  • Replies 833
hi all expert out there. my bike have clock 7000km liao and have not change engine oil till now. what is the best mileage to change engine oil , and what type is best for vtec 1
like to exchange ideas,have the intention to get my class 2 so that can join friends for touring around the world.
If u r using normal oil, its advisable to chang every 3-5k km...
Guest aikh1an
and dun forget to change the oil filter too after 2 or 3 time changes of engine oil
It would be better if u change oil filter & engine oil together.. Spark plug then change 2nd servicing....:cheer:
My schedule is 4.5k, change oil, then plugs n oil filter every 12.5k... been maintaining this schedule on my bike 4 the past 7 yrs.. engine still going strong.., except now clutch plate wearing off liao.. no power....:sian:
1996-1997 : Honda CBX 125
1997-2006 : Honda Project Big 1
2006-2011 : Yamaha Fazer 1
2011-2013:- Harley Davidson XR1200
2013- now: Something BIG..
You haven't changed ever since you bought the bike?
The first oil change with a brand new filter for a new bike would be at the first 1000km. Then oil change every 5000km. Filter change every other time you go for oil change. Maintain this and you'll have your engine runnin as good as new always.
Guest enHANZed
any motodiam having servicing promotion ? i know motorworld has package offer
hi expeert out there? does vtec have a diper located at the cap for topping up engine oil? if have i afraid mine inside the einge liao. kaozz
not to worry, dun have, u just have to look at the side small screen to check level, straighten your bike before checking
but to check ur engine oil level... u need to make the bike to upright position. 3litres for oil change witout oil filter and 3.2litres with oil filter change.
Just wondering.Any of you S4 expert or in fact any bike...Issit advisable for use to stick to 1 brand of engine oil or issit ok for us to switch different brand of engine oil everytime we need to change engine oil....Any experts care to share their knowledge
http://i85.photobucket.com/albums/k74/waklabib/esso.jpg
I just broke my record for JB-KL timing
Originally posted by darrenx@Nov 16 2004, 01:21 AM
Any ideas if put too much engine oil into the bike will have wat syptom?
Heavy and sluggish !
http://www.singaporebikes.com/forum/uploads/photo-3088.gif
any other syptom then tat?
normal is put how many litres?
see most bike shop put 3.2 plus change oil filter
but c my bike the engine cap there put some jap wording n some 2.7 / 2.9 / 3.6 litres
Using the info u've given,
it should be 2.7L without oil filter change
2.9L with oil filter change
3.6L with engine rebuilt (That means after assembly of ur stripped engine)
Guess u are using Ver S ?
i am riding a VerS
But then if thats the case y alot of motorshop put 3.2litres? ( make us pay more? )
Cos quite confuse regarding this...
So any1 here knows whats the actual correct amount of enigne oil need?????
Thinking of maintancing myself....pls help
Originally posted by darrenx@Nov 16 2004, 02:20 AM
i am riding a VerS
3.2L should be for Vtech.
Obviously they mistook ur for a VTEC cuz of the colour or the ripping u off by saying it's actually better for ur bike, which is not.
If u dun believe me, check the forum for exact specs for Ver S.
Cheers !
Originally posted by redname@Nov 16 2004, 11:12 PM
same as ver S, the info can be found on the bike itself, not sure is it the chainguard or the place where u pour in the oil
Right hand engine casing...
PB1, Ver R and Ver S all the same specs (99%same)
Cheers !
