Originally posted by cs_kup_oh@Nov 2 2005, 03:02 PM
iszit?
but i have been using semi at about $12
so i kena chop la??????
:giddy:
If it is Castrol Power1 4T $12 I think is ok. Where got kanna chop? Dat one is abt the price la for Castrol POwer1 4T.
History n Present ride
  • Replies 638
Originally posted by sky_80@Nov 2 2005, 12:15 PM
R4 where got so cheap?
think market price around $18 leh.........
that one should be the Power 1 castrol lah........ :giddy:
R4 can get $14 at HKL
fully-syn always cost more than semi-syn.
http://www.picturesky.com/albums/userpics/12200/sbf.jpg
| 01.1999-01:yamaha | 02.2001-02:suzuki | 03.2003-03:piaggio |
| 04.2002-04:suzuki | 05.2004-09:honda | 06.2009-04:honda |
hi
jus wan to ask something about chain
u all know the part where the "gear like thing " holds the chain at the rear wheel part, is it supposed to be fixed, or can move huh?
Honda Wave 110s - FT7476M
Honda CG 125 ----- FK7947T
Suzuki Bandit 400 - FM 8039Y
Yamaha Fazer 6 --- FW7537E
Honda Steed ------- FN 5565R
Yamaha YP 250 - FS2578R
Suzuki DL650 ---- FX9497T
u mean e roller to hold e chain ?
it can move 1 but mine 1 seem like cheap brand use 1 week e whole thing came off n also bo chap cox find it useless :cheeky:
http://www.tactics.ne.jp/~baseson/koihime/image/staff_kanan.gifhttp://www.tactics.ne.jp/~baseson/koihime/image/staff_katagiri.gifhttp://www.tactics.ne.jp/~baseson/koihime/image/staff_ringo.gifhttp://www.tactics.ne.jp/~baseson/koihime/image/staff_yuukisan.gif
but is it supposed to rotate when your tyre is not moving?
MERGED THREAD
Topic : wave + 2T
Description : faster meh....?
hey guys... this is wat my fren told mi de... wave to 2T in our petrol tank...
i dunnoe the ratio of how much 2T to petrol la...
Is it true? will the engine give way..? Or any side effects....?
I tried once.. it really gain power.. once ur petrol finish...
2T also finish liao... but i still scared scared leh....
Pls ease my scareness thanx! :confused:
Riding is a Passion, Once a Rider, Always a Rider
:cheeky::cheeky:
2T does not burn and may get stuck in ur valves .
dun do that again .
u may spent more money cleaning the engine ,carbs and valves
here in the philippines we use repsol 4t 15-50w (mineral based) for the 1st 500kms then same oil when you reach 1000kms, after that you can use repsol sintetico 10-40w (synthetic based) oil and change your oil every 2000kms. :thumb:
NO!. u dun wan to change a new engine bcoz of 2T. yes its more powerful as it is a lubricant but it wil jam ur valves soon.. better go service n clean it.
Originally posted by 168km/h@Nov 6 2005, 02:48 PM
2T does not burn
Serious huh ??? dun joke leh !
http://i16.photobucket.com/albums/b12/Ah_Hia00/Thai/MaeSod.jpg
My Bike Outside The Immigration Checkpoint of Mae Sod(Thai Mynmar Border), Mae Sod, Thailand
25th Dec 2005 to 9th Jan 2006
Singapore - Malaysia - Thailand
Total Distance Covered ~ 7000+ km
Originally posted by RxzDelux@Oct 29 2005, 12:43 AM
But i heard dat Castrol R4 is hydrocrack Group III oil somewhere in the forum i think. To each and everyone preference.......
Yeah it's true but Castrol have won a long standing court battle and court ruled thier hydrocracked is synthtic....
I'd rather stick with ester based oils any given day !
huh...? so serious ar.... so how to i ask 4 cleaning? clean wat i tot clean
engine is overhaul liao huh? any trustworthy shop to recommend?
thanx:cheer:
:cheeky::cheeky:
i use maxima semi syn gear oil lei. so far so gd. fully too thin as wave is air cool, need a thicker oil for better protection.. juz my 2cts.. :smile:
i still thinking of whether is gear oil suitable a not...dun reallie know the diff between gear oil and the normal semi / fully syn / mineral oil..
I change ard 1k plus using fuchs comp4
Ester based? As of i know only RockOiL,Motul and Fuchs Silkolene have ester base. U using which one?
U forgot Redline and Maxima.....
My ride is on Maxima for now....
Fully Syn 15w50 is too thin for u ??
Gear oil about 60-80w....
it's too thick.....
Gear oil best used for separate gear box like harley, 2 stroke bikes.
4 stroke bikes like Wave is better run on fully syn oils.
Cuz fully syn oils hold their properties longer and thus offer more protection when really need. Whereas semi or hydrocracked oils break down faster and offer less protection to heat.
*Wai*
Fully too thin? I don think so la. I got used before Maxima Extra 15W50. Works wonderful. Where got too thin? The only thing dat i don like abt it is dat it last only aabt 2085km on my wave. Sianz. :sian: Other than dat what i can say Maxima Werks!
It's because u said it's ester base. Ester base means not fully ester. Dat's why i opt Redline and Maxima out. Redline and Maxima most of their products is 100% polyol ester which is why their price is more on the high side.
As for Fuchs Silkolene i think only Pro4 Plus is 100% polyol ester.
Which Maxima u using? Is it the Extra15W50 or Ultra5W50? :confused:
Originally posted by Thai_R@Nov 8 2005, 01:16 AM
4 stroke bikes like Wave is better run on fully syn oils. Cuz fully syn oils hold their properties longer and thus offer more protection when really need. Whereas semi or hydrocracked oils break down faster and offer less protection to heat.
*Wai*
Ya It's true Wave is better on fully synthetics because it may offer more mileage and protection dat is if u can afford it. Fully synthetic r expensive!
Whereas semi or hydrocracked oil break down faster and offer less heat and protection to heat?
I don think so. I have been using my Wave on most range of engine oils be it expensive or cheap and now I am still running it wif Hydrocracked oil. Bo taiji. As long as u keep to the drain intervals and monitor the engine oil level. Should be no problem.
To each and own preference.
:cheers:
Get this if u can afford
REDLINE or MAXIMA.
Beware though the price is on the high side. One bottle can range between $20 till $30.
Sorry i meant ester as the base stock.....
not ester fortified like Motul 5100.....
