problematic FJ532*S
26 Nov 2007 - 12 Nov 2011 -> TA200, FV2X2G
12 Nov 2011 - 12 Nov 2012 -> SYM GTS200, FZ99*0D
29 Nov 2012 - 13 July 2015 -> KIA Rio HB 1.4M, SFY*
13 Jul 2015 - 28 Apr 2018 -> Kia Cerato V2 SKT*
28 Apr 2018 till current -> Hyundai Elentra S_trim SLZ*
Fellows,
Have a question here.
When i close throttle, my pipe Gives out a very Loud Sound, like "BACKFIRE" sound..
Wat is the problem? will it cause problems?
Pls advise....
Regards
Fellows,
Pls advise....
Regards
the problem is that your air / fuel ratio is unbalanced... right now it is too rich... just adjust it to make the mixture a little more neutral...
some people like to backfire on purpose... but it can't be good for your pipe :cheers:
I think pipe is the last thing to be worried about... think of the back pressure on the exhaust valve! :slurp:
Today any Bike Shop open?? my Phantom no Brake Light.....
lol... you don't need a bike shop to solve that...
1. your tail light is there... right...?
2. when the tail light is on, does it look like its just the normal tail light's brightness, or does it look like its the brake light that is always on?
3. assuming that your tail light is normal, put your ear at the front brake lever. tap the front brake a few times, you should be able to hear the brake light switch being triggered audibly... and yet no response from your brake light? the solution is simple... just replace the tail light bulb... the brake light filament should have burnt out... ah boy should be open (they close only one day per year) and the bulb should cost a dollar or so...
4. however if your tail light looks like its the brake light that is always on... check your front brake lever first, tap it a few times to hear if the brake light switch is being triggered... if the tick tack tick tack sound is there, move onto the rear brake pedal...
at the chassis where the rear brake pedal is, there is a wire connected to a hook, which is locked by a nut. at the end of that wire is a cable that connects to your rear brake pedal. if you do not know which wire I am referring to, stomp on the brake pedal a few times and observe the moving cables on the chassis...
what you need to do is to adjust the nut at the end of the wire... so that the pedal can trigger the brake light appropriately... its hard to explain the direction which the nut should go, so do try turning it through out its range... what you are looking for is that moment that your brake light is finally off, which means that your brake light should be triggered normally now...
try it out and tell me if your brake light issue is solved :cheers:
Go planet motors $1 only. One of the filament is broken. have to change new bulb.:clap:
Fellows,
Pls advise....
Regards
Could be too lean or rich. Could be your air filter being clogged too.
Fellows,
Pls advise....
Regards
I checked with Planet.. they say have to change the Tensioner..... $60... i was wondering really is the Tensioner problem or wat...
Hi bros
I just changed a front & back disc, front & back brake pad two days ago. The day i changed it, it produces a weird 'WONGGGG WONGGGG WONGgggg wonggg' sound from the engine which didn't occur previously before.
It only happens when the bike is coming to a halt upon slowing down.
I went back to the bike shop, the bike owner tested the bike and did not find any problems with it. I wanna know what could be the problem, sometimes these bike shops might be too busy to investigate the problems for you.
Hi bros
probabbly ill fitting or disc and pads. keep checking your disc.. might have cracks in time to come if not rectified.
byon you selling your phantom already ar? think i saw your post somewhere.
UPZ FOR GREAT INFO.
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Solution: Retune the carb.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
the weird sound only happens when i slow down and occurs only on gear one.
i think i know this . i also got that sound before . not very nice to heard it . check the disc and pad . if not check the big "thing" that hold the brake pad . maybe is the "thing" somewhere spoilt . this is what my mech told me .
paiseh . not very good at parts . just agar agar say out .
Phantom 200 - FU86XG - April2009 to Oct2009
RoadwinR 125 -FBE109XC-Nov2009 to Still Going On
its ur chain and sprocket that needs changing liao
J. P. Morgan
time to wash cubrator... if im not wrong.
hi,
Anyone care to advise why exhaust emitting white smoke on my TA150. This only happen in the afternoon (when hot) and not morning or at night?
is your bike overheating...if it so check your radiator and EO levels top up if necessary.. if you are loosing water all the time, jia lat ah..
hi,
:lol: ta150 don't emit white smoke then it'll be weird, your bike is a 2 stroker. As for why only in the afternoon? Beats me :lol:
hey peeps, by right, the choke should help to start up cold engines right? even for engines that are already warmed up shouldn't have any problems right?
And when the choke is open, the engine idling speed will increase right?
But funnily, when i start my engine which is already warmed up and i pull the choke, my bike dies off.
But when i close the choke, it can start liao..
Any ideas why? it's not supposed to do that right?
http://i87.photobucket.com/albums/k129/ckoonyin/ThenandNowver2a.jpg
