Originally posted by skateboy@Dec 12 2006, 09:31 PM
that i can't help already... did u ask the mech wat prob is ur bike having that cause the high fuel consumption??
I think it's becoz my bike very old liao...next year gonna renew COE liao...plus I'm the 7th owner...dunno what the previous 6 did to it...Somemore got scratches on crashbar so I assume ever buang before...haiz
Life is a journey...keep on walking
Errr dun flamed mi for this but my spec 3 manage to do 406km as shown on my trip meter and when i pumped my tank to full i actually only pump 16.53L as show on the pump display... using mobile synergy 5000.
I'll post a pic for u all to see nxt trip to the kiosk hehe... :smile:
Originally posted by jamesgoh13@Oct 31 2006, 03:48 AM
Mine fully stock spec 3. Hit highest 23.5km/l. Riding style rpm 6 at xpressway. Or 80-90km/hr most of the time. Guess the tire do plays alot for this FC issue.
FC goes high when ur tires r low pressure which makes the bike travels more sluggish. Therefore I oways pump once within 2 weeks.
Now my FC remains at this level, unless i on & off play wif it. Last but nt least i seldom drag more den rpm 4 in 1st 5 gears. Only drag when 6th gear. Dun kinda lyk to play pickup.
the ridding style and bike also play a part..
i used to ride spec 2.. my milage 280-290 hit reserve.
now ridding spec 1 ride tll 330-340 reserve havent hit reserve.
i think due to vtec open slower. spec 2 at 100kph open vtec liao. spec 1 at 100kph not open vtec..
http://motorride.net/wp-content/uploads/2011/06/2012-Kawasaki-D-Tracker.jpg
Old Bike doesnt mean no good and new Bike doesnt mean good...
Its how we take care and service it...
Its the engine that tell us all....
Experience taught me alot ;) hope u know wat i mean..
http://photos-h.ak.fbcdn.net/hphotos-ak-snc1/hs160.snc1/5969_132325762781_632277781_3118071_4563982_n.jpg
Yah I agree with you that old doesn't mean no good....But in my case I assume the previous 6 owners abuse the machine before I took over so that's why fuel consumption very high due to wrecked engine or watsoever....:cry:
the fuel gauge is not accurate.. after 300, u go pump, how much can u pump???
- Yamaha FZ150I
-Yamaha FZ150I
Hi guys, just got a ver S too.
Curious on the capacity of the fuel tank. I saw the fuel needle at res and went topping up. To my surpise only manage to top up 10L till the breem already.
So in the average a full tank can go 350-400 huh?
Thank you all the bro here.
ters always sumtg wrg wit d fuel gauge.. mine aso like tat.. shown empty but only can pump 12 litre
- Yamaha FZ150I
-Yamaha FZ150I
I also have a ver S which COE ending soon but my fc r still quite ok...between 23-25..i am using shell 95
I am not sure how full do every1 pump....cos i can only hit reserve around 250-260km...after tat usually need to top up around 11l...
I will only walk on the path choosen by none but myself
So roughly what is the tank capacity of the ver S then? just worried that will run till the tank dry then "jia la"
i know the Vtec S4 is around 17L including reserve. Is our the same?
Should be 18 litre. Usually you'll physically hit reserve (not via fuel gauge) at the 15 litre mark.
As for the fuel gauge, for me when the needle is way past the 'reserve' mark and doesn't bounce back up on braking then the bike will go into reserve.
Email guay_hansen @hotmail.com
My blog at snowparang.blogdrive.com
http://www.pbase.com/snowparang/image/79866156/medium.jpg http://www.pbase.com/snowparang/image/95749015/original.jpg
Wow...learnt a lot from the replies...Anyway, there's something I've yet to try and see if it's the cause of high consumption; clutch plates....:confused: ...maybe my clutch plates are worn so there's a lost in the power transmission from engine to wheels...I'll change my clutch plates when I got $$$....:cheeky:
clutch plates.. do affect a lot bro!!
- Yamaha FZ150I
-Yamaha FZ150I
guys, changing the carb needles and carb rubber helps?
http://i10.photobucket.com/albums/a125/bearsvaluebaby/fireworks718ROXCfmFBsffgif.gif
2005 - SSDC - Class 2B
2006 - BBDC - Class 2A
2008 - CDC - Class 2
only if it's worn
Thanks!
How is your project doing? Can the forks fit in your RS?
:confused:
Originally posted by rockoil@Dec 16 2006, 01:17 PM
Thanks!
:confused:
they fit exactly. However, I've forsaken the idea of fitting an adaptor to the brake caliper and go for the full thing instead. But it's damn hard to find a cheap front 02-03 rim! And the top clamp is even rarer!
Maybe I'll sell it off on eBay again. Cos got lobang to buy a TL1000R full front setup...hehe...
Ver S there is a reserve tank Fuel co*k.
Unless it is permanently switch to reserve, otherwise you wouldnt run till dry.
Yah...I seriously think it's my clutch plates causing my high fuel consumption...Turn throttle hard sometimes still same speed...maybe the friction plate pai liao...:cheeky:
Also, sometimes I engage gear got tak tak sound very loud leh...not only first gear....why lah?? :confused: :cheeky: :cheeky:
Ic, you really into modding your RS huh.
Maybe you can get the cramp from ebay too?
:sweat:
Check ur Air filter. if choke or dirty ur FC will drop.
Life Is Never Fair.
Some pple slog for the paper in their wallet.
Some slog to feed the paper to the pple w/o the wallet.
