Hey guys
I'm riding a version S. Used to get 24km/L.
Recently changed to knobbies and rear sprocket changed to 40T. and my fuel consumption gradually went down to 21km/L, 20km/L and now about 19km/L. if it is due to the wheel/sprocket change, the change would be immediate, not gradual right?
Any idea what else may be the problem?
I've changed EO and spark plug, still same problem.
Of course I trust my skills. I ride alone cos I don't trust the competency of the driver next to me.
Anyone can help??
Y my vtec 1 travel 250km reserve Liao.. Pls advice
2005-2006: RXZ
2007: Y125Z & RVF400
2008: RVF400 & African Twin
2009: African Twin, GSX1300RK2, Renault Kangoo(A)
2010: GSX1300RK2, Renault Kangoo(A)
2011: GSX1300RK2
2012-2013: GSX1300RK2, Proton Savvy(A)
2014: Proton Savvy(A), Super 4(S1)
Present: Super 4(S1)
Anyone can help??
Check :
Airfilter
Spocket (front / back)
Chain
Tyre
Wheel bearing
The way u ride
My vtec 1 also having bad fuel consumption. Only can get 16km/liter. Using yoshi full system, knn airfilter, carb stocknsetting but got tune because of exhaust. I tried changing the clutch plates all that. Also never improve my fuel consumption. Any one knows what is the problem?
Bikes ridden
1) Aprilla Atlantic 200 FZ 3782 Z ( 2010 - 2011 )
2) Honda Super 4 Spec 1 FS 9698 G ( 2011 - 2011 )
3) Honda Wave FBF 560 U ( 2011 - 2012 )
4) Honda Super 4 Spec 1 FS 8002 X ( 2012 - 2014 )
5) Honda RVF ( 2013 -2016 )
6) Yamaha Tmax 530 ( 2014 - ???? )
7) Yamaha X1R FBC 259 G ( 2017 - 2017 )
8) Ducati 1098S FBB 6006 K ( 2016 - 2017 )
One think u can also check is the header manofold. See got air leaking out anot. That may effect the FC too
Sent from my GT-I9505 using Tapatalk
Using stock sprocket size?
If up/down size might affect the fuel consumption. Also check the connector to the airbox got any air leak due to old bike and rubber also worn out.
Current Ride:
W650 Cafe Racer
FXSTC Softail Custom
TW200 Tracker
Zephyr ZII Custom
CB750K
CB400four
Hi guys, I'm riding a 2004 spec 3 bike fully stocked. Just got it about a month ago and my FC is very bad. When I hit 200km my petrol gauge starts to run already. Any idea why my FC so bad? I'm still a newbie so I need all the experts to teach me a thing or two about super 4. Thanks!
http://i276.photobucket.com/albums/kk7/fireimmortal/footballg.gif
Daelim Roadwin R125 2011 - Now
Honda CB400 Vtec 3 2014 - Now
Possible reason for bad fuel consumption :
-Airfilter (Dirty/ Clogged up)
-Spocket (Worn out/ Not standard size)
-Chain (Not lube/ Chain too slack/ tightened)
-Tyre (Worn out/ Incorrect Pressure) ( Wrong size)
-Tyre Valve (Leaking air)
-Wheel bearing (Not in good condition)
-Engine Oil (Wrong grade/ Due for change/ Too much)
-Carburetor (Air/ Fuel not balanced) (Jetting not stock)
-Fuel (Contaminated/ Low grade)
-Fuel line/ filter (Clogged)
-Meter (Inaccurate/ offset)
-Rider (MotoGP mood/ Fuel-conscious type)
-Clutch (Clutch plate/ spring worn out)
-Header Gasket (Worn out)
-Weight (Heavy luggage/ pillion/ rider)
-Idling (Too High/ low)
-Engine braking (Too much)
-Abrupt braking
-Hard acceleration
-Engine condition (TOO much to explain)
-Brake Caliper/ Brake pad (Brake Caliper piston jammed?/ not free)
-Improper suspension set-up (Too hard/ Too soft)
-Servicing (Do on time, dnt overdue)
-Idle too long (Waste petrol/ Engine hotter/ coolant affected unnecessary/ WaterPump work harder to maintain temperature)
Tats all I can think off, for now. :cheers:
Edited by HaiR1
Sorry didnt see the above post which is very well explained. That post should be stickied!
Thanks man..
Just my Possible reason:thumb:
-Engine Oil (Wrong grade/ Due for change)
-Abrupt braking
-Hard acceleration
Wow, thanks for the advice. I guess I'll have to go through a heavy servicing for my bike. Anyone know which shop would be best to do it and cheap?
Good is not cheap
Cheap is not good :thumb:
Good is not cheap
:thumb: :thumb: :thumb: :thumb:
Current Ride:
W650 Cafe Racer
TW200 Tracker
Zephyr ZII Custom
CB750K
CB400four
Good is not cheap
lol.. i meant reasonable pricing, not those overcharged type de..
i was thinking of trying Unique Motorsports.. should i?
Depends..
My suggestion, find 1 shop/ mech to attend to your bike.
I have RaceWerks to attend to mine
Ps: Some shop out there change mech like changing shirt, not permanent
I did all my Bikes servicing at a shop at woodlands. so far the mech is a nice guy,will not anyhow over charge.
Sent from my 2013023 using Tapatalk
Current Ride:
W650 Cafe Racer
TW200 Tracker
Zephyr ZII Custom
CB750K
CB400four
Anyone riding spec 1? How is ur fc? Mine is about 15l/km.. Hit 225km light start to run
How many liters left when light start to run?
2005-2006: RXZ
2011: GSX1300RK2
15L/km is not normal. My Kawasaki 750 already getting 19.75km/L
Need full servicing already.
Current Ride:
W650 Cafe Racer
TW200 Tracker
Zephyr ZII Custom
CB750K
CB400four
Price is one thing , Quality & Knowledge is another
So far so good. I have few bike done up by him. Very happy with the result.
Current Ride:
W650 Cafe Racer
TW200 Tracker
Zephyr ZII Custom
CB750K
CB400four
hi guys..need help,where can i go to change my fuel jet for spec3? cos my fc is very bad..planning to change just the jets not as a whole set..and how much wud normaly the shop quote?
Yo Bros,
Try BROQUET Fuel charger to get better power and FC
Super4 Bikers user reviews at my sales thread below.
http://www.singaporebikes.com/forums/showthread.php/235030-lt-CMO-gt-BROQUET-Fuel-Charger-(UK)-NEW-(Torque-Top)-DUAL-MODE-SELECTOR-Voltage-Stablize?highlight=
https://www.facebook.com/pages/Vtec88-Used-Bike-Parts-Broquet-Fuel-Charger/415899711838681
Do take a look and thanks in advance ;-)
hey people just wanna get some advise from u guys..
getting my 2A and contemplating between spec 1 and 2.
I want good fuel efficiency. so is spec 1 a better choice than spec 2? whats are the cons of spec 2 besides the vtec open earlier? I read through the thread some bros the spec 2 1litre can go up to 23km whereas spec 1 1 litre about 19km.. What price range should i be looking at?
Thanks bros.
