If I not wrong, size 7 is shorter, thus it will get hot very fast. Size 9 is wat is call a cold plug because it is longer(length), thus heat can dissipate easier.
What I mean for long distance use size 9 so that ur engine(if I not wrong) won't overheat as u ride for a pro-long period of time.
Size 7 is normally for smaller cc bikes. So that it can go into their normal working temperature fast enough (too cold engine is not good, must be rite working temperature than can function well).
So size 8 is good for Spore's start n stop riding.
  • Replies 833
never do that...... will damage your engine.
Signal First Before You Brake
SuperFour Biker
Posts ALL Rights reserved�.
THE WINGS TO RIDE FREELY
but the saving is enough for the saving of the cost of the plug?
SuperFour Biker
Guest enHANZed
i also experienced better performance with iridiums ...could be psychological though
guess it depends on the firing of the plugs..
from the combustion & dissipation of fuel
higher end models like the tapered splitfire etc are designed
to give you a cleaner & stronger combustion ratio in the piston chamber
thus saving yr pistons from heavy handed mech workshops that execute you
the moment you say piston jam
in a nutshell higher end plugs simply provid a cleaner combustion, fuel quality is also crucial but for singapore, no worries fuel wise quality is good enough our lowest is ron92, for other countries they still using ron90
hope this helps
cheers
looking for drz parts, any parts will do!
Agree wif desmondspencer there. Definitely more fuel efficient...hheee n power too
anyway...any guys know where's motoworld? heard there's motul 300v there...wonder if they sell iridium plugs too
cheers
Originally posted by spider_dude@Dec 16 2005, 07:46 AM
Hey there ... Pple me need info... Just bought a brand new VTEC3.. Need info on oil change. Which brand is the most compatible for VTEC3 and where i can get it...
well,congratulation on ur new bike,so 4 oil change is depend on u as some selling r cheap n expensive.for long run i suggest u try sikolene or motul brand.its gd to buy enoensive as it gd 4 ur engine,.
safe ride n hv a nice day:goodluck: :thumb:
angry: Yamaha the best, f$%* the rest:angry:
For run in just find the cheapest mineral oil to run ur spec 3. Change oil often for the first 3000km and dont forgot the oil filter. After that use wat ever u want...
brand new for running in can use semi syn oil...
then after run in depends on wat u wanna use liao...
all depends on individual... but dun use the wrong kind of oil esp cheap cheap ones... using the correct oil n good oil will protect ur engines...
Yamaha FZ1S: Nov 09 - May 13
hachi right...as long as u change regularly...noneed to worry...
i always use motul...but the bad news is...no more stock liao..sobsob!
http://www.ducatinewstoday.com/wp-content/uploads/2011/06/Stay_a_Hero_Campaign.jpg
Like father like son
is not the oil lght up u muz change is the oil in the engine chassis not enuff... faster go n top up or piston will burn.
Life Is Never Fair.
Some pple slog for the paper in their wallet.
Some slog to feed the paper to the pple w/o the wallet.
OMG 2005 did you service your bike before?
or you oil is leaking?
bring to shop and have a check...
sound like you are knowledgeless on bike huh.
SBF
any package for bike info like the parts, what to look out for, when to change this and that and servicing as well....
i think of organize one and get together too...
how how?
do some KM is not bad one...
KM=knowledge management
http://www.sharemation.com/wadthefart/n/logo.JPG
Dun think about 7%
life still goes on.
SBF
how how?
No lah, juz that I barely have time to know more about my bike before some 'driver' crashed his car into me...some way to drive. The bike spent the next few months in the carpark. :faint:
Basic service info I am still ok, juz that I dun want to spend that $40 towing just to change the engine oil and such. Silly rite...
Just realised that the oil warning lighted up only when the bike is started, after a sec gone liao. :|
For the knowledge management part, sounds good, but I think much of the basic knowledge are in the stickys liao. :smile:
Hardcore
