Hey dude, I doubt its the 好兄弟 pulling pranks on you at junctions :lol:
Anyway jokes aside, try tightening your spark plug or go with problem 2. Idling shouldn't change or change much due to riding vibration; I know our bikes vibrate alot.
:btw: you remind me that I've forgotten to go down to AMK to view someone's bike condition :lol:
Hey, my bike is fine today already, guess its really the sparkplug + rain...anyway will go play around with the idling also..think its a little too slow...thanks for the suggestions ! :cheeky:
12 Jun 2008 - Class 2B
28 Jun 2008 - Honda Phantom TA 200 (COE 11/3/17)
17 Jan 2009 - Class 3
27 Oct 2009 - Class 2A
28 May 2016 - Yamaha Fino 115 (COE 04/8/24)
9 June 2017 - Honda CB400 Spec 2 (COE 02/1/23)
bro i had the problem too... even a drop of water can stall ur bike.. i changed my plug cap and the problem nv come back again..
i have the same probs when rainning, haven`t had time to change the cap yet. But my bike also back fires alot, where is the screw to tune the mixture??
hmmm think something wrong with my break, no tension when i squeeze in, is it the brake fluid low??? hmm cause the previous owner, go and respray and spray the thing black also can't see.. so my front brake not working now
very good guess... either low or ur brakes are leaking fluid liao... u can check the brake fluid level by opening the two screws on the square box (brake fluid reservoir)... careful not to let any brake fluid drip on ur paintwork... wipe off immediately and rinse with water if kena... if low, can bring to mech or DIY top-up...
Unfortunately, none to contribute because fortunately, there haven't been problems with my phantom recently :cheeky:
I mean those solutions you've seen or offered to others which is not in this list dude :lol:
its on the left side of your bike, don't have a picture for you though. Or you can try meddling with your idling knob first to try? checked your air filter recently?
best to put a thick towel on tank with the handle bar locked to left. Else let a mechanic do it as he might also have to change brake pads(could be worn out or not properly installed)
i`ve changed the air filter bout 2 mths ago. after i changed the spark plug i notice the bike dying in the rain and the back fire
joe no tension at all might mean the brake lever unit spoilt...change the hwole thing roughly 80-85 at ah chong. i did it before so u better let him see if its the problem.
wahaha.. thanks for all the info, got it fix already, was the brake lever unti spoil and also my brake disc is out of shap, but the strange thing is i never knock into anything or fall down, so also don't noe why out of shape, total damage is 110, the brake dis is second hand de.. wahaha painful man.. cheers.. but cannot save on the brake man :D can save out life
haha glad to hear your problem solved..ride safe :thumb:
Please copy the template and add on your recommendations with smiles
jB :]
Solution: Its normal.
Problem 2: Engine stalls in heavy rain and unable to start.
Reason: Air fuel mixture may be too rich.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Solution: Retune the carb.
Reason: Clutch is worn
Solution:Change new bearings.
Hey, do you guys think this thread is worth to be sticky?
PM to let me know so I can put glue to it.
Cheers!
Women will never be as successful as men because they have no wives to advise them.
So we gotta decide what we should be about it:
1. shall we beats them up for opening new threads without doing a search?
2. Close their thread?
3. Argue with them and get into trouble?
4. Drive them out of this forum?
We all were once a newbie before and I believe I am still one now.
Some learn from their mistakes and some find it hard to swallow their ego and fight back.
So, when there is a issue, we need to find the root cause and get ride of it. So far I haven't got any solution for this.
I wanna hear your thoughts on this.
Oh man, I think jB really did put a good effort on this thread and I thought it'll serve good purpose for those who open new thread all over.
Damn.. looks like I have to delete many un-necessary post we created here. heh heh
Psst.. heard you clear meter eh.. wipe it real clean okie, so you can watch what speed you're riding.
Cheers!
well, not much people will read thru sticky but happy open new thread... :sian:
1. well I'd still say the search function ain't idiot proof like yahoo yet :lol:
2. would be good to pm them before/after you lock it and guide them.
3. We were once soldiers too :lol:
4. not nice to shoo others away :lol:
I don't know if it should be a sticky or not :nono: let the others decide..
sometimes I find that not everyone will pay attention to sticky or realise that its there because its not outstanding enough.
well, uncle vince... this is very informative thread indeed... but again i ask people around here (in PK forum, how many people browse through sticky section with many informative links and notes before posting new thread).
i really miss kiamh's PK directory thread.
since moderator is voluntary basic, we do not wish to burden u with loads of unnecessary moving and cleaning too.
if u see the thread needs to exist, just let it be... or if u think they fall under same category (like newbie questions, chit char corner) please feel free to do so as it is..
people come and go, so do threads...
after all it's free forum and we are free to post here :D
Put limit on who can start a new thread lor... sa like post counts >50 or maybe >100... at least it gives them 50 or 100 posts to learn before starting their own threads, and their participation being limited to the many many many threads of wide varieties should not be a problem. In fact even if you lao jiao in PK forum also no need to start new thread sia... everything all have liao. zzz
that's not upto PK's moderator's power i guess.
anyway, it's great forum and friendly people... just we bull$h!t alot :p
hmmm i suggest u all change the title la.. like' see here for ur phantom problem' don't put possible la.. very blur for new rider.. but this is a good post la.. help alot of new rider.. so thumbs up for u guys.. :D
