Can try to trouble shoot on your own.
Probably wiring between battery and CDI got a problem.
Have you tried to find the problem part of the wire on your own?
I can't open the cover to check the battery and wire etc. Cos no tools.
I dun noe wat to do now.imagine i have to push start to start from point a to point b. Push start again from point b to point c. Along the way, signal blinking very fast yet weakly. No horn also. After I stop, tried to start. But its totally dead. No cranking sound at all. It's as though, the switch is not turned in.
Can u help and advise?
5 Oct 2005 - Jun 2007(SP) FS6059X
18 Jun 2007 - 26 Nov 2007 -> CBR400, L model problematic FJ532*S
26 Nov 2007 - 12 Nov 2011 -> TA200, FV2X2G
12 Nov 2011 - 12 Nov 2012 -> SYM GTS200, FZ99*0D
29 Nov 2012 - 13 July 2015 -> KIA Rio HB 1.4M, SFY*
13 Jul 2015 - 28 Apr 2018 -> Kia Cerato V2 SKT*
28 Apr 2018 till current -> Hyundai Elentra S_trim SLZ*
probably your rectifier is fried.
brand new battery gets drained very fast right?
if so, probably is la.
ah chong has spares for it. think around 180?
Magnetic coil and battery ok according to them. Went to planet less than a month ago. He told me is the battery spoil, which I reluctantly changed. But problem back again.
If really CDI problem, how long will it take to repair? Do I have to leave it at the shop?
would be rather fast i think. plus minus 2-3 hours at worst.
Thanks for help.
Went down to planet. Issuse is the "Starter Relay". Total damage is $30, second hand. So far, I tried on and off the engine, and it's ok. Can start. Hopefully, this is the cause of problem after quite some time.
Also, mine is FV xX2 G. Coe ending next year 2012 June. Am completating to renew or nt. According to others, they say not worth it to do so. It's very high, as we all know. On the other hand, do not know what bike to buy. Super 4 very high in value. I quite big size, which 2b suits other than ta200?
My DR also had this problem before when I went for a Malaysia trip, you can actually hotwire it, but be warned, lots of sparks! Hahaha! :lol:
Got a brand new relay for $65 (or was it $85) for it when I came back.
Hmmmm.... but when my relay was fried, my horn and lights were working just fine.
Sorry I couldn't diagnose it better for you, but I am glad you got it fixed. :)
Thanks for help.
just renew the coe unless you get another bike... and when you change your mind in the future, you can just cancel the remainder of the coe and get your money back :smile:
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Kalyan)
Solution: Gear box dying.
Solution: Engine is overheated. (Running too lean/ Not enough engine oil.)
Turning the screw clockwise to enrich the mixture. (once again, tune in 1/4 or 1/2 turns of the air correction screw, located on the LEFT side of the carb)
Bike tends to rev rapidly but have poor acceleration if lean, and if too rich, will have "spongy" / slow throttle response at high speeds.
If in need of advise / demonstration sms pandora's kitten at 93270801 (advice/demo given is FOC)
Solution : Get your air filter changed. You are advised to inspect the air filter every 4000 or so kms and change it at 10k (Honda warranty service manual)
Solution 2: Buy a can of fix a flat from Carrefour or petrol stations, put it in your box.
Solution: Obvious.
Others:
Solution: If you have very poor acceleration when throttle is opened, you are running lean. Enrich mixture by 1/2 to 1 turn of the air correction screw.
Solution: If you are using spray on chain lube, dirt and grease may be thrown off the chain during normal operation. When a lot of grease accumulates on the chain tensioner (rubber cylinder) and swingarm protector (rubber bar) the chain will emit a loud sound as though running through sand. Scrape and wipe away the excess grease and enjoy the quietness.
Solution:
- Send to bikeshop.
Solution:
Solution: Fuel/air mixture too lean giving poor acceleration and a hot engine
Solution: Fuel-air mixture likely too rich. Backfires when throttle is closed, due to residual fuel afterburning in the exhaust header. This is bad for the valves and the catalytic converter.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Pandora's Kitten :3)
Solution: Engine is overheated. (Running too lean/ Not enough engine oil. An overheating engine may cause excessive oil consumption, especially when using less tolerant mineral oil)
Problem 27: Handlebar position is not centered (while riding). Handlebars are "straight" but wheel points to one side.
Solution: Lock the wheel, grab the handlebars firmly and twist the bars until straightened. The risers are flexible to some degree, due to the vibration damping rubber washers. (Demonstrated by Planet Motors)
Solution: If your steering lock is spoilt, put the wheel against a pillar or a wall.
Problem 28: Bike hard to U-turn. Riding position not comfortable as handlebars too high up.
Solution: Adjust the angle of the handlebars. Loosen the bottom two screws of the risers, pull back the bars so they "rise" towards your face. This will give you a more relaxed riding posture and you are able to enjoy a greater turning angle at low speeds. If your handlebars are set to rise straight upwards forcing you to stretch forward and upwards to steer, your elbows will prevent you from turning easily at low speeds.
Edited by Pandora's Kitten :3
No worries bro. Appreciate your help and spirit. ;))
Still worried abt the problem. Also dun noe whether it's totally solved....
What is bugging me now is my Coe. Ending June 2012. Only 1 year to go. Doesn't wan to spend lots on just a bike. Transport serving only. A bike is still only a bike ultimately. However, still need a bike transport. Am thinking of selling or worst case, scrap at $200. Then gt another ta200. I love ta200. As it's very econmical. Dun wan to buy luxury ones. End up with installments. I just find it Bo Hua with interests. Since it's only bike.
Your thoughts pls....
Hi bro/sis, sorry to hijack this thread..Got my 8 years old TA200 2 months ago..Encountered 2 incidents with bike stalling halfway while riding during rain..The first time it happens, bike loss power and all electrical power loss..it was diagnosed to be the battery flat..After battery changed ok liao..The second time, the bike loss power and stop and i heard a "POP" sound! Quickly guide the bike with my feet to the road shoulder..At first i thought the tire punctured. But it was not punctured when i checked it.. The sound like comes from somewhere near the exhaust....This time round, electrical power is there as i can see the green neutral light when bike key is switched to "on"..EMAS came and towed my bike to a nearby car park..After a while, my bike can starts again and so far so good till now..i really dun know what happens and can any bro/sis help me in this? It can't be when during rainy weather this problem will come every time right? My frz who rode a phantom previously told me that this problem happened to phantoms often but he also dun know what is the problem and he changed bike in the end..I really want to find the root to this problem..Had read up on this thread and the problem that is similar is during raining, spark plug got wet and stalled..But my bike problem got a "pop" sound and so i am in a dilemma on what is the problem..Meantime, will refrain from riding during rain and will check weather forecast before riding.. :( Hope bro/sis here can help me..Thanks in advance!
Edited by Mike80
You just diagnosed your problem; your spark plug got wet during a ride in the rain. Or perhaps your spark cable is old and the internals are exposed to the elements. Since I got some time, let me try to explain the 'pop' sound for you as simply as I am able to.
Air-fuel mixture enters combustion chamber from carbs -> spark plug wet -> cannot produce spark -> air-fuel mixture does not ignite -> no combustion -> un-combusted air-fuel mixture exits combustion chamber via exhaust pipe -> exhaust pipe is very hot (as we all know...) -> temperature in the header + pipe heats up air-fuel mixture -> air-fuel mixture ignites as it exits the exhaust pipe due to decompression (air pressure outside is lesser than pressure inside the bike's internals) -> you hear the pop sound as the ignition takes place.
If you're able to, whenever this happens, stop your bike at a sheltered area, remove your spark plug and clean it dry. Chances are, your bike can start again. For a longer term solution, consider replacing the rubber bits that are supposed to prevent these sort of things from happening. Hope it helps.
Postman Eating Inc*
http://i12.photobucket.com/albums/a208/murano04sfs/38y29ty14.gif
http://4gifs.com/gallery/d/155006-1/Mascot_scares_girl.gif
Squid defination: http://www.urbandictionary.com/define.php?term=squid
come to the clinic this sat...and let some experience diagnose..hands on..
bet you learn fast..
hi just to check, i just saw a tube at the bottom of my bike. it seems to be hanging loose. is this a problem? need to repair?
Got bike must ride!
SYM Maxsym 400i - 09/11/12 to current
Phantom TA200 - 07/08/09 to 09/11/12
This tube is most likely the:
1. Carburettor drain hose, the tube links to the bottom of the carb. This "vent" hole is usually closed by the screw located on the bottom of the right side of the carb, used for draining flooded carb or as a emergency feature if tuning goes wrong. Just leave it alone unless fluid constantly leaks from the tube.
so i can just leave it alone until i see fluid leaking right. Thanks Pandora.
Got bike must ride!
Yeah, nothing to see there, just a tube lol.
It's possible to run without the drain tube going to the undercarriage but in case someone needs to dump fuel from the carb.... it's a bad idea to do it onto the hot engine block/crankcase. Hence the tube.
Think that is either the carb drain hose, or the breather tube that links to the tank.
The tube even if drop/ lost also no poblem, but leave it there better, help avoid having stains from dripping fuel on your bike.
Bro I live in Yishun too, where do you live, I can go tighten the spark plug for you.
Hi Bro Silent hunter, i stayed in yishun ring road. Where do you stay? i come to your place since you are helping me mah.. ;) Kopi after dat..
Thanks ezzyoiler, will try to make it to the clinic this sat! Really feel welcomed to this forum by all the friendly and helpful bro/sis here! ;)
