My friend told me only able to go via shipping as per mentioned by you too.
Charges are sky high too.
These will be enough to deter me from buying overseas already. :(
Thats why engine oil business is actually a "safer" business, not affected by online shopping.
I had a chance to chat with an engine oil manufacturer sales engineer and this is what he told me,
In layman term, for high performace, high rpm, high heat vehicle, one should go for thicker oil. Cause if use thin oil, the oil might evaporate too fast leaving not much lubrication and cooling effect in the cylinder. If use thicker oil, the evaporation rate is slower.
He also mentioned due to semi syn nature, it is not able to mate well with its addictive. Even if the oil manufacturer add those super good addictive inside, it is actually not effective. Hence no matter how "good" is the oil, it will never be as good as a full syn.
As for ester, he actually mentioned it is abit "corrosive". It will slowly "attack" the seal, gasket etc, in long run. However it is very good for high heat = high performance.
thanks 4 e info.
cant wait for my nxt oil change :)
schaeffers!!
Yes its worth. There are other brands that are almost as good available cheaper but 300v probably the best there is. Chg at recommended OCI. Dont waste money n fully utilise its qualities.
Thanks! BTW, care to share the alternatives?
Havoline® Formula
SAE 20W-50
Saw this in jb caltex at +/- 60rm for 4L.
But decided that how picky i am and hate being stuck with the same oil for 3000-5000+/- km
Decided to stick with my schaeffers
anybody tried ipone engine oil?
29/06/16 : Honda MSX 125
Havoline® Formula
SAE 20W-50
I bought it in Singapore at caltex. Doesnt last as long as Shell Rimula R3x. now my best discovery is penzzoil HDEO is one of the best I ever used. Super super quiet and smooth.
question. is it true that to estimate the engine oil change for the bike is to estimate based on the engine oil capacity of the bike? 1 liter apporx 2000km so a bike with 3 liter engine will need to change engine oil approx. 6000km( fully syn)?
EO change is based on your bikes' OCI.
for example a S4 Revo OCI is 12000km. of course you wouldn't want to use mineral is you want to use for that kinda distance AND you'd change just before reaching the OCI, not on or before...
Read up more about fully syn oils, they can last more than 6000km.
Assuming that no oil was "eaten" by the engine, the same grade of oil will last the same, regardless 1, 2, or 3 litres.
Of course, single cylinder 2b bikes may "eat" some of the oil during the duration of its life inside the engines compartment... kupkia etc etc....
the advice you got, as in your post, is a conservative way of "measuring" the change intervals.
I wouldn't say it's all wrong, though you'll spend more on your bike than you need too...
btw, What bike are you using?
Just my $0.02 :angel:
Goodee hor hot goodee... Mat witz sebastian! :p
Take note oil change interval should also take into consideration fuel, moisture, carbon contamination from the engine. Especially with spore hot and humid climate that increase the rate of oxidation of the oil.
Thanks but where to get it?
Bro, though debatable, you are rather right and safe to say so.
That has always been my practice too.
my 2 cents. bike of
1L eo should change about 1000km because very little oil is circulating.
2L = 4000
3L-6000
mobil 1 is pretty good. the 40 weight. not the cheapest but decent.
anyone tried the new Motul 300v? heard formula changed also and its better. Triple ester technology?
might go for Royal Purple next. just for fun.
A question bothering me all the time.
We can use almost any oils for our 2B Cubs?
Anyone able to advise whether these oils are suitable for Sparks?
1.Royal Purple 01140 API-Licensed SAE 10W-40 High Performance Synthetic Motor Oil
2.Castrol 06246 EDGE 10W-40 SPT Synthetic Motor Oil
3.Lucas Oil (10710-6PK) Semi-Synthetic 10W-40 Motorcycle Oil
4.Red Line 11404 10W-40 Synthetic Motor Oil
5.Pennzoil 550022829 10W-40 High Mileage Vehicle Motor Oi
Are these oils suitable for Spark 135LC?
Road hogger @ 50km/h on 4th lane :cool:
A bike can go up till 200km/h, can the rider go up till 200km/h o_O
All the oils u list are meant for cars, usually too slippery for ur wet clutch. There could be chance that one of them could work but nt worth the risk. Just stick to the reputable 4T oils. Make sure there is a JASO-MA certification.
