hmmm i damn scared sia cause i did a calculation say on average spec 1 can hit 22-25km/l so the tank before reserve is 15l so i should be hitting 330-350km for a tank before reserve right.. but right now im at 220km so is it possible to hit 110+km before the reserve..? im only left with 2.5 bar.. how ah..?
Actually diff rider will have diff FC. there wont be 2 bike having the same figure. FC depend a lot on the rider styles and also the weight.
btw i'm riding a spec 1, will go around 280-300 km b4 i hit reserve. and with regards of the digital meters, wat i felt is that its not that accurate, for my first 2 bar normally i hit around 130++ then i go towards the third bar after which the rest drop veri fast. like each bar can push u to 50km. 6 bars = 300km b4 it blink.
juz my 5 cent worth of comments..:D :D :D
******* Live a life where there is no tomorrow!******
oh okok than its normal for my bike le.. i thought my bike FC very high... but after checking through the forum realise its normal... anyway is there anything i can do to my bike to make the FC better... does adding revtec do the job?
Selling Fanciful and Vintage Helmets. Interested pls Pm me!
My spec II can clock me about 320km before reserve. But this is depending that i am riding at not more than 100km/h (not opening vtec). So in general , ride slower, save petrol............
http://aycu26.webshots.com/image/24425/2003714932190805835_rs.jpgâ„¢
<Treat Others As Wat You Want Others To Treat You>
<Feb 2006 - June 2007: Honda Phantom TA200 (FV4*** G)>
<June 2007 - May 2009 : Honda CB400 Spec II (FW9***D)>
<May 2009 - July 2011: Yamaha FJR1300ABS '04 (FX9***C)>
<July 2011 - Present: Yamaha FZ6N 2007 (FBB5***X)>
Hi all, i have a Q. I've been riding my S4 Spec2 for almost 4mths now and it seems to be having a little problem.....Filling up full tank ( 17Litres ), my bike can only clock 220km and its already down to reserve! Its a pain to hear others clocking more than 300++km on their S4....I've just changed 1) Spark plugs 2) K&n Air filter 3) Oil filter and engine oil and even fix on REV-TEC just to see if theres any changes....but everything's the same..220km and it hit reserve!!! I ride 90-110km/hr and every thing on my S4 is standard.
Apreciate if you could advise me on what you think is the problem!!
Most common factors that contribute to poor gas mileage
http://www.howtodothings.com/automotive/how-to-get-good-gas-mileage
http://www.nccc.gov.sg/fueleconomy/Maintaining.shtm
when i turn on the key my bar run from left to right..but when i start igniton. i left with 1 bar but it did not blink so am i hitting reverse already ? or wait til it blink than i hit reverse..
JAN '08 - JUL '08 ~ VFR 400 (FH *1*3D)
JUL '08 - NOV '10 ~ CB 400 (FBC 3*3D)
NOV '10 - JUL '12 ~ CBR 600 (FBC *6*3K)
JUL '12 - AUG '12 ~ X-1 (FZ *2*3A)
AUG'12 - Sept'15 ~ SPARK T135 (FBE 4*2*B)
SEPT'15 - JUNE' 18 ~ Tmax 530 (FBG 8877Z)
JUN'18 ~ AUG'22 ~ XMAX 300 ( FBG 8877Z)
when the fuel gauge don't run then you're still not yet in reserve. and also when your bike is tilted the reading is different, but fuel gauge is just a rough guide.. judge by mileage will be more ideal..
2006-2007 -- Honda Varadero XL125
2008-???? -- Honda Super 4 Hyper Vtec
Ride safely always. BUT that doesn't mean going slow. :)
ok..i jus started riding so i dunno wat my mileage..i wan to ask when u are in reserve the bar will run left to right when u are riding is it.. or run alwhile than back to 1 bar again..
should start pumping petrol when u see the bar running left to right and won't stop at 1 bar again..
and also if u have reseted your "Trip 1 or 2" during the previous full tank.. just pump a full tank and reset the meter, and when hit reserve, take note of the amount of petrol pumped (full tank that is).
so let's say u pumped 15litres.. and traveled 320km on your previous full tank, it will be 320 / 15 = 21.3333...km/l.. for super4 it should be around there.. :)
ok thanx for the advice..i think i hit reverse around 320km.. so it should be like wat u say 21.333km/L..but i see alot of guy saying they can hit around 23-24km/l i dun get it..i seldom on vtec too..may be its my jet kit and full system eat too much fuel..haha
with full system and jet kit, guess your FC is consider good already..mine all stock and that reading never appear on my full tank run as of now..
may be i really very gentle with my throttle..and i seldom on vtec, 1 hand can count..haha
that will explain why your FC is relatively good
Wat do u mean by vtec?? Can explain?? U mean on gear 6??
guys. my spec 3 1st bar onli runs abt 35km+-. issit normal or issit way too low. coz i read from the forum like all so high like tat ley.
pls advice. thanks
hi.. Although I'm riding a spec 1, I think your fuel consumption is on the high side.. A typical full tank, my first bar can last me around 120km.. Or is it that u didn't pump till near the brim?
u all pump till it reach the brim or until the recommended by the manual 1 until the round corner there? i onli pump till the round corner there and not to the tip until like its going to spill out ley. is it the case?
vtec mean..my rpm nv go more than 7rpm
bikepics.com..go there look for super 4..dunno whether can help u or not but can try
u all pump till it reach the brim like its going to spill out or until the recommended by the manual 1 until the round corner there?
need some advice coz my FC not tat gd. pls help
bro whether u pump to the brim or pump half tank, it's not going to affect ur FC at all.. Maybe by a little little bit cos ur tank is lighter is u nv pump full tank.. even if u pump 15l and travel 300km while i pump 5l and travel 100km.. Our FC is the same, it has nothing to do at all with whether pump to brim or not..
Max
SpecIII Rider
http://i277.photobucket.com/albums/kk53/u0605382/SNC00042-1.jpg
http://www.speedtest.net/result/333285646.png
riding a spec 1.. vtec rarely open.. fc about 22km/l.. change gear at about 5k rpm.. is the norm already?
