  • Replies 2.2k
hi. hw much does it cost for ver s full overhaul? What are the component replaced & wat r checked?
You have a PM.
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
Hi unique, my full system exhaust no spring, is there spring for sale?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi, do u sell stock s4 spec3 exhaust pipe? If yes, how much is it?
hi can u recoment mi of a pipe that gives a loud deep base sound?n how much wld it cost?
You have a PM
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi Kelvin, what's the price of changing spec 1 speedo meter (including the LED part, also the price of speedometer sensor cable and lastly, the ignition key for spec 1 (cuz mine unable to handle bar lock). Thanks and sorry for asking so much.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi,
My spec 1 LCD is burn out. How much to replace?
You have a PM
Best Regards
Kelvin 87178999
WL: Zul 84818999
Valve Clearance / Top Service Packages For Class 2A/2 Bikes / CB400 Super 4
$350 Valve Clearance Package:
- Replacement of cam cover o-ring
- Balancing/ Replacement of shims
- Replacement of standard coolant
- Lubricate/ adjust drive chain
- Check spark plugs
- Check both front and rear brakes
- Check tire pressure
- Check electrical lightings
- Check clutch
- Workmanship
Applicable to most class 2A/2 bikes like Super 4 CB400/ CBR400/600/900/1000 / RVF400 / R1/ R6 /FZ1/FZ6 GSX400/600/750/1000 etc
Time required: 3 to 5 working days
Top Service Package:
- Replacement of timing chain
- Replacement of tensioner
- Replacement of tensioner chain guide A
- Replacement of tensioner chain guide B
- Replacement of head gasket
- Replacement of fully synthetic engine oil
- Replacement of spark plugs with NGK iridium spark plugs
- Replacement of valve seals
- Servicing/ Balancing of carburetors/ injectors
- Service of inlet valves
- Service of exhaust valves
- Check clutch
- Workmanship
Top Service Package for Honda Bikes: $950
Honda CBR1000 06 etc
Top Service Package for Yamaha Bikes: $980
Yamaha R1/R6 99-06 etc
Top Service Package for Suzuki Bikes: $1200
Suzuki K1 – K6 1000, Hayabusa etc
Time required: 7 to 10 working days
Top Service Packages for: Honda CB400 Ver R/S/PB1/ Vtec I/II/III
$450 Package:
- Replacement of tensioner chan guide B
- Replacement of block gasket
- Replacement of coolant
- Replacement of engine oil
- Check spark plugs
- Check cam cover oring + 8 x head mountings
- Check clutch
- Workmanship
$650 Package:
- Replacement of all 16 valve seals
- Service all 8 inlet valves
- Service all 8 exhaust valves
- Check spark plugs
- Check clutch
- Workmanship
$650 Package:
- Replacement of all 16 shims
- Balancing of all shims
- Check spark plugs
- Check clutch
- Workmanship
$850 Package:
- Check spark plugs
- Check clutch
- Workmanship
$950 Full Service Package:- Replacement of timing chain
- Replacement of spark plugs (OWS Twin Iridium or NGK Iridium Spark Plugs)
- Replacement of coolant (Engine Ice High Performance Coolant)
- Replacement of engine oil (Motul 300v)
- Check clutch
- Workmanship
Time required for Top Service: 3 to 7 working days
Please check 1st post of the thread for latest updated pricing. Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi Kevin,
just check how much it cost to replace my water pump ..i think my pump not working.
Thank you
G-Day, do u entertain customer from Malaysia, e.g. if i am to buy product from U, can send item to M'sia by courier tq.
For the Driven Fatbar($150), does it comes with the driven bar pad? coz i dont see any driven pad sold on the list.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://i600.photobucket.com/albums/tt84/uniquemotor4/197213_1828455067017_1109535625_32114859_7162164_n.jpg
http://i600.photobucket.com/albums/tt84/uniquemotor4/198938_1828453346974_1109535625_32114856_6346049_n.jpg
http://i600.photobucket.com/albums/tt84/uniquemotor4/200593_1828454467002_1109535625_32114858_3546211_n.jpg
AFAM Sprockets for Honda CB400
DRIVEN Sprocket Nuts
EK MVXZ Red Coloured X Ring Chain
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi Kelvin, i'm coming down tml to do afew services to my spec 1:
1)$65 OWS PACKAGE
2)Flush radiator and engine ice
3)Trottle cable
4)OWS 3 in 1 Performance Package
5)Add 'on/off' control switch for my headlight
I hope u can give me a good quotation. Many thanks.:)
1)$65 OWS PACKAGE
3)Trottle cable
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Erm sorry Kelvin, u did pm-ed me, but u didn't write anything in the pm. Haha. :D
Please see again, the pricing are indicated beside your questions.
Best Regards
Kelvin 87178999
WL: Zul 84818999
How much? =)
How much? =)
AFAM sprockets (520) + EK MVXZ Red Colour X ring chain + Driven sprockets nuts: $385
Best Regards
Kelvin 87178999
WL: Zul 84818999
Thanks thanks. Will come to autobay tml.
You are welcome. Sure, cya.
Best Regards
Kelvin 87178999
WL: Zul 84818999
