  vibration_42 said:
Hi guys, any idea how to Manual start the TA200? I can't start my bike electrically now! I keep getting the tick tick sound on the right side of the bike. I guess it means bat low but now I can;t even start to get it to the work shop!
HELPS!
http://lmgtfy.com/?q=how%20to%20push%20start%20a%20motorcycle
HELPS!
push start? can find google for it... first time do usually very tiring one...
or jio your rider friend to push ur bike with their bike... den u throw ur clutch... =D
Do what's right, not what you think is right. =)
  VidaK said:
nah... changing the brake kit to higher end ones is too extreme for phantom... now my rear brake is too harsh already... :cheeky:
that depends on how you ride actually ;)
HELPS!
Push start! I reckon I've to do on mine the next time I try to ride :sweat:
i dont have to worry about it....my place comes with push start facility..but for 1 try only..
no samullah...
nop... just throw clutch can le.. dun need to press the switch!
i think somewhere here got teach...
but lotsa warning such as bike ran off cos too much throttle, clutch nv clutch in after engine starting, wheel roll over toes.. ahaha.. lotsa such stuff.. do be careful~ =)
jB> keep up the good work for updating the problems, reasons and solutions post summary.
.....:bouncefire: Reminder to all riders including myself:- Ride safely. Wear proper attire. Do not rush :bouncefire: .........
sian was riding quite fast jus now, around 100, then traffic light turned yellow, so kinda did an e brake, with "manual brake system" haha. but then the prob was i only did it with the front brake, and not the rear brake. before coming to a stop, my pillion and i both heard a pop sound, kinda similar to a punctured tire. checked the air pressue and it was fine. on the way back, friend noticed a screeching sound coming from the rear of the bike. when coming to a halt, or when doing a turn, also noticed a weird heavy grinding sound. was thinking whether the rear wheel alignment is off. any advise?
appreciate for reading!
Hi weian, had similar encounter like yours..
the pop sound u heard most proably result of sudden decline of speed..
as for the grinding sound,u may wanna check ur brake pad..
if its botak, it will start grinding the metal plate of brake pad..
if persists u may needa change the whole brake clamp thingy instead of the brake pad =)
Dave
thanks mepkoh (typed meepok initially, haha) and dave!
in fact, i just had my rear disc pad changed only recently, so shouldnt be botak so fast. maybe it's the clamp as u said. will go down to chong when free. thanks again!
saddened.
Have you solve the problem, do tell us what causes.
For my past experience, the rear brake pump jammed after a 'POP' sound, like punctured sound indeed. Then the rear brake cannot be applied, bike was like someone holding the bike from behind, have to trottle a lot to go forward, it was since the brake pads cramped to the disc. Can diy to release some brake fluid but went to mechanic straight. Ride real slow because don't want the burning smell of the brake pad. In the end changed a new rear brake pump, can't recall how much.
eh, i continued riding and the problem SEEMS to me that it has went away. my rear brake didnt jam or anything like that. but for some time after the incident, whenever i do a turning or cornering, the weird sound still occurs. but i THINK and FEEl all is good now. hopefully. :D
UPZ FOR GREAT INFO.
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Solution: Retune the carb.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
  jB said:
Thanks for upping list, I don't think phantom only has 23 common problems? :rolleyes:
well you can always contribute to the list
22/10/2009--20/01/2010 TA-150
20/01/2010--28/08/2010 KSR-110
28/08/2010--??? NSR *wink* *wink*
UPZ FOR GREAT INFO.
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
  Hydher said:
probabbly ill fitting or disc and pads. keep checking your disc.. might have cracks in time to come if not rectified.
hi there hydher,
i found out the issue already, it was due to the lousy brakepad supplied by the "friendly shop" along the road of queensway shopping centre. right outside the bus stop. i spent over $400 on china parts (which they claimed to be honda original). and yet more problems resulted from it. i strongly do not advise anybody to get it from there.
it's long this road, http://maps.google.com/maps?f=q&source=s_q&hl=en&q=&vps=2&sll=37.0625,-95.677068&sspn=38.502405,79.013672&ie=UTF8&geocode=FcGkEwAd5egvBg&split=0
  jtzx said:
byon you selling your phantom already ar? think i saw your post somewhere.
nope i'm using it for transport.. i was intending to rent it to people who wants to use it for weekdays.
Hi there, i've updated the list.
  Quote
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Edited by byon
neater? updating the list
