Originally posted by ET@Aug 12 2005, 06:52 AM
gsxr750 at motorwolrd, having promotion for maxima at $70 for 3 btl & a change of oil filter
OK but my bike is 2 stroke leh so wonder if my bike can use? Anyone knows or should I just just the gear oil? Which is better ha?:confused:
http://img227.imageshack.us/img227/9692/img9124zb3.jpghttp://img259.imageshack.us/img259/8310/alanhv3.png
Aprilia Riders Club Singapore (ARC)
a place where all aprilians gathers and have fun together!
Guest Demon_gal56
I like the FUCH one too.... very smooth for the engine i suppose.. :cheer: :cheer: :cheer:
Originally posted by alanhim@Aug 1 2005, 12:29 PM
Anyone help Pls.? For 2 stroke bike is it better to use fully syn oil or gear oil? Any difference?
2 strokes bike use Gear Oil is better.
Hatred do not ever cease in this world by hating but by love.
This is an eternal truth...
Overcome anger by love.
Overcome evil by good.
Overcome the miser by giving.
Overcome the liar by truth.
http://ist1-1.filesor.com/pimpandhost.com/2/3/5/1/23516/s/H/k/S/sHkS/funny-gifs-better-world.gif
OK. thanks. But do you know what the difference?
Originally posted by ET@Aug 18 2005, 09:17 AM
care to explain?:confused:
its not better as in it'll affect ur machine but more like it'll affect ur pocket. engine oil has additional stuff inside to protect the engine as it goes thru the whole bike. gear oil only need to lube the gears, so doesn't need those additional stuff inside. So, its possible for the engine oil to be the same quailty as the gear oil but much more expensive cause of the aditional stuff inside
abit :offtopic:
sorry but to explain to both of them.
thanks mod
alanhim & ET
to add on to redname
correct me if im wrong.
2 strokes bikes is different from 4 strokes bikes.
the pistons in the 2 strokers are not immersed wif the Gear Oil when rider changed.
instead it will soak the gears of the bike.
so Gear Oil is for 2 strokers & Engine Oil is for 4 strokers.
:goodluck:
I see. So it's more important to have a better 2T than 4T right? Thanks guys.
yup
2 strokers need good 2T
always need to top up.
or else... :giddy:
last time i used Rockoil Gear Oil for my 2 strokes bike.
not bad.
:cheeky:
Originally posted by stsoh@May 25 2005, 11:39 AM
if u r comparing semi-syn to full-syn, it is the quality of oil tat is make from.
full-syn provides better protections n performance for ur engine.
most full-syn eo based on POA, ester or poly ester (best n most expensive).
don't buy those hydrocrack type tat claim to be full-syn, these r only dino oil based, it is the same as semi-syn (castrol r famous to have use this method for manufacturing their full-syn eo).
so tat means Castrol R4 is not fully Syn?
Hi Guys... anyone bought Motul E.O from Mah motors, the one opp SLT.... just bought Motul 5100 @ $12/-... seems to cheaps compared to others... but this shop listed as one of the dealers in motul webby... so wondering wheter this chiong one??? BTW, bought only a bottle for top-up only...
original stuff...
but...
semi-syn.
War is Peace.
Freedom is Slavery.
Ignorance is Strength.
Originally posted by chua_chee_keong@Sep 9 2005, 02:22 AM
So where to get the EO for Maxima which is the best price :confused:
i find the prices at planet moto one not bad, $20 & $22, i tink the diff is the SAE rate but both fully syn. u might wanna try racewreks at alexander, not sure of the price but he's prices for oil normally quite ok, u go check then post here can? :sweat:
For my opinion:
2-stroke bikes use normal fully syn engine oil will do, for the gearbox.
Juz rmber to change it regulary, evry 5000km.
But 2T shd use the POWER POWER one, for lubricating the piston so that it "dances" smoother n faster!!
4-stroke bikes, esp "BIG COWS", shd use good grades of 4T for the engines, becoz it lubricates not only the gears, but the piston as well, in this case, pistons.
And also rmber to change regulary for optimum perfromance and life-span of the engine.
PS: You take care bike, bike take care you!
:cheer: :goodluck: :cheer:
That time MotorX got special promotion..... now must check if they still have, if not there's a thread by the importer under "Advertisers" section, can check the various shops.
The price for Maxima Extra & Ultra is @ $18 & $20
Just change 2 weeks ago
Honda NSR150 SP : Feb 04 - Feb 05
Honda CB400 Spec II : Jun 05 - Jan 08
Nissan Latio : Feb 08 - ???
the price is from racewerkz or planet motor?
Philosophy A: Ignore what everyone else thinks. Riding is a better way to get around. Ride paranoid and keep your skills sharp
Philosophy B: Ride with somebody who's better than you. You will pick up a handy trick or new skill just about every time you are out
Philosophy C: You don't need a big bike to prove ur passion for riding
Package deal at Eddy Ong in AMK Industrial Park, got mine 3 X Maxima Extra 15W50 with oil filter for $65 :thumb:
http://picturesky.com/albums/userpics/11161/yamaha.jpg<span style=\'font-family:impact\'>I go 60 nia
http://www.singaporebikes.com/forum/uploads/photo-1478.jpg
For Sale: Arai Gunmetal gray side cover for RR4, right side (Still in packaging)
