its a weird size. 23mm can't fit, 24mm on the loose side... so i use a 24mm spanner, but u hv to be very careful. its easy to slip the spanner and round the drain bolt. b4 replacing, check that ur o-ring is not flattened. if it is, change it or else could leak.
  • Replies 849
1.5L of Eo will cause your gasket to Explode. WHen oil heated up , it will expand hence will damaged your Engine gasket which may also lead to Overhaul of your Engine.
just to play safe, put 1100L of engine Oil will do.. I just had my Oil changed today at Planet motors. I got myself 1L of chex9000 and 100ml of motul300v Oil... not too bad!!!
gasket won't explode lah. Unless Ur crankcase don't have a pressure relief vent (a tube from crank case to airbox.)
Even without crankcase vent. The end result is sluggish engine and at max foaming engine oil (especially when the oil is near it's end of useful life.)
Plus maybe leaking of oil at crank seal.
anyone know the price for Mobil 1 - Racing 4T 10W40 ????
2002 to 2003 - Honda NSR 150
2003 to 2004 - Honda XR400 SM & Honda CBR400
2004 to 2005 - Yamaha YZF R1-03
2005 to 2006 - Honda Super 4 Spec II
2006 to 2007 - KTM 525 SM
2007 to 2008 - Kawasaki KSR 110
2008 to 2009 - Kawasaki KSR 110
its $18 at mxtradings. same price as the vtwin 20w50. overseas forums have pretty good comments so far. im using the 20w50 one now. its smooth and good value for a fully synthetic.
@naim: How do you find 50 weight? Wondering if I should change to 40 weight this time or stick to 50 weight
i prefer 50 wt. may be a little more draggy than 40 wt, but i would trade sum acceleration for more protection.
Ok thanks, I know all 50 weights are not created equal and there is a huge range in the viscosity. I wish someone who has tested different oils can give their view. I have only tried Motul 5100 on my phantom and it does feel a bit draggy and the need to overgear it. I am wondering if a good quality 40 weight FS oil(may be pennzoil) can provide the same protection as a 50 weight and at the same time is more revvy.
mechanics recommend to use mineral oil instead of synthetic oil for old engine. as the mineral is thicker and suitable for old engine.
mine has been overhauled recently, so it can happily run synthetic. b4 that, my engine was blowing-by. so wen i run on synthetic, the engine oil was evaporated more quickly than mineral. so ur theory is still somewhat correct. :)
i tink protection wise can only be determine over a few years, and the engine is torn apart to check for the wear & tear. but im sure a good brand FS can hold up to the abuse be it 40 wt or 50 wt. oil analysis can also determine how long the oil stays at the same weight (oil thins out as its being used). i just prefer to be on the safe side wif the higher viscosity. :)
  • 5 months later...
i am riding a 7yrs old phantom, just owned for 2mths
i need some advices, should i use FS oil? like thumper or chex 9000 or motul-300v mentioned above?
or just stick to my current $7 castrol EO? (just changed ~1mth, already hit 1k km)
i hope to get an EO that creates LESS / MINOR vibration, LESS noise, SMOOTH gear shifting within 2k mileage
pls advise... 10Q:)
pls advise... 10Q:)
Am riding a 9 yrs old phantom and using Petronas FS + Oil Treatment, recommend by ah koon & have no regrets for the hefty $33/-
@naim
thanks for advice, now i am trying chex 9000, compared to previous castrol 10w40 (from LAB), chex 9000 feeling a bit more vibration, draggy & a bit harder to shift, not sure what's the reason... anyway, exhaust sounds nicer (slight louder & deeper bass)
@Ray Oliver Donovan
next time i go Dr Koon there try..
@trex101
where u get this Schaeffer 20w50 V-twin? n d selling price is? 10S
added review for Shell rimula r3x 15w40 HDEO
http://www.mxsouth.com/belray/belray-oil-lubes-thumper-racing-oil_1.jpg
Belray thumper 20w50/15w50(new formulation)(Unique motorsports/hkl) $18
Hydher - After 1000k,gear shifting was slick 4.5/5
TheChosenX - I loved it to the end. Only after 1000k++ that the throttle is smoother and engine has lesser vibration. 4.5/5
http://www.castrol.com/liveassets/bp_internet/castrol/castrol_malaysia/STAGING/local_assets/images/products/mco_power14t_malaysia_375x253.jpg
Castrol Power 1 15w40 (Thailand) 100 baht / S$4.26
VidaK - Gear changing is a little stiff, engine sounds rough and top speed is much lower than before 2/5
jianping - worst EO on my bike, engine feels less powerful,noisy and rough.. need to throttle alot more to attain 90km/hr on expressway.. avoid this.. i bought at $12.. 1/5 :nono:
nbk3 - used it for running in, around 200-300km, sticky gears. $7. wudnt recommend for long term usage. 2/5
Castrol Power 1 Racing 4T 20W50 Fully Synthetic - $22 from Eversuccess (DIY)
naim- used it for 1500km and felt almost like Chex 9000. good value, though abit ex, but vibrations was nt bad and acceleration still OK
http://img227.imageshack.us/img227/3716/dsc00359e.jpg
Chessa Chex 9000 10w50 (planet) $16 (UM) $18
VidaK - No gear changing problems, or other problems. Although there is more vibration then quality oils, it is good value for your money 4/5
jtzx- Great fully syn Eo. which is value for money which can last at least 2.5k millege 5/5
armani123sg- gd, no problems but didnt feel any diff comparing to FUCHS brand.
naim - awesome value for money. the smoothness is remarkable considering the price. but felt it become a little rough wen hitting the 2k mark
TheChosenX - Didnt like it at all. Was very rough all the way. And even in my new bike it evaporated almost 20% of it. But then again is value for money. 2/5
http://img401.imageshack.us/img401/5391/photodw.jpg
FUCHS Silkolene 15w50 (planet) $10
byon - very good at start, throttle on and i can feel the pull from my bike never before. significant performance degraded after 1k.
Hydher - I hated it after 1k, gear changing was rough as hell and stuck at neutrals 2/5
armani123sg- gd, no problems but didnt feel any diff comparing to CHEX brand.
icearmour- gear changing was very hard..too much vibration as well..changed after 500km...1/5
nbk3 - very good at the start, smooth gear change, rev ups, masks sound/vibrations rather well, after 1k km, sticky gear, hard to engage neutral, at 1.5k km, impossible to engage neutral unless engine off, cheap. 2.5/5
http://www.cbxmanmotorcycles.com/Aftermarket-Motorcycle-Products/Chemicals-Lubricants/4-Stroke-Motor-Oil/Maxima-32901-Maxum4-Extra-100-Synthetic-4-Stroke-Motor-Oil-15W50-1-Liter-Bottle.jpg
Maxima 15w50 extra (planet) $21
VidaK - no problems with the bike, but compared to the chex, this oil lost outright since its much more expensive... 3/5
icearmour - no problems, speed, smoothness, vibration etc all are at decent levels...but not the best in anything so 4/5
http://www.cbxmanmotorcycles.com/Aftermarket-Motorcycle-Products/Chemicals-Lubricants/4-Stroke-Motor-Oil/Maxima-35901B-Maxum4-Synthetic-Blend-4-Stroke-Motor-Oil-20W50-1-Liter-Bottle.jpg
Maxima 20w50 synblend (planet) $15
Hydher - Was used for long distance travelling. Was soso. 4/5
nuttybing - can feel the roughness in changing gears after around 1300km, so so only 3/5
http://www.cbxmanmotorcycles.com/Aftermarket-Motorcycle-Products/Chemicals-Lubricants/4-Stroke-Motor-Oil/Maxima-36901-Maxum4-Ultra-100-Synthetic-High-RPM-Formula-4-Stroke-Racing-Motor-Oil-5W50-1-Liter-Bottle.jpg
Maxima 5w50 ultra (planet) $23
VidaK - No doubt it is a good oil, but it is a little expensive 3.5/5
http://img210.imageshack.us/img210/9615/img0237e.jpg
Mobil 20w50 $7
naim - using this cheap mineral EO for running-in.. so far so good.. using it at 500km intervals (kiasu! haha!) but actually not dat bad.. quite value for money.. just shorter OCI is recommended.. good gear change and tolerable vibrations..
http://i16.photobucket.com/albums/b35/adiknaim/300V_15W50_1L.jpg
Motul 300v 15w50 (planet) $28
VidaK - The smoothest is unreal. In fact top speed increased. 4.5/5
ckoonyin - very smooth; last me until 1000km before it started to get rough 4/5
ckoonyin - 2nd time using it again, damn smooth, gear changes are very positive. engine vibration is noticably muted compared to Motul 7100
icearmour- overall smoothness increased nicely:thumb:vibration still there but slightly lesser....4/5
http://www.amsoil.com/StoreFront/images/MCF_900.jpg
Amsoil 10W40 (UM) $28
TheChosenX - Really like this oil. Used it for 3k before i change the next and still smooth. A little expensive but i like the smoothness of it. 4.8/5
Motul 5100 15w50 (semi)
nuttybing - Gear changing is really smooth, can feel the power along with the throttle, around 2000km can feel it deteriorating 4/5
ckoonyin - roughness was similar before i did EO change from Motul 300 3/5
http://img809.imageshack.us/img809/9716/7100fullsyntheticesterm.jpg
Motul 7100 10w40 100% Syn Ester $22
lycan - still trying it out. feels smoother than Motul 5100.
ckoonyin - not much diff between Motul 5100
TheChosenX - Trying it out for the first time. Throttle is so much smoother and more responsive. But nosiy compared to my thumper 20W50.
NASA [Which series?]10w40 (planet) $10
Hydher - Not bad in all rounders even price. 4/5.
jtzx - pick up quite bad but over all good.. 3.5/5
armani123sg- acceleration faster, nicer sound, better than the FUCHS and CHEX but my FC decrease from usually 40km/hr on FUCHS/CHEX to 37km/hr on NASA... :)
http://i239.photobucket.com/albums/ff37/hydher/bike/IMG_9969.jpg
Putoline SUPER DX 4 SEMI SYN $8 LAB
Rating 2.5/5. Useable for 2k and you get what you pay for.
http://i239.photobucket.com/albums/ff37/hydher/bike/IMG_0242.jpg
Total 15w50 $8.90
jtzx - Bought this at carefour for only $5.90 for my DIy oiler.
http://i227.photobucket.com/albums/dd246/tosco1122/HR50white.jpg
Verity 15w50 fully synthetic (planet) $26
VidaK - It is very good, but not the best. Quite expensive also... 3.5/5
Amsoil 10w40(25$)
icearmour- gear changing is the smoothess among all..less vibration and as good as motul 300v..top speed not so great so 4/5
http://i16.photobucket.com/albums/b35/adiknaim/liquimoly.jpg
Liquimoly 10W50 Fully synthetic (Equipment Extreme) $24
naim - very smooth. very slick gear changes. doesn't get rough at full throttle. vibration is strong due to its thickness, but u can feel that its smooth. though abit expensive. 4.5/5
http://www.honda2wheelersindia.com/images/honda-genuine-oil.gif (Thai version) $12
Original Honda Motor Oil 0W20 Similar to the picture except the words are all Thai.
Icomeforyou - Loved this motor oil, cheap and good. Smooth, and gear is smooth. The oil once changed you can feel its thickness. My vehicle was "growling". Top speed okay, not much improvement, but riding is smooth. Best utilized at 85 - 95 there abouts. Can feel it starting to break down around the 1k~1.5k mark
http://www.singaporebikes.com/forums/attachment.php?attachmentid=218300&d=1315147274
$10
nbk3 - its a 10w40 which meant its relatively light. doesnt mask vibrations or sounds as well as thicker oils.fully syn. so far so good. on expressways u can sorta makeout the engine churning the oil away.hmmm. so far so good. 3/5
http://i16.photobucket.com/albums/b35/adiknaim/53-3100Mobil120W50.jpg
Mobil 1 V-Twin 20W50 Fully Synthetic - $18 from MXTRADINGS (DIY)
naim - best value for money oil i used. the difference from Castrol FS 20W50 was alot! smooth n effortless gearchange. vibrations lesser as well. will update if it withstands well to my 1500km OCI.
Mobil 1 Delvac MX 15W40 HDEO - $11+ (DIY)
naim - cheap n good. smooth gearchange and good clutch feel. feels like it breaksdown after abt 1000km. very watery wen drained after 1500km. recommended for short OCI.
Shell Rimula r3x 15w40 rm71/5L DIY
nbk3 - used for over 8000km and 3 oil changes, it has been delivering decent performance so far, no slippages at all and engages clutches firmly and responsively. not able to mask vibrations well and only starts to truly feel much smoother after ~1000km. definite value for money at ~sgd6/L. overall 3/5
Hi Guys,
May I suggest that your particular engine oil chosen will work best together with MSP Engine Oil Enhancer.
Please click for more information
http://www.singaporebikes.com/forums/showthread.php/362124-lt-CMO-gt-MSP-Engine-Oil-Enhancer-Today-s-Most-Technologically-Advanced-at-Great-Discount
Few years ago, a CityCab taxi had been accidentally driven into the swimming pool at Kentish Lodge in Balestier by 55-year-old Ling Hong Lim during a heavy downpour.*
The vehicle A spokesperson for CityCab said it will remove the taxi after the pool is drained. This is expected to take a day and the company said the taxi will be good enough for the road again, but only after an overhaul.
An "overhaul" would have cost around SGD$10,000 and take at least 3 weeks. However, MSP came to the rescue 28 days later and fix the taxi within a day! Please see below.
MSP Car Recovery Part I
http://www.youtube.com/watch?v=wpR6_EBsEnY&feature=relmfu
MSP-Car Recovery Part II.wmv*
http://www.youtube.com/watch?v=MoF76ocOG0k&feature=relmfu
Hi guys. I just bought a Phantom on saturday. Will be collecting next sat. Just wondering how often do you guys change your EO?
2A - On going...
1500km to 2000km for fully synthetic is the norm.
Ok thanks. Will be collecting bike this sat. Comes with new EO. Will check the mileage travelled then change EO.
2A - On going...
Hi Spark, for a reasonable full syn, some people do 4-5K before oil change. Oil degradation is dependent on varying factors such as riding style, traffic environment, quality of engine oil, age of bike and so on. Some gurus advise that you could continue to use your bike as long oil still good and not too dirty, the bike still works and feels alright close to when the oil is new.
Thanks! Will take note of that. Anyway changed price to Motul 300V from $28 to $30. Planet now sells at $30.
Mobil 20w50 $7
Motul 300v 15w50 (planet) $30
Total 15w50 $8.90
Amsoil 10w40(25$)
$10
[ATTACH=CONFIG]250131[/ATTACH]
2A - On going...
Where to buy the shell rimula oil?
I just bought Schnell Fully Synthetic 5w40 meant for cars at giant. $24.99 for 4L. hehehe
Edited by Hydher
I use Agip 20W/50 the best for my bike change every 2k base on my usage @$14 but recently my bike shop say the boss close down is that truth? I switch Motul 20w/50 my bike don't like this oil vibration too much compare to Agip! Haiz...
http://tripdrive.blogspot.sg
