i talking abt the design of our STOCK air box.. not airbox take out... i asking, from the design of the STOCK air box, still in its Stock position on the bike (which means never take out airbox) can water get into the carbs?
hi bro,
no.
regards.
  • Replies 100
not sure bout how this happen, but i found a small leaf in my airbox the other day.. hahaha... how the heck did it get there??!!!
who gets summoned for not signalling? i did..
dumb luck? maybe...
nak nene mandi air bunga...
leaf uh?check sumore la skali got spider kang...haha:cheeky:
Speed Is Nothing Without Control:thumb:
my stock filter i used only for 3 days since i bought the bike....
now it is still in good condition...
wat i noe is if u change ur carb,den u can use KNN filter or other filter bcoz of the size....if im not wrong lah....
but u say pollini can be fitted onto our carb?
how much it cost??
YAMAHA spark135 '07 - present
HONDA S4 '08 - present
just wondering.. those malosi red sponge like filters.. u tink those filters r good? i tink this filter can easily be cut into shape to put onto out stock airbox..
dumb luck? maybe...
  • 8 months later...
;3276970']air filter illegal or not ah? if stop by TP how much is the fine?
Don't put any filter also won't get fine. But yr pocket will kenna burn big hole becos have to overhaul when all the dirty stuff go inside yr engine when u got no filter. If u fix Turbo on yr bike then TP will fine u $550:deal:
http://i186.photobucket.com/albums/x219/ts_subaru/Hondasonic.jpg
NO more ROV/TP on the roads. :thumb:
im using posh open pod filter for wave, u know for k&n filter we normally oil it first b4 using ryte? wat abt the posh one? can we oil it? cos i got the k&N recharger kit with me and was thinking whether i should use it or not.
also i heard that if want to buy K&N open pod for wave must get the car one which has same diameter as the wave carb is it true? where got sell k&N filter cheap2? jurong point which shop haf ar?
many thanks
Bro actually for small cc bikes there's no need to change to oped pod filter. Esp for 4 strokes. Reason is because If u don't intend to change carb, u have to set the carb again for the open pod, which in certain cases changing the needle. So it's not very worth it if u're using and open pod and u're using standard carb. Airbox is much better, there's more noticeable power in the low end of the powerband.
Point is, rather than changing to a k&n open pod and spending nearly 100 bucks, stick to the airbox. Unless u're changing the carb. Coz there's much to be done to the standard carb once u use the open pod.
http://i18.photobucket.com/albums/b112/h4hahak1m/DSC01047-1.jpg
Spark 135 and x1r riders!
Add yourself into our new FB page now!
Or if u're and ex-spark/x1r rider.
No registration fees :)
https://www.facebook.com/yamahat135sbf
  • 4 months later...
Hey.
Just asking if lets say i took out my airbox and want to get the k&n air filter fix, issit possible ? Some workshops i go to they say that the carb have to be changed in order to fix the filter. Damn exp leh like that. Is it true ?
Live to ride another day.
http://img35.imageshack.us/img35/1076/img0048u.jpg
the k&n air filter available for spark is the panel kind.. not the open pod..
open up ur stock airbox and see the air filter inside.. the rectangle yellowish-brownish(if dirty) thing..
that's ur air filter..
by using hi-flow air panel, u're allowing higher air intake to ur carb and also cleaner air.. as those panel has better filtering system..
not forgeting to re-tune ur bike to accomodate the higher air flow..
btw i selling my JFC air filter.. almost like k&n.. cheap n good...
Lousy Noob Rider
How much are u selling? Is it washable? Suitable for Spark?
Okay. I just went to HKL just not and they are selling K&N cone air filter for spark135 at $65. Point to take note of:
1) It is a modified version therefore it fits nicely once the air box is taken out.
2) It will filter away dust but water still may seep through the filter fibre hence leaking into the carb(which obviously is not a good thing).
3) Air/Oil ratio needs to be tuned since air flow will be higher after fitting the filter.
it's or spark/x1r..
hw much? $50 ok?
washable yes, the same way u wash/maintain/clean/oil the k&n.. u can use k&n cleaner/recharging kit..
mine is not OPEN POD air filter hor..
mine is the PANEL kind.. like your stock filter.. but with higher air flow and better filtering rate of dust/etc etc..
K&N have 2 types for our bike..
1) Open Pod (Pineapple/Cone - whatever ppl call it..)
2) Panel
*impt notes*
k&n does not fabricate filter for our bikes.. so those selling on the market are custom-made-with-some-modification-to-fit a spark/x1r..
Lousy Noob Rider
it's or spark/x1r..
hw much? $50 ok?
2) Panel
*impt notes*
Bro,
PM-ed u!
Wahseh.
I went to HKL to open port and fixed the K&N oval air filter. Have to do some tuning for your oil/air ratio. After that, the bike feels lighter and its easier on the throttle. Damn shiok !
hi everyone . if i change to air filter does it affect the top speed? but i hear my frenz say if change to air filter will increase pick up but decrease in top speed. is it true?
Different sound (As wut 'kurarensu' said), K&N filter can last longer unlike stock air filter. So don't have to change every 10K...
Heard K&N filters can last for 160K... Donno true ornot...
my FBB plate hit 55k mileage, still havnt change anyting except for oil filter and engine oil. hahaha. 120 !!!! still strong !!! wuuhuu !! :sian:
MUSIC IS LIFE. LIVE A FUN ONE. LISTEN TO SKA
