wot is PAO???
http://martymcfry.com/images/limpdick2.jpg
'01 - Honda Repsol
'09 - Vespa GTS300 Super
'12 - Yamaha FZ1-N
Originally posted by redlineoil@Oct 24 2004, 04:47 AM
All engine oils come in 0.946L
Prices:
5w30, 5w40, 10w30, 5w50, 15w50, 20w50, --- $23/-
10w60 --- $26
All prices quoted are PROMOTIONAL prices in lieu with the launch of the RedLine street engine oils.
what is the retail price after this promotional?
Originally posted by il4@Oct 22 2004, 12:42 PM
Click here to know more
PS: U havent answer my question either, are u using it for your 55K or honda wave, please reply.
For my Wave first...... :smile: Anyway thanks for sharing il4.
History n Present ride
Originally posted by redname@Nov 13 2004, 07:19 PM
hi, if u guys r looking for ester based engine oil, i looked thru the market & found motul 300V to be among the cheapest, priced at $20 per bottle.
if u want a bit lousy one (mixture of PAO & rockoil), u can try rockoil priced at $18
wat the different bwteen ester base and non ester base?
Originally posted by waiyuen@Sep 3 2004, 05:54 PM
As I know, now only MOTUL & FUCHS 4T is Ester base. Been try this 2, both work very well. But Motul expensive abit (10W-50)...so I use Fuchs Pro 4 Plus(15W-50), cheaper the Motul 2 dollar. :smile:
Motul-MotoGP Yamaha team
Fuchs-MotoGP Kawasaki team
SO see which brand u like loh~ :cheeky:
where u get ur pro 4 plus?
just try out the Fuch silkolene pro 4 15W50 on my old Honda Helix(10.5 yrs), is better compare to Mobile 1 in term of performances wise. Start up at 1 light push, engine noise reduce, temperature maintain.
Mobile 1 cost me $22.50 at Esso petrol station, outside selling $18 (hear from fellow rider).
Fuch Silkolene pro 4 15W50 outside selling $21-$22 (Ubi area as quizesilver tell me), got MO from Quizesilver only $15.50
Anyone care to share motul 300V performance?
With every good wishes
Mark C.
It is in the moment of your decision and action that your life is shaped.
Life is a daring adventure or nothing at all.
æµ· 纳 百 å· ï¼Œ 有 容 乃 大 。
为了生活我å¯ä»¥å¿ , 平安回家 , 陪家人åƒé¥­å¾ˆé‡è¦.
Hi, juz want to ask u guys... is the engine oil ur mentioning the same as gear oil?.. i noticed that the bikes ur using the engine oil on is all 4 strokers.. how abt 2 strokes?? coz me riding sp ma which is 2 stroke.. den recently i had difficulty in changing gears oso... sometimes i even got gears skipping the chain for a slight moment.. is it the symptons to tell me that its time to change the oil?? i'm quite confused between engine oil and gear oil... pls enlighten on this... tanx...
<u>Past Ride</u>
Jan 2005 - Dec 2006 FT2#5#Y Honda NSR 150 SP
<u>Current Drive</u>
Apr 2005 - ????? SFU2@#2A Hyundai Getz 1.3A
<u>Ideal Plan</u>
Bike - RVF NC35
Car - EVO/STI
http://i252.photobucket.com/albums/hh35/Benben81/Photo_0003.jpg
Originally posted by ypvs@Aug 6 2004, 11:25 AM
Which 4T engine oil is good for super four? Is How much it cost ? BP Vistra good to use ?
honda recommended shell for the engine oil. been proven making the engine running smooth & better. for other brands of engine oil.. repsol, rockoil, fuchs & motul are very gd & cost more than normal brands. these brands been tested & proven which r commonly use for racing. in anyway u can try experiment using different kinds of engine oil & when u r comfortable using any of it.. then u have the choice to choose which u want. i believe those cost more r definitely good one.
:cheers:
Originally posted by mitsevo@Feb 7 2005, 08:40 PM
Hi, juz want to ask u guys... is the engine oil ur mentioning the same as gear oil?.. i noticed that the bikes ur using the engine oil on is all 4 stroke.. how abt 2 stroke?? coz me riding sp ma which is 2 stroke.. den recently i had difficulty in changing gears oso... sometimes i even got gears skipping the chain for a slight moment.. is it the symptons to tell me that its time to change the oil?? i'm quite confused between engine oil and gear oil... pls enlighten on this... tanx...
mitsevo.. theres no difference between this two terms that so called.. engine oil(4T) & gear oil. its only engine oil is commonly name for 4 stroke bikes & gear oil for 2 stroke bikes. no worry.. u can just use any of this. mayb if u r interested.. how about repsol or rockoil gear oil & their 2T. for ur gear skipping problem.. commonly its the clutch plate have been wear off which need to be change a new one.
:cheers:
yah, there's diff between these 2. the diff is in the kind of additional stuff they put in. 4 stroke oil has more additives cause it lubs the whole bike wherelse gear oil only does the gear box. so between the same quailty, 4 stroke oil is more exp cause of the additives. its kind of a price diff decision now. i recommend motul gear oil or rockoil gearoil
ur gear changing thing can be costed by ur gear oil, ur clutch cable (too loose or tight) or ur clutch plates (prayit isn't tis, quite ex to change)
Yes there is a difference.
Gear oil is usually "thicker" than Engine Oil (Higher Viscosity to deal with the 'shearing' effect of gears)
As redname mentioned, they also contain different (probably less) addictives than EO as EO has to deal with the by-products of the engine combustion (carbon,etc) as well as lubricate the gears/clutch.
quick question. When is the time to change
1. clutch plate / lining etc?
2. engine oil?
Many thanks!
http://img407.imageshack.us/img407/7720/dsc00157a.jpg
All Must Work Hard!
1) When there's a problem with your clutch (e.g. experiencing clutch slip)
2) Follow recommended change intervals in your manual, minus a few kms to play safe if you want.
Originally posted by hachi@Oct 7 2004, 09:31 PM
I am using it cheap and good. Basically they are the same and using technology.
hahahaha after seeing all this royal purple engine oil juz wanna ask u guys.........
soo i juz need to gt the $10.50 royal purple engine oil or the royal purple max-cycle engine oil i assume both also can use rite for bikes?? cos me riding a VERS
U PAY PEANUTS, U GET MONKEYS!!!
the Royal Purple dat cost $10.50-11 is for cars only.... will spoil ur clutch n gear..
use the RP Max-cycle... heard it was good... cost $18... if im not wrong...
i used the Cheap RP..... and it aint feels good... to thin.... n very rough feeling....
or use Mobil One frm LAB... tink around $15?
'01 - Honda Repsol
'12 - Yamaha FZ1-N
did the max-cycle motorcycle oil price went up (last oct'04 was S$16)?
if u ask for my opinion, i still say RP max-cycle motorcycle oil is the best for my bike.
i used RP max-cycle motorcycle until my recommended oil change at 4000 km n it felt at time of oil change just like castrol R4 (when new).
currently trying out silkolene fuchs 4t pro plus, not as slick but still new oil, running for about 1000 km now.
my advise don't use oil for cars (motor oil), they r not design for bike usage, spend a little bit more n it is worth the amount.
if u really want to save $$$, use semi-syn oil for bikes rather then use motor oil.
Note of caution: Motor oil do not contains zinc and phosphorous, as these metals are hard on your car's catalytic converters. They're substituting molybdenum disulfide, which lowers friction and improves gas mileage. It also causes problems for people with wet clutches, that is most motorcycles.
:cheeky:
:cheeky:
how much did ur silkolene fuchs pro 4 costs?? & where did u get it done??
Originally posted by stsoh@Feb 25 2005, 08:32 PM
got this fuchs from a website banned by sgbikes.com, can only whisper if u want to know. LOL :cheeky:
pm me too.
