hi, interested in purchasing e brembo 16mm master pump wif a hel brake line package 4 my rs125... can u qoute me a price plz?
Hi boss, can I know how much is the Rcs 19? For r6 10 model. Cash n carry. Wana buy for my relative actually. Update me plz.. Thank u..
You have a PM.
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
  • Replies 272
hi boss, what is the current promo for the brembo rcs 19 ? do i need to make an appointment?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi, whats the difference between brembo rcs 19 and brembo rcs 15?
And which is suitable for yamaha Rxz?
Thanks!!
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Brembo 19 RCS Radial Brake Master, Brembo 16 RCS Clutch Master Cylinder....if get both any promotions? comes with standard or evotech reservoir?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
How much to get both 19 and 16rcs? for r6 2011
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi, Aprilia Rs125 can fit? both clutch and brakes.. if yes how much does it cost?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
All Brembo Master Cylinders are now in stock! While stock last!
RCS 19 Brake
RCS 15 Brake
RCS 16 Clutch
16mm Brake
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi bro how much is the rcs19 and rcs16 plus brembo calipers for s4 vtec3?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://i600.photobucket.com/albums/tt84/uniquemotor4/rcs19brembo.jpg
http://i600.photobucket.com/albums/tt84/uniquemotor4/bremboclutchfoldinglever.jpg
http://i600.photobucket.com/albums/tt84/uniquemotor4/rcs15brembo.jpg
http://i600.photobucket.com/albums/tt84/uniquemotor4/rcs16brembo.jpg
Best Regards
Kelvin 87178999
WL: Zul 84818999
Brembo M4 Monoblock Calipers Kit $1600.00
http://i600.photobucket.com/albums/tt84/uniquemotor4/Brembo_220A39710.jpg
Until now MONOBLOC calipers had been realized for a Super Racing use: the manufacture with particular material and in limited batches implied such a price which deterred the usage of this technology for calipers to be fitted on normal supersport bikes.
Brembo, through a relevant engineering work, succeeded in producing a monobloc caliper at an interesting price but keeping very high technology.
The structural design, of course radial, is MONOBLOC type as already said. Of course a real monobloc, like those used in MotoGP and SBK from the majority of the riders, that is to say without the lateral caps which hold the pistons. Brembo, unequalled in the world, developed this technology so as to assure unique stiffness and working precision.
TECHNICAL INFO: Fixing hole distance 108 mm and Off-set = 22,5 (perfectly interchangeable with the radial calipers of Japanese supersports, for some model spacers are required), 4 pistons Ø 34mm, 2 high performance brake pads,pads anti-vibrating springs,double piston seals, red Brembo logo, hand painted, identifying a Racing products
Brembo HPK "T Drive" Floating Disc Kit $1200.00
http://i600.photobucket.com/albums/tt84/uniquemotor4/Brembo_TDRIVE.jpg
A product of experience acquired in SBK and MotoGP, the brand new T-Drive is the next generation of product reflecting the natural evolution of Brembo brake discs engineered for competition use.
The key feature of the new T-drive system is an innovative method of transferring brake torque from disc to wheel, in which the conventional system of cylindrical bobbins are replaced by a set of eight “T” pins on the disc and eight corresponding segments formed in the disc carrier.
The special shape of the pins was developed following a targeted study of machining tolerances and ensures braking torque can be transmitted more efficiently, by offering increased resistance to thermal and mechanical stresses, especially under extreme operations such as those encountered in competition.
The connection between disc and carrier is assured by a special guillotine type interface (patent applied for), which allows both radial and axial float, as well as reducing the overall weight of the disc. This brings considerable advantages in terms of enhanced rideability, when compared with the conventional disc-carrier interface using round bobbins.
Brembo 19 RCS Radial Brake Master Cylinder - High Performance Brake Systems $550.00
http://i450.photobucket.com/albums/qq228/uniquemotor/brembo5.jpg
Brembo showcased the new 19 RCS, an update of the legendary product with a number of significant engineering features, all derived from MotoGP. The most unique feature of the Brembo 19 RCS (Ratio Click System) radial brake master cylinder is a patented device that allows the rider to choose between two settings, 18 or 20 mm, to improve either modulation or response during braking. Previously unavailable, this feature now provides a very simple adjustment that will give the optimum feel between rider, riding style, bike and circuit.
Brembo 16 RCS Clutch Master Cylinder - High Performance Brake Systems $550.00
http://i562.photobucket.com/albums/ss69/uniquemotor2/brembo9.jpg
The 16RCS clutch master cylinder makes up a set with the 19RCS. The 16RCS is equipped similarly with the Ratio Click System, allowing adjustment of the feel on clutch control. Like the 19RCS brake master cylinder, this component has a forged-aluminum alloy body with hard-anodized surface finish.
Brembo 15 RCS Radial Brake Master Cylinder - High Performance Brake Systems $550.00
Intended specifically for Naked and SuperMotard machines, the 15RCS master cylinder has all the technological features of the 19RCS - the M/C most popular with enthusiast - namely the Ratio Click System, the same component specifications as for MotoGP system, hard-anodized cylinder body, and folding lever. With the 15RCS, the user can change the lever pivot distance from 18mm to 20mm simply by turning the adjuster inside the cylinder. This brake M/C can be matched with the 16RCS clutch master cylinder, giving a set-up that will deliver MotoGP performance, as well as being a real attention-grabber.
Brembo 16mm Master Pump + Clutch Assembly Package: $388.00
Brembo 16mm Master Cylinder Assembly: $288.00
Clutch Assembly Package: $128.00
http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs517.ash1/30469_405181132105_160394947105_4555925_4772397_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs557.snc3/30469_405181137105_160394947105_4555926_3878478_n.jpg
*Please check 1st post of this thread for latest updated pricing. Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Brembo Calipers + Brembo T Drive Floating Brake Discs + Brembo RCS 19 on Yamaha FZ1
http://www.facebook.com/media/set/?set=a.1493308229164.52305.1727814660
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://i600.photobucket.com/albums/tt84/uniquemotor4/DRZbremboupgrade.jpg
Suzuki DRZ400SM Brembo Upgrade Kit
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://i600.photobucket.com/albums/tt84/uniquemotor4/Bupgradekitall.jpg
Brembo Upgrade Kit:
Brembo 19RCS $550.00
Brembo 16RCS $550.00
Brembo M4 Monoblock $1600.00
Brembo T-Drive Floating Disc $1200.00
Brembo Folding Clutch Lever $295.00
This kit fits the following with*OE sized brake rotors:
Honda CBR1000RR 2006-2011 (320mm)
Honda CBR1000RR 2009-2011 ABS (320mm)
Kawasaki ZX6R 2005-2011 (300mm)
Kawasaki ZX10R 2004-2007 (300mm)
Suzuki GSXR600 2004-2005 (300mm)
Suzuki GSXR750 2004-2005 (300mm)
Suzuki GSXR1000 2003-2001 (300mm)
This kit fits the following models with*Oversized brake rotors:
Honda CBR600RR 2005-2001 (320mm), OE size is 310mm
Honda CBR600RR 2011 ABS (320mm), OE size is 310mm
Honda CBR1000RR 2004-2005 (320mm), OE size is 310mm
Honda CB1000R 2008-2011 (320mm), OE size is 310mm
Kawasaki ZX6R / 636 / RR 2003-2004 (300mm), OE size is 280mm
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/311157_10150287938762106_160394947105_8053212_1802614911_n.jpg
Brembo Upgrade Kit
Brembo 4 Piston Calipers + Caliper Brackets Kit $888.00
Edited by Unique_Motorsports
Best Regards
Kelvin 87178999
WL: Zul 84818999
Brembo Upgrade Kit
Brembo 19RCS
Hi please pm me the price. Isit for the front?
Brembo Upgrade Kit
Best Regards
Kelvin 87178999
WL: Zul 84818999
hi boss, i wana if i am able to take up the Clutch Assembly Package: $128.00 if my bike is on hydraulic clutch now? thanks you for your reply
Aprilia RS125 03 (2008 - 2011 June)
Ducati Monster 400 97 (2011 - Present)
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Brembo Upgrade Kit
hi kelvin, what is 4 piston calipers plus calliper bracket kit? S4 only got 3 callipers..
