lol overhaul so exx.. so now worth it... best is to change Eo always... 1.5k change...
sparkplug 20k i heard...
vidak: what sparkplug and EO u use?? those cheap cheap de or?
errr... I use the cheapest denso plug and cheap fully syn eo... chessa chex 9000 10w50...
where you get the fully engine oil... cause i use my engine oil semi red t less then 300km... thinking of changing already... performance too bad ;-(
sparkplugs not 20k change?
my eo is from planet... $15
what problems are you facing?
for the plug... every time when you service your bike (e.g. when changing oil) ask the mech to take out your plug and see if need to replace or not
spark plug 20k?
i change every 2k plus
wow.u must be loaded..i.change at 10000 km..
20km is what most spark plug mfg recommends...
understand that spark plug does not affect FC that much...thats the reason why some people still change at 20,000 km..
EO 1.5k change is the best.
Spark plugs change every 2nd time u change EO.
If ur plugs melt and the head drops inside then GG liao.
if 5k gg den its not a spark plug...spark plugs are made to last for at least 70000km,
J. P. Morgan
if 5k gg den its not a spark plug...spark plugs are made to last for at least 70000km,[/quote
yeah some last forever...if u go to sungei road..second hand plug for sale..
Not only to see if plugs need changing. A used plug can tell you a lot about how well your air/fuel ratio is. A used plug can tell you if you should re-tune your carb.
Reading Spark Plugs (with pics)
Sparkplugs = $6?
Overhaul = Few hundred + Time + Hassle + Possible danger when bike breaks down.
U guys weigh it out. Sommore TA only use 1 plug.
Sparkplugs = $6?
although its cheap i agree, but the need to change so often is abit overkill i think...
its like rebuilding the engine block every year even the bike no prob...
sorry my analogy is known to be very exaggerated....
Cheers!
J. P. Morgan
hmmm diff people diff philosophy... for me is better i change than gamble with the possibility that it fail on me. No doubt i might spend abit more but if it rids of all the hassle i think its worth it.
Well, u never know when the plugs will fail on you. Actually, if im not wrong, what ur afraid of is the plastic parts melting off and dropping into your carb etc. If small piece then ok.. if big piece overhaul time.
For me is i dun want to save a $6 end up have to spend a few hundred.
Anyways, to each his own. cheers!
recently i just changed EO at unique motors at defu lane. $15 only, for FUCHS 15w50 EO and a denso spark plug. i find it super worth it cause previously i changed this exact EO at ah koon at $16, just for EO only. at unique, got EO and spark plug at $15 only. just sharing. :)
Edited by armani123sg
Its good to share what Orange shop does to its customers :thumb:
:btw: sometimes I do mine for free, my customers settle for me :p (Just sharing too teeheehee)
is that fully or semi EO?? so good deal only $15?
What a rip off. I was at unique. Planet also have the same deal but with NGK plug =) The Eo at planet is $10.. spark plug at $5. I dun really like the fuchs 15w50. If not mistaken, its base isnt good. After doing 1k, felt really rough and always caught in neutral.
btw. this thread is off topic. Initially wanted to go to orange shop.. Now blacklisted already.. abit too much.
btw denso sp vs ngk sp? which is better?
Edited by Hydher
bro, u serious that the FUCHS 15w50 is $10 at planet??? if so then next time i go there change. cause spark plug no need change so often.
unique u can choose denso or ngk, up to u...
n whats e orange shop? :)
Solution: Its normal.
Reason: Air leakages.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Solution: Retune the carb.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Problem 24: Where to get visor / assesories after 6.30pm.
Solution: Lim Ah Boy (Kelantan Lane around Jalan besar Hawker centre).
Problem 25: Can Phantom change headlights?
Reason: No reason in particular / cosmetics.
Solution: Yes. Can change and it all depends on your DIY / mech's skill.
Solution: http://www.pinkphantom.com - (Source to get nice headlights)
Solution: LAB - (Source to get nice headlights)
Read top for orange shop.
Call and ask planet. 67474740. Black bottle... Pretty sure. I really despise that eo though
