Originally posted by s4vtec@Oct 17 2006, 01:04 PM
Upon asking around my friends, i was adviced to buy Shell CoolGuard OAT Ready To Use (pre mixed formula). No water needed to be added to it. Price is @ SGD$6 per 1 liter bottle. An s4 would require 2 bottles. Anyone any comments about this? :confused:
Actually not exactly 2 bottles bro..most prob u only use 1 1/2 bottles of the coolant :smile:
Some biker once said " If u haven't been to Gerik, U haven't been touring in Malaysia".
add to reserviour with the balance? :cheeky:
http://i88.photobucket.com/albums/k175/des_child75/signature/watermark.jpg
Ink and Needles is where i feels my pain...I am a 60km/h rider so don't horn at me ... ...
you are right! :smile:
for the resevoir, we add it to full? :giddy: Or just between the less and more...
after i had done my coolant flushing, here are my 2 cents...
2 liters of coolant was jus enough to fill up the radiator and the reservior... :smile:
when i top up the reservior, total is 2 liters including those tat went into the radiator...
when pouring coolant into the radiator, you need to constantly tilt the bike left and right so that the coolant can flow into the radiator properly...
lets talk about, Flushing coolant... again... :p
what are the correct steps to flushing coolant...
  • 1. remove side panels and petrol tank of bike.
  • 2. open radiator cap and coolant reservior cap.
  • 3. remove coolant draining screw located on the left side of bike at coolant pump.
  • 4. allow coolant to drain out completely.
  • 5. remove coolant reservior screw and empty coolant in reservior.
  • 6. tighten screw back to coolant pump.
  • 7. pour in about 1.5 liters of distilled water into radiator.
  • 8. start engine for 2 mins and let the distilled water "clean" the internal of the coolant system.
  • 9. off engine, remove screw at coolant pump to drain distilled water completely.
  • 10. tighten screw back to coolant pump.
  • 11. fill up radiator and coolant reservior with coolant fluid.
  • 12. start engine and topup excess to reservior if nessecary.
-the total capacity of coolant for s4 including reservior is about 2 liters.
-when pouring coolant into the radiator, you need to constantly tilt the bike left and right so that the coolant can flow into the radiator properly.
-i had done my coolant flushing and refill and 2 liters jus went into the radiator and reservior completely...
:cheer: :smile:
:cheer: :smile:
Thanks bro! :thumb:
Originally posted by sabbaha@Oct 18 2006, 05:28 AM
Thanks bro! :thumb:
sabbaha, if u wana flush coolant, jus let me know... i can help you with it! :cheer:
(coz i expert liao! joking la... jus wana extend my help to you guys)
ride safe... :cheer:
the coolant i used... which u need 2 bottles for s4... SGD$6 per bottle from Shell... :smile:
Not bad..quite cheap! :smile: $12 for 2! :cheeky:
bro, y use distill water to "clean" or flush ur radiator?...wad abt using radiator flush?
http://i4.photobucket.com/albums/y117/nebulaz/KTM-Pink-1.jpg
HUA Hua hua....WADEVER..AR you STOOPID OR WAD? HUA hua hua version 2.....
Guest quizesilver
pls monitor the coolant's reservior...
my bet is that it will drop by the original marking...
as according to spec 3 manual the required coolant is 2.2L
distilled water will not rust and corrode the internal parts of the radiator and cooling system but normal tap water will. i think its due to the oxygen in the tap water...
as for and old bike like mine, (7years old) the internal of the radiator cooling system is more or less, corroded. be it yes or no, we cant see. but jus to take pre-cautions. if we were to use coolant flush to clean the internal, the coolant flush might "eat" into the corroded areas and worst, form a crack in the cooling system... then... you can imagine the rest...
the above are my 2 cents... anyone pls correct me if i'm wrong... :sweat: :smile:
thanks for the advice... i'll keep watch of it. :smile:
Hi all, I went to Planet Moto and K&T in search of my RADIATOR MESH but unfortunately unable to find. Im thinking of going to LAB next to find. Can anyone pls advise where i can install the RADIATOR MESH and how much its gg to cost me? :help:
Radiator mesh usually ppl DIY. Buy mesh, cut to correct size then spray yourself. Secure it with cable tie or metal wires. Mesh comes in a very big piece (enough for a few pieces) so better if u can gather a few ppl to share.
http://farm2.static.flickr.com/1055/527481558_8975eefe29_m.jpg
Dec00 - Aug03 : Honda Phantom TA150
Aug03 - Feb06 : Honda CBR400RR L-model
Oct03 - Mar04 : Honda NC35 RVF400RR
Feb06 - Oct06 : Honda CB400 HyperVtec
Oct06 - Sep07 : Honda NC35 RVF400RS
Sep07 - Now : Alfa Romeo 147 1.6 T.Spark
something for you guys to drool about... :smile:
mini egg shaped fog lights... :cheer:
will post pics when i have installed them... :cheer:
Then in that case, anyone inside SBF doing RADIATOR MESH? pls contact me, im willing to pay to install as i wanted very badly... xie xie... :weep:
me too! :)
another place to install Lizard Skin... :smile:
It doesn't look nice ..bro ..Its better to be at the brake cable :smile:
Originally posted by mountain_smith@Oct 22 2006, 04:22 PM
hey guys, can a spec 2 rear hugger be fixed on a spec 1??
bro, there are a few types of hugger in the market and most of them can fit on most of the bikes. if u wana know can fit or not, jus see which design you like, then ask the shop guys if can fit or not... mostly can fit one... and i recommend you to go Motoworld... higher price to pay but better service and better quality. hope my answers above satisify your question. feel free to ask more. i recieved your pm b4. think you are a newbie to s4... welcome to the s4 family. :cheer: :smile:
