Top Service Packages for:
Honda CB400 Ver R/S/PB1/ Vtec I/II/III
$450 Package:
- Replacement of timing chain
- Replacement of tensioner
- Replacement of tensioner chain guide A
- Replacement of tensioner chan guide B
- Replacement of block gasket
- Replacement of head gasket
- Replacement of coolant
- Replacement of engine oil
- Lubricate/ adjust drive chain
- Check spark plugs
- Check cam cover oring + 8 x head mountings
- Check both front and rear brake
- Check tire pressure
- Check electrical lightings
- Check clutch
- Workmanship
$650 Package:
- Replacement of tensioner chain guide B
- Replacement of all 16 valve seals
- Service all 8 inlet valves
- Service all 8 exhaust valves
- Check spark plugs
- Check clutch
- Workmanship
$650 Package:
- Replacement of all 16 shims
- Balancing of all shims
- Check spark plugs
- Check clutch
- Workmanship
$850 Package:
- Check spark plugs
- Check clutch
- Workmanship
Time required for Top Service: 3 to 7 working days
really intrested in the $850 package can pm me for more details thanks u
  • Replies 2.2k
You have a PM
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
Hi ther..Im riding a spec 3..My font brake lever seems to b stiff n hard whenever i brake n the brake light wld take awhile to turn off..cld it b my brake pump kit?How much to chage new 1? Tanx
You have a PM
Best Regards
Kelvin 87178999
WL: Zul 84818999
is the clutch plate and aftermarket rear suspension still same price?
Hi Unique, any tyre promotions for Sept? Either michelin or metzeler..
Thanks in advance..
Sent from my iTouch using Tapatalk
You have a PM
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi,
juz wan to know if you do full servicing and tuning of CB400 Vtec-1 Carburretor and how much time needed.
Thanks,
koreano
Full Service: Please refer to our servicing packages.
Servicing of carburetors $60.00
3 hours
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi,
Thanks,
koreano
3 hours
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi may I noe the model or part no for the DID X-ring chain that is in the package below
- DID X Ring Gold Chain + Honda sprockets (525): $260
- DID X Ring Gold Chain + Hodaka sprockets (525): $220
http://www.nea.gov.sg/cms/mss/gif/rainloc0.gif
DID VX2 X ring chain.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi thx for the prompt reply.... btw do u have 525ZVM-X did X-ring chain? How much issit the price difference if I pair it with the sprocket above?
No more VM2 chain. All new DID chain are VX2.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Im aware that vm2 was replaced by vx2... Im saying another model 525 ZVM-X....
Nope. Only VX2 available.
Best Regards
Kelvin 87178999
WL: Zul 84818999
hi unique, how much do u charged for wheel alignment?
You have a PM
Best Regards
Kelvin 87178999
WL: Zul 84818999
i have a problem: my bike is using a set of new arashi brake disc and brake pad. normally, there was no issue with the braking at all, everything works out fine. However, during raining period, the braking effect is gone and i need to press harder on my brake lever to feel the brake. when i do that, not only do my bike have this jerking braking effect (similar to ebrake) there is also noise coming out from the front. it's not a screeching noise thou. just a mechanical noise that i can hear and could feel it when i brake during rain. what could be the problem?
Former rides:
HONDA SP (FP4733L) - CAGIVA MITO (FS7923U) - GILERA RUNNER (FS6524U) - HONDA SHADOW (FP5522Y) - HONDA PCX (FBF3971Y) - HONDA CB400 VTEC 1 (FS2994Y) - YAMAHA FZ1S (FBA5057A) - HONDA CBR400RR-R (FQ6676A)
Current ride:
Dec 2013-Present: Kia Picanto (M)
You have a PM
Best Regards
Kelvin 87178999
WL: Zul 84818999
You have a PM FOR Hi ther..Im riding a spec 3..My font brake lever seems to b stiff n hard whenever i brake n the brake light wld take awhile to turn off..cld it b my brake pump kit?How much to chage new 1? Tanx
I have the same prob. please advise
Do drop by when free, i get my mechanic to check for you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://i450.photobucket.com/albums/qq228/uniquemotor/cb400ohlinsdamper.jpg
Ohlins Top Mount Steering Damper for Honda CB400 $700.00
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi UM any promo now? For cb 400..
Looking for new set of NGK iridium, how much ? Or is there a cheaper package?
Waiting for your PM..
Thanks!
  • Yamaha RXZ 135
  • Honda Wave 125
  • Honda CB400 Spec 3
  • Yamaha FZ6
  • Yamaha FZ1S
  • Yamaha XMAX 300 & Yamaha R15
Thanks!
You have a PM
Best Regards
Kelvin 87178999
WL: Zul 84818999
